Question about EliteGroup K8M800-M2 Motherboard
Bios setup when my pc is started... without pressing delete key automatically bios setup appaers on the screen
    Novelist:
  • 93 Answers
You may have something failing in the POST (Power On Self Test). Typically, they'll just hang, or even reboot, if that's the case, but... you never know. I'm guessing that if you save and exit from BIOS, it reboots, and sends you right back into Setup again.
Start by removing or swapping out things. First, I'd do the DDRAM chips (if you can). Reseat them, and be sure they're inserted properly. Once you're in BIOS again, check to see if the amount of RAM reported matches what you have installed.
Next, if you have a video card, take it out, and switch the BIOS to use the onboard video. Also, remove any other add-on cards you have.
If none of that fixes the problem, you can find the jumper on the motherboard (should be near the battery), and set it to clear CMOS. Follow the instructions in your manual on how to do this. Once that is completed, try restarting.
Let me know how it goes.
Cheers
Posted on Nov 04, 2008
My satellite Toshiba L875D-s7230 says bootmgr is missing press ctrl alt and delete to restart and does nothing
Which operating you are using?
Method 1: Run Startup Repair from Windows Recovery Environment (WinRE) To run Startup Repair from the Windows Recovery Environment (WinRE), follow these steps:
  1. Insert the Windows installation disc into the disc drive, and then start the computer.
  2. Press a key when the messagePress any key to boot from CD or DVDappears.
    If your PC does not detect the media automatically
    1. During the restart process, read the screen for any instructions that explain how to interrupt normal startup and enter the basic input/output system (BIOS) setup utility. Most PCs use the F2, F10, ESC, or DEL key to begin the BIOS Setup.
    2. Look for a tab in the BIOS Setup Utility that is labeledBoot Order,Boot Options, orBoot. Following the directions on the screen, use the arrow keys to go to theBoot Order, then press Enter.
    3. Locate the CD, DVD, or USB flash drive (this might be called Removable Device) in the Boot list. Following the directions on the screen, use the arrow keys to move the drive up so that it appears first in the Boot list. Press Enter. The boot order sequence is now changed to boot from the CD, DVD, or USB flash drive.
    4. Press F10 to save your changes and to exit the BIOS Setup Utility. SelectYes in the confirmation window. The PC will restart.
  3. Select a language, a time and a currency, a keyboard or input method, and then clickNext.
  4. ClickRepair your computer.
  5. In theSystem Recovery Optionsdialog box, select the drive of your Windows installation, and then clickNext.
  6. At theSystem Recovery Optionsdialog box, clickRepair your computer.
  7. Click the operating system that you want to repair, and then clickNext.
  8. In theSystem Recovery Optionsdialog box, clickStartup Repair.
Method 2: Rebuild the boot configuration data (BCD) from Windows Recovery Environment (WinRE)
  1. Put the Windows installation disc in the disc drive, and then start the computer.
    4. Press F10 to save your changes and to exit the BIOS Setup Utility. SelectYesin the confirmation window. The PC will restart. Allow the PC to restart normally. The scan will take a few minutes and remove any malware that may be infecting your computer.
  3. Select a language, a time, a currency, a keyboard or another input method, and then clickNext.
  5. Click the operating system that you want to repair, and then clickNext.
  6. In theSystem Recovery Optionsdialog box, clickCommand Prompt.
  7. TypeBootrec /RebuildBcd, and then pressENTER.
Jan 20, 2017 | Toshiba Computers & Internet
How to Insert Boot Media?
Mostly you wil have to adjust the BIOS of the computer to boot from USB or DVD media.
When booting most computers mention the button(s) to press to get into BIOS:
--A Function key (such as F1, F2, or F3)
--The Esc key
--The Delete key
On some PCs, entering the BIOS may require pressing another key or a combination of keys. Keep your eyes open for an on-screen message that says something like: --'Press F1 to enter setup'
--'BIOS settings: Esc'
--'Setup = Del'
--'System configuration: F2'
If you don't catch it the first time, simply try again. Your computer's documentation may also tell you which key to press.
3. When you know the right key, start the computer again and press the key when the first screen pops up: You may hear a confirmation beep or see a new message. If you timed it correctly, you'll be in the BIOS within a few seconds.
Good luck,
A.Misset
Oct 18, 2016 | Computers & Internet
Bios utility
BIOS Setup utility?
Dell laptop?
Lot of information here.......let me see if I can sift through it.........
Post the model number in a Comment.
The model number can be found on the Bottom of the laptop.
