Question about Sony KV-27FS13 27" TV
Suddenly, "No Signal" display when cable box/VCR Connected to UHF/VHF Jack
My KV-27FS13 color TV, with a cable box and Sony VCR connected to the UHF/VHF jack on the rear, suddenly has started displaying the yellow "No Signal" message when the TV is turned on. The red standby light flashes twice and goes off, then the "No Signal" appears. This just happened this evening after having had the TV on this morning and everything working perfectly.
Turning on the VCR and pressing the TV/Video button doesn't change anything. Still "No Signal".
Connecting this same cable box/VCR setup to the rear jacks on two of my other color TV's works fine; nothing wrong with the cable box or the VCR; everything plays and displays just fine.
The red, white and yellow A/V connections are working. I can hook up my camcorder and DVD, and those play just fine in their usual "Video 1" and "Video 2" settings.
  • smithster310 Sep 14, 2008
    Forgot to mention. I bought this set in November 2001, and have had this cable box/VCR setup hooked up to it ever since.
  • smithster310 Dec 26, 2008
    Thanks to a recommendation from a buddy, I found a TV repairman who makes house calls. $35 for the visit to diagnose the repair (a bum tuner), $200 to replace it. The total was less than half the price of a new 32" flat screen, and much, much less than what I would have paid for an extended warranty over all these years.
    TV works great, and I owe my buddy a dinner at his favorite restaurant. Thanks to everyone on fixya who helped.
    Genius:
  • 1,665 Answers
Have a look at your manual below. If problem persists you need to call a tech to check if it can be repaired localy. If you have some experience remove cover and check the condition of electrolytic capacitors, resistors etc. at main board. You need also some special tools for replacing components. Good luck!!
http://www.retrevo.com/support/Sony-KV-27FS13-TVs-manual/id/274ag712/t/2/
Posted on Sep 14, 2008
    Brigadier General:
  • 6,966 Answers
Initially, may I suggest that:
  • verify that the KV-27FS13 is tuned to either channel 3 or 4 with the cable box and Sony VCR connected to the UHF/VHF jack;
  • play a known good VHS tape and determine if the taped movie would display on the TV;
  • verify if the Sony VCR has a VTR button and is pressed or activated.
Depending on the results of the above checks, probable faults could be:
  • defective tuner block/assy of the KV-27FS13;
  • defective rear jack of the KV-27FS13.
A temporary workaround other than repair would be:
  • connect the Sony VCR to the KV-27FS13 using Video (1 or 2) A/V INput (from the Sony VCR A/V OUTput).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
    Scholar:
  • 163 Answers
It seems power supply is faulty. Take it to authorized service shop to troubleshoot and repair.
  • 4,472 Answers
How long have you owned the tv? You have two options though your best bet is to locate your nearest authorized service center to have the tv repaired.
Thanks,
lee
  • Lee A.
    Lee A. Sep 14, 2008
    The tuner IF module or possibly a failed component(s) in the input control area. Follow this link to locate a sony repair facility.
    http://eservice.sony.com/webrma/web/inde...
    If you have a moment to accept and rate my solution accordingly I would greatly appreciate it.
    Thanks,
    Lee
  • Lee A.
    Lee A. Sep 14, 2008
    I have given you the best solution and what the problem is I hope you will reconsider and accept and rate accordingly so that I may assist you further if need be.
    Good luck,
    Lee
Will not connect to tv channel
  • Connect the existing Aerial/Cable TV
    signal (or from the Cable Box/Satellite
    Receiver {RF OUT or TO TV}) to the
    ANTENNA-IN socket on the
    recorder.
  • Use the supplied RF coaxial cable to
connect TV-OUT socket on the
recorder to the aerial input socket on
your TV (VHF/UHF RF IN).
Helpful Hint:
- Depending on how you have currently
connected your TV channel (directly from an
off-air aerial or Cable box or VCR), you will
have to disconnect some of the cables before
you make the above connection.
Feb 02, 2013 | Philips DVDR3380/05 DVD Recorder
PICTURE SEEMS TO BE BLURRED WHEN ITEMS MOVE FAST ON SCREEN, ESPECIALLY PERSONS IN CLOSE UP.
