Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
Initial Setup flashing on and off
The "Initial Setup" auto program screen keeps flashing on and off intermittantly, more and more frequently (no matter what you try to do to stop it), until the remote is disabled. Pushing buttons on TV itself only temporarily helps problem.
  • 13 more comments
  • sg54158 Nov 21, 2007
    Initial Setup constantly flashing on KV-32FS200.
    Remote and front panel buttons are locked out except, volume and input.
    I have tried:
    Powered on / off - unplugged from power.
    Let the Auto program run through it's sequence.
  • MASmith Nov 22, 2007
    Initial Setup flashes on an off;
    when I try to let the autoprogramming run through, it stops at a different channel everytime: channel 25, 74, 80, et cetera.
    tried new batteries in the remote
    powering on/off
    unplugging tv
    still not solved.
  • tuyere Dec 16, 2007
    I have the same problem as Sonya, I have had some luck by unpluging the television overnite, it will stop flashing for about 4 to 6 hours.
  • Anonymous Dec 21, 2007
    Initial stup keeps flashin on and off, now all the buttons are locked off including the frint panel on the TV
    Auto on and off keep blinking for me too. I haven't tried unplugging overnight, but I will give that a shot. I have run the auto set-up and that helps for a short time.
  • GOLF JESTER Dec 28, 2007
    EXACT SAME PROBLEM AS SONYA, EXCEPT THAT DISABLING REMOTE MAKES NO DIFFERENCE. UNPLUGGING TV DOESN'T WORK EITHER. BUT UNLIKE HER PROBLEM MY TV MAY ACTUALLY WORK FINE FOR SEVERAL DAYS AND THEN START ACTING UP AGAIN.
  • jaymz9mm Aug 03, 2008
    This has been happening for me over about 3 of the 4 years I've owned this TV. It seems to happen in bursts - it works fine for weeks, even months, then it freaks out. It gets to the point where I feel like it's messing with me. The initial setup will popup asking me to press channel up or down. Sometimes it goes away before my finger touches the remote. Sometimes it disappears right before I hit the channel button which is infuriating. I'll run the setup but it will flash again seconds later.
    I recommend giving it a swift smack on the top near the back, that seemed to fix it once ;) In all seriousness though, I feel like it has something to do with a lot of dust getting sucked into the back of it, and smacking it would probably knock that loose if that were the issue.
  • USGRANT Aug 04, 2008
    INITIAL SETUP BOX KEEPS APPEARING ON SCREEN. CAN NOT STOP IT FROM REAPPEARING. IS IT WORTH HAVING A SERVICE TECH LOOK AT IT OR JUST SCRAP IT AND GET ANOTHER BRAND TELEVISION? (DON'T WANT TO GO THROUGH THIS AGAN)
  • Anonymous Sep 10, 2008
    Same issue, initial set up keeps popping up, had tv for 5 years, just started acting up within last 3 months. Getting very frustated. Tried unplugging overnight, redoing set up etc. still having issues. Would not like to spend too much to repair, would rather put towards new tv. Have other sony products, never had any issues, this is a first with me and a Sont product. Emailed sony tech support, no use, they want you to call for technician to come out to look at or bring in.
  • RSFAN Sep 10, 2008
    INITIAL SET UP BOX KEEPS POPPING UP AT TIMES, WILL STAY OR OR FLASH ON/OFF. TRIED UNPLUGGING, CHECKING REMOTE, USED OTHER SONY REMOTE. GETTING VERY FRUSTRATING! T.V. IS 5 YEARS OLD, STARTED ACTING UP LAST 3 MONTHS. SONY STATES I WOULD HAVE TO CALL A SONY TECHNICIAN TO LOOK AT T.V OR BRING IN (NO WAY) TOO DAMN HEAVY. WOULD RATHER REPLACE THEN TO PUT A LOT INTO IT TO REPAIR. Have had a lot of sony products, 1st time with any issues.
  • Anonymous Oct 09, 2008
    I too have this problem. At first plugging/unplugging was successful, but not anymore.
    Sounds like a defect inherent in this Sony product. Perhaps Sony can be convinced to repair due to initially defective design?
  • jwarfi Dec 08, 2008
    I have the same problem. Frustrating. I tried changing batteries in remote, unplugging, running the setup, reconnecting cable. Nothing seems to work.
  • mocha655 Dec 14, 2008
    Same deal for me. I had an authorized Sony repair shop charge me $300 for a repair that only lasted 1 week. It's now back to the same "Initial Setup" screen again.
  • dgromes Mar 26, 2009
    Same problem, exactly as everyone else.
