Question about Whirlpool GU2400XTP Built-in Dishwasher
My whirpool dishwasher clean button is flashing.
It started its cleaning cycle and it stopped right in the middle. The clean button is flashing and that is all it does.
  • kcchiefsfan4 Oct 15, 2008
    my whirlpool dishwasher clean button flashes 7 times and it will not work, what is the problem.
  • 725 Answers
Does the clean button flash 7 times then repeat... if it does you have a heat problem,, you will need to run diagnostics to clear the code and or find the problem.. let me know I can help
Posted on Sep 14, 2008
The CLEAN light is flashing on my Kenmore QuietGuard3 , but it won't clean anything. It starts a cycle for a few minutes, stops and starts flashing clean again. Any suggestions?
You will have to reset the dishwasher. First try and turn off the mains power and back on after a short time. If the clean light flashing starts again then you go through the hard reset procedure.
press NORMAL WASH then HEATED DRY buttons one after the other until all the lights on the board lit up (3X's). The dishwasher will enter into a cycle; Press Cancel. This should stop the flashing.
If you are supplying dishwasher from hot water inlet then make sure the inlet water temperature stays within the recommended range of 145 deg F.
Apr 21, 2013 | Dishwashers
Printer prints out blank pages
Follow these steps:
1. Load a few sheets of plain paper in the sheet feeder.
Turn off your printer.
Hold down the paper button as you press the power button to turn the printer back on. Hold down both buttons until the power light begins to flash, then release the buttons.
The printer prints its test page, which includes a nozzle check. Does the paper print out without any gaps or with gaps? If there are do this:
2. Load a few sheets of plain paper in the sheet feeder.
Make sure the printer is on and the ink light is off.
Right-click the printer icon in the bottom right corner of your screen (the taskbar) and select Head Cleaning.
Follow the on-screen instructions to start the cleaning cycle, which lasts about 1 minute. The power light flashes throughout the cleaning cycle and stays on green when the cycle is finished.
Never turn off the printer during a cleaning cycle or you may damage it.
When the power light stops flashing and remains on, you can check to see if the nozzles are clean. Click Print Nozzle Check Pattern and click Print. Check the printed nozzle check pattern to see if there are gaps in the lines.
If there are no gaps, click Finish.
If there are gaps or the pattern is faint, click Clean to clean the print head again.
You may need to clean the print head up to 4 times. You can also turn off the printer and wait at least 6 hours. Then try printing again.
If this doesn't work then double check that you have the toner cartridges in correctly. If you do then your print head is broken and/or burned out and it's best to just replace the printer. Fixing it would cost more than the printer itself
Jan 17, 2011 | Brother MFC 420CN All-In-One InkJet...
Oven self-clean won't turn off!!
You will need to press the stop/cancel button, this will clear the cleaning cycle, due to the interruption. If this does not clear the display you will need to unplug the stove for five minutes and then plug it back in and this should clear the display.
Nov 14, 2009 | GE Ovens
Lights flashing at end of cycle, dishes not clean
I switched it off at the wall and left it for a minute and set the dial to Stop and then set it again from the beginning and so far it has been fine. Thanks, DCD
Oct 02, 2009 | Miele Dishwashers
Amana nfw7200 washer stopped in middle of cycle and is flashing ''nd''
is it full of water? if so there is a drain problem and may have to clean out the pump
Aug 23, 2009 | Maytag NFW7200TW Front Load Washer
Icemaking cycle automaticall self stops and cleaning light blinks
ice machine runs one cycle and freezes ice will not release ice block to wire cutter. then after a few minutes the cleaning light starts blinking
Jun 11, 2009 | Kenmore 51lb. Clear Ice Maker
Not draining properly and stopping in middle of cycle
Take off the front panel, place a cookie sheet or something under the washer to catch water and unscrew the knob on the right. This will allow you to clean the filter leading to the drain. This worked on ours.
Apr 22, 2009 | GE WCVH6260FWW
Clean light flashes constanly. Won't clear out to start new cycle
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jan 03, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
154 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