The Sony Bravia KDL-32BX320 generally gets excellent reviews (4.5 stars out of 5) from owners, so I have to wonder what you're watching.
This is an HDTV and should excel when provided an HD signal to display. SD (standard definition) signals often look worse on an HD display than on an SD display. An HD signal is only available via the following ways (reference the image below):9_27_2011_4_28_11_pm.jpg
1) An "over the air" (UHF / VHF) antenna is connected to the cable / antenna input and there is a broadcaster of HD content nearby (only an over the air antenna can input HD signals to this jack - no cable boxes, etc.).
2) An HD Cable TV, DirecTV or Dish Satellite set top converter, Blu Ray Disk Player (or other HD source is connected via HDMI or Component RGB jacks.
3) An HD video played back from a computer hard drive connected to the VGA jack (when the computer is equipped with a modern processor and video card).
You will NOT be able to view HD video if:
1) The source material is a SD (non-HD) source. An over the air antenna will not provide HD signals if the broadcaster does not have HD content to show or is not capable of broadcasting in HD. Digital is not necessarily HD.
2) The source material (other than over the air antenna) is connected via Antenna / Cable jack.
3) The source material is connected via Composite jacks.
The USB jack is generally not an input for motion pictures, but may display stills - depending on the TV's ability to play the format they are stored in (jpeg, gif, bmp etc.).
Hopefully, this will help you solve the problem you're having with the picture. Good luck!
Sep 27, 2011 | Sony Bravia KDL-32BX320
How to add an Exterior Speaker to Sony KV-13M10
Welcome to FixYa!
To add an exterior speaker to Sony KV-13M10, you have to have an AMPLIFIER.
  • At the back of your TV you will be able to see 3 RCA output namely = VHF/UHF, Audio and Video.
  • Use an RCA cable and connect to the Audio output.
  • At the back of your amplifier, connect the other end of the RCA cable to an RCA input labeled Audio - L (left, usually in white color).
  • Your speaker should be connected to your amplifier labeled output or audio out. The connection type depends on the make and model of your amplifier. The speaker wires usually come in red and black color. red goes to red, black goes to white.
A simple diagram will look like this:
TV audio out -------------> amplifier audio in (left, white color) amplifier audio out (left, white color) -----------> speaker (black wire) amplifier audio out (right, red color) ------------> speaker (red wire)
Have a great day.
Aug 26, 2011 | Sony KV-13M10 13" TV
MY WEGA SONY KV-27FS13 TV - HAS SOUND THROUGH CABLE BOX BUT NO PICTURE. I DONT KNOW WHAT CHANNEL TO SET IT ON- AND DO I PUT IN ON DIGITAL OR ANALOG?
Hello, hopefully you can help me. I just brought a used sony wega kv-27fs13 27 flat-screen tv. But when I put the cable wire in the TV it says No Signal. Do you know what the problem could be?
Jul 23, 2011 | Sony KV-27FS13 27" TV
I have an older but operable Sanyo VWM-700 4 head hi-fi VCR to connect to an older but operable 13" TV just to watch workout video cassettes(via cable, no cable box necessary).How are the connections made...
You connect the Antenna to the VCR, you connect the AV OUT from VCR to AV IN on TV.(Yellow, Red & White) (Doesn't matter as long as color to color) Then you TUNE the VCR to the channels and the TV simply acts as a monitor. You must tune the TV to the OUTPUT from the VCR. If ya play a tape and look for the signal on the TV, to "Tune it in" to the VCR. first. then go to tuner.
Jan 26, 2010 | Televison & Video
Best picture and sound
connect coaxial cable connector from your cable service company to cable box-----in jack.
2-using coaxial cable connect cable box out to tv-vhf/uhf jack.
connect projection tv audio out (var-fix)jacks to avr 230 line in.
Aug 22, 2008 | Audio Players & Recorders
No cable
try going into the menu of the tv and changing the tuner type from ANT to Cable
Jan 28, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Moved tv from 1 location to another
hi there, it may need some fine tune for the sony kv-27fs12 to be connected directly to cable jack wall. do some test. ty
Jan 10, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony KV-27FS13 27" TV Logo
251 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