  • dgromes Mar 27, 2009
    I have the same problem, I contacted Sony on the web, they had me reset the TV, and so far I problem free, 1 hour. They said if that doesn't work, to unplugged the TV for 2 minutes.
Heh. I just gave my set the "Fonzie treatment" after I was convinced the initial setup notice was messing with me. The problem cleared right up. No joke.
Posted on Aug 05, 2008
  • jimdrebert
    jimdrebert May 19, 2012
    Actually, the problem seems to be a lack of maintenance. All electronic devices have vent holes for convection cooling. These allow dust to settle on the inner modules such as circuit boards which in turn can cause short circuits to take place. Even minor ones can create annoying faults like intermittent flashing messages, as in this case. The dust needs to be either blown or vacuumed out. If you have an air compressor, just blow through the vent holes on each side of the TV cover. This corrected the fault instantly for myself.
I have the same problem with my sony it takes about a 1/2 hr for the picture to come on and from then on it just constantly blinks off and on. At first i thought it was the cable and the cable came and sed right away its the tv. this happened b4 but it fixed itself, now they tell me its doing this b4 the tuner goes bad.
Posted on May 30, 2006
SOURCE:
How do I tune a sony trintron without a remote
Hello
You can autotune your Sony TV without a remote control. Fist connect it to an external antenna or cable whatever may be, to its antenna socket at the back side.
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
[1] Press POWER button on the TV to turn it on. The Initial Setup screen appears.
[2] Press CH+ button on the remote control or on the TV front panel to start Auto Program, or press CH-- button to exit.
The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
To perform Auto Program again
1 Press"MENU" button on the front panel of your TV.
2 Press "RIGHT ARROW button to highlight Channel Menu.
2 Press DOWN ARROW BUTTON to highlight CABLE or ANTENNA AND PRESS [+} to select.
4 Press UP arrow or DOWN arrow to highlight On or Off according to how you connected your TV. Press [+] to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select
5 Press DOWN arrow button to highlight Auto Program. Press [+]to search for channels
6 After Auto Program finishes, press MENU button to exit.
OK
Dec 18, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Initial Setup Screen
Have you ever cleaned the set front glass with windex or glass cleaner.Sometimes the fluid runs down before you can wipe and lands inside right on top of the push buttons that control ( CH,VOL, MENU, etc.) If this happens you can get this trouble. If you up to it take the cover off and look at the board just under the front edge of the crt. If you see green or grey residue you probably have to remove that corresponding TAC switch. You can just cut out and use the remote for that function.
Apr 07, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Magnavox ZV450MW8
Magnavox is made by Funai. Similiar problems in another piece of equipment made by them was solved by 1) Turning off DST in the clock, or/and 2)Turning off the clocks auto update feature, ie, go to manual clock adustment. Hope this helps.
Sep 17, 2008 | Philips Magnavox DVD/VCR Dual Player
KV-36FS200 WEGA Initial Setup Annoyance
hello my friends i beleive that you have some loose connections on the main board around the eprom
good luck
caypianan@yahoo.com
Aug 20, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Changing the time on my Motorola Razr V3 phone
Go to settings
--> Initial Setup
--> Time and date
--> Auto update off
Then you will find the time and date.
go to date use right soft key and change the date and similarly for the time.
Jul 28, 2008 | Motorola Mobility RAZR V3
Initial setup
This is commonly caused by the CRT going too weak, and the AKG circuits are switching off the bias to the CRT. This is part of the high voltage regulation protection.
Other causes, but are rare to cause this, are failures in the bias circuits, high voltage regulation (flyback assembly), and in the scan amplifiers.
With proper experience, reference to the service manual, and the proper set-up, it is possible to determine the causes of the failure, and service it. The cost of the parts will be rather expensive if you can still have access to them.
Jerry G.
Apr 04, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
1) Do a hard reset = leave unplugged for 12-24 hrs , then
try again.......................................
2) What does "until the remote is disabled" mean ??
Nov 09, 2007 | Sony KV-32V16 TV
Initial setup
First give it a hard reset. To do this you must unplug the power cord for at least 4 hours; then try again.  This will reset the internal programming and restore it to factory defaults settings. Unplugging for a shorter period of time may not do the trick.
If the hard reset does not solve the problem it has a defective eeprom OR a bad voltage regulator that feeds the controller IC/eeprom set.  In which case you will need a tv tech to dignose the exact fault and determine the defective parts. (There are over 100 parts associated with these functions).
Hope this helps.
Oct 20, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
1,643 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