As soon as you turn your laptop on, watch for the Dell logo screen.
WATCH the bottom of the screen.
What key does it state to press, to - enter BIOS Setup?
Write it down.
If Windows loads let it load, and run a few minutes. Then turn the laptop off normally.
THIS time AS SOON AS you press the Power On button, start tapping on that BIOS Setup key.
Tap in 2 second intervals.
You may hear beeps. Those are Stuck Key Error Code beeps, and it is you that is doing it. Ignore them.
This will get you into the BIOS Setup utility.
If Windows doesn't load, press the CTRL key, and ALT key, and DELete key, AT THE SAME TIME.
This will restart your laptop, and start tapping on that enter BIOS Setup key.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 15, 2013 | Dell Studio Computers & Internet
HOW TO DETECT THE CD ROM USING PHOENIX ROM BIOS PLUS VERSION 1.10 A02
The BIOS information is typically found at or near the top of the POST screen for a very short time ALR PC non / PCI = CTRL+ALT+ESC AMD advanced micro devices=BIOS = DEL Award BIOS = DEL Dtk Datatech Enterprises Co. BIOS = ESC Phoenix BIOS = CTRL+ALT+S Phoenix BIOS = CTRL+ALT+INS Restart your computer during the boot process you will see on the screen to press a certain key usually Delete or F2 to enter setup
this will differ depending on which bios you have Press and hold that key during the boot up process to enter BIOS Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system (note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults) after windows has loaded your computer will automatically restart it might restart 2 times one to finish the installation the next will be because the operating system is loaded and will boot from your cd during the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart otherwise it will keep booting from the cd /dvd drive
If the cd rom is not being detected ?
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Feb 28, 2013 | Computers & Internet
Need to access the menu
Know what the ->enter BIOS Setup key is?
It's on the bottom of the computer manufacturer logo screen.
Got it?
Now press the CTRL and ALT and DELete keys at the same time.
Restarts the computer.
JUST AS SOON AS IT STARTS, start tapping on the enter BIOS Setup key.
Tap in 2 seconds intervals.
If you hear beeps ignore it. These are Stuck Key Error Code beeps, and it is you that is making them.
Still No?
Turn the computer off by holding the Power On button in, for 10 seconds.
WAIT 20 seconds, then press the Power On button.
AS SOON AS YOU PRESS the Power On button, start tapping on the enter BIOS Setup key. The rest is above.
Regards,
joecoolsvette
[The time period to enter BIOS Setup goes by F-A-S-T!
As soon as you see the computer manufacturer 'splash screen', (Logo screen), it may be TOO late. The above method makes sure you get in BIOS Setup ]
Nov 21, 2012 | Computers & Internet
Bios setup screen doesn't apper
during the boot process you will see on the screen a certain key to press usually the Delete or F2 to enter setup (BIOS) this will differ depanding on you computer and operating system bios
hope this helps
Oct 17, 2012 | Computers & Internet
Can't get pass the setup utility
hope this helps
Sep 13, 2012 | Toshiba Satellite Pro A210-EZ2203X...
WHAT IS BIOS
BIOS is Basic Input Output System. On startup, before the windows screen comes on, you need to press one of the F# keys to enter the BIOS/setup screen. On my PC I have to press F2 to enter the BIOS/setup screen. The delete key can also take you to this screen on some PC's.
Mar 17, 2012 | Advent Computers & Internet
How do i access the BIOS of my pc? when my plug and play compatable sound system is connected to my onboard sound, the computer does not detect the device
You can access the BIOS by rebooting the computer. Upon bootup, press DEL button (you may want to press it several times). The BIOS or CMOS settings will appear. You may need to enable USB devices for your computer. Good luck!
Oct 25, 2009 | Audio Players & Recorders
Unable to get into BIOS SETUP
hi there,
On most systems, the key or key combination to press to enter the BIOS program is displayed on the screen when the system boots up, at the time when the BIOS is ready to enter Setup.
take a look at some default keys:-
  • {Delete} (modern Award and AMI BIOSes)
  • {F2} (modern Phoenix BIOSes)
  • {Ctrl}+{Alt}+{Esc}
  • {Ctrl}+{Esc}
  • {Alt}+{Esc}
  • {Ctrl}+{Alt}+{S}
  • {Insert}
  • {F1}
Apr 10, 2008 | Toshiba Satellite 5005-S504 Notebook
EliteGroup K8M800-M2 Motherboard Logo
57 people viewed this question
Top EliteGroup Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Matthew Spark
Matthew Spark
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
