Question about Philips 60P8342 60" Rear Projection Television
Sound Goes Off and TV Comes On By Itself
I Have a Philips 60" TV Model 60P8342 and after the TV is on a while the volume starts going off and back on and after a little longer the TV will start changing channels. The TV will also will come back on by itself once it's turned off. I have tried disconnecting the remote control sensor and the front panel controls but that didn't help. Any help would be apprecicated. Thanks!
  • Anonymous Jul 14, 2008
    I have the same exact problem.
    What is the SSB board? Can the repair be made by a novice with good soldering skills?
  • 4 Answers
You need to replace the SSB board
Posted on Jun 08, 2006
Philips 60p8342 projection tv 1)Color distorted, whitish and dull 2)Picture bowed at top and bottom 3)Set turns off by itself 4)I can't turn on set unless its been off and unplugged for many hours and then...
These sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 16, 2010 | Philips 60P8342 60" Rear Projection...
Flashing power button no picture or sound!!!
Ive had this problem... Usually all that is needed to be done is a few reboots... First unplug and let sit for one min and then plug in and allow three mins for it to boot... Didnt work retry and retry
Dec 31, 2009 | Philips 60P8342 60" Rear Projection...
Sound goes out and comes back on
If this is a pair of wireless speakers hit the button in the back of the speakers to change the channel. if it is the speakers inside the set, it could be a loose solder connection that heats up after a while and then the solder seperates preventing sound. this same issue could happen to the final amp in the tv, when they get bad they will heat up and stop working. All requiring a tech to troubleshoot the problem.
Sep 10, 2009 | Philips 60P8342 60" Rear Projection...
Philips rear projection TV model 60P8342.
It`s not Eprompt, it`s the Eprom, Erasable Read Only Memory. The Eprom holds all the information in it about your set like has it got Ni-cam Sound, A wide-screen, A projection set plus a lot of other information like Convergence settings, RGB setup, PAL, NTSC settings plus customer settings like Colour, brightness etc. There are other settings besides these which are in binary bit code which can control the power supply, Standby timing etc etc. The Eprom may only be an eight or a sixteen pin device but it a crucial part of the set where information is perminantly being read from the Eprom to make sure the three guns are set correctly and the convergence errors are being kept in check. This is a very time consuming job even for a qualified technician, I know, I used to do these and Philips sets are notorious for Eprom and uPC failures. The Eprom comes formatted from the suppliers, so there`s absolutley no information in it at all meaning that you have to start from zero. If you can get the set to come on long enough and you can get the set into service mode, you may be lucky where you can write down the 200-300 or so settings, If not, WHAT A JOB. Believe me, you can change the Eprom in 2 minutes, but it could take 1 or 2 days to set it all up again and even then it`s very difficult to get it perfect. Ian
Aug 10, 2009 | Philips 60P8341 60" Rear Projection...
I have a philips 60 inch tv with on picture and sound
There are two common problems with Projection TV sets. Problem #1) Convergence Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
  • Dull looking video
  • White looking video
  • Red/Orange looking video
bb0cf99.pngSOLUTION http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 28, 2009 | Philips 60P8342 60" Rear Projection...
No picture, no sound. sounds like a bird cherping in back of tv.
power supply wont come up, so it chips. the fuses are super hard to check on this one, but you can pull the cable that goes to convergence sometimes and it will come up with a bowed picture. its the 3rd ribbon cable going from the defleciton board (lots of high power parts) to the signal board (lots of daughter boards, small parts) there are 3 cables hooking the two together, pull the one furthest from the back and try to power on. be ready to pull the plug but it will come up and run with a bowed pict if the ICs are bad. if so, see this link for tips
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Jan 06, 2009 | Philips 60P8342 60" Rear Projection...
Philips 60p8342 chassy ptv 916
check all your solder connection and test the resistors on the conversion IC's , also check oscilating circuts
Oct 27, 2008 | Philips 60P8341 60" Rear Projection...
Popping sound and picture goes out
Sounds like the flyback or the picture tube. Either items can cause this. If the pop comes from the rear right side its the flyback. If the sound comes from the lower front behind the speaker grille its the tube. Let me know what you discover as I have access to any of the parts you would need.
Mar 10, 2008 | Philips 60P8342 60" Rear Projection...
Philips TV 60P8342
No reset, but you can check for vertical problems and convergence problems also. No high voltage. Check horz. output and caps
Aug 01, 2007 | Philips 60P8341 60" Rear Projection...
Philips 60P8342 60" Rear Projection Television Logo
167 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
