Zune Installation problems
I just bought a Zune today. Have been trying to install the setup program and keep recieving errors. I absolutely have no idea how to run this or fix this.
I, format my mp3 pleyer by windows. hellp me plz!
Posted on Sep 14, 2008
Zune free download
which os are you using depends on the of right ckick on the installation file select properties then click compatible and then you
click run program in compatiblity mode for and you choose the one that works for you
Jan 20, 2014 | ASUS Computers & Internet
Softwear Instalion
what problem are your experiencing?and what software are you trying to install?Please specify the problem and software so we can give you the solution//
Jun 27, 2011 | Computers & Internet
I can't install Zune Software
Are you running Windows? It will not work on a Linux System. (Not sure if it runs on a Mac)
Jul 29, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
TRYING TO INSTALL MY ZUNE MP3 80GB
You need to download the software from www.zune.com before connecting your zune. Follow the setup instructions. After installation you connect your zune to the PC and the software should automatically detect it and continue the setup and update process.
Oct 03, 2008 | Microsoft Zune JS8-00001 Digital Media...
Olympus Master 2 installion operation failed
I had this problem today when installing Olympus Studio 2. I turned my Spyware and Virus Protection off, and the program installed correctly.
Sep 20, 2008 | SiPix SC-3300 Digital Camera
Problem with intalling zune's software
Uninstall all zune software and download and install it again. Possibly a bad download.
Or run error check on your computer then try it again.
Go to my computer, right-click on C: - go to properties- then go to TOOLS tab. Click on Error check - make sure you have both boxe(s) checked to fix errors as they are found then hit start. You will have to restart your computer for this check to happen. Usually takes a a few hours, but recommended to do at least once every few months.
Hope this helps!
Aug 03, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune Downlaoding
What is your operating system? Windows Vista Im guessing
since you said you got a new laptop. What I did to install a old programs is just open my computer (Make sure disk is in drive) and right click the CD icon, Go down explore. Right click a icon that says install or setup. go down to properties. click the tab that says compatibility. Check mark "Run this program in compatibility mode for: And choose what that program is ment for. should say on the box that came with your CD. Like Designed for Windows XP. Hope this works...
Mar 23, 2008 | Computers & Internet
The contents of this file cannot be unpacked.The executable you are attempting to run has been corrupted.
When I try to install the software, I get an error message. The installation just quits. trnsp.gif Answer An installation error is defined as any issue or error that prevents the Setup program from fully completing the task. Installation errors can manifest themselves in several different ways. One common installation problem is the Setup program is interrupted with a message indicating some type of problem. Another type of installation error is when the Setup program simply disappears or doesn't complete for any reason. When Setup is interrupted with an error
Many installation issues will be accompanied with an error code and then an error message that identifies the problem. Because the camera software uses the Windows Installer, the exact definition of the problem can be obtained by looking up the error code on Microsoft's website. Two common errors are Error 1904 and Error 2711.
When Setup simply disappears or doesn't complete
Note: When installing software, administrative rights are needed to install all the files for camera software. If you are logged in as another user without administrative rights, the software may not install/function correctly.
First try booting clean. If you are using Windows XP, Windows Me, or Windows 98, click here for instructions on booting clean. If you are using Windows 2000, click here for instructions on booting clean. Once you have booted clean, then try to install the camera software.
Since booting Windows clean may disable CD-ROM support, we recommend you download the latest camera software for your camera and use the download file to install after you have booted clean.
All other installation issues
If you are unable to find a solution to the installation issue given the above information, please try the following suggestions. After each suggestion, try running the installation program again.
  1. Reinstall the Windows Installer. This Windows Installer engine can be downloaded from http://www.microsoft.com/downloads/release.asp?ReleaseID=17343
  2. Windows 2000 Only. Stop the Windows Installer service and reboot the machine. To do this:
    1. Right-click on My Computer
    2. Choose Manage
    3. Click on the plus (+) sign next to Services and Applications
    4. Click on Services
    5. On the right side on the pane, double-click on Window Installer
    6. Choose STOP
    7. Reboot the computer.
If the service was already stopped, try starting the service, then stopping the service and rebooting.
If following through on the specific instructions above do not resolve the issue, please try the following standard diagnostics:
  1. Try a different installation media. For example, if you are attempting to install the camera software via the CD, download and install the latest web release. If you are trying to install the web release, try the camera software CD. Please note, the latest software can be downloaded here.
  2. Run ScanDisk and Disk Defragmenter. Both of these utilities can be found in the Accessories program group of the Windows Start Menu.
  3. Search for and delete all TMP or CHK files.
    For Windows 98 and Windows Me Users:
    1. Click on "Start", "Find" and choose "Files or Folders".
    2. In the Named field, type *.TMP and click "Find Now"; delete all files found.
    3. Repeat this procedure with *.CHK.
    For Windows 2000 Users:
    1. Click "Start", "Search" and choose "For files or folders".
    2. In the Search field, type *.TMP and click "Search Now"; delete all files found.
    For Windows XP Users:
    1. Click "Start", "Search".
    2. In the "All or part of the file name" field, type *.TMP and click "Search;" delete all files found.
  4. Empty the TEMP directory; this folder may contain files that are interfering with the installation. To do this, use the following steps:
    1. Right-click on My Computer and choose Explore.
    2. Click on the plus (+) sign next to the C drive.
    3. Click on the plus (+) sign next to the Windows directory. (For Windows 2000, it is the WINNT directory.)
    4. Click on the plus (+) sign next to the Temp directory. The right side of Explorer will display the contents. Select all the files listed in the Temp folder and delete them.
  5. Reboot the system and try installing the software again.
Jan 21, 2008 | Logitech QuickCam Express Web Camera
51 people viewed this question
 Grubhead
Grubhead
