Question about Hotpoint 24 in. HDA1000Z Built-in Dishwasher
Cycle doesn't finish
Near the end of the cycle on the dishwaxher, when it is in the process of drying, the dishwasher stops. I was wondering why it is not running the full cycle.
  • 76 Answers
Its the timer you need a new one they arent hard to get just ring up your local apliance man and tell him (or her) you model number and brand and he will order it and fit it for you
Posted on Jun 22, 2008
Dishes still wet upon end of cycle
Check if the heater is working. This can be done by checking if the dishwasher has steam and dishes are warm when cycle is complete. Also check if the Rinse aid has not finished. Make sure the Rinse aid dosage is not at too low.
Jul 31, 2014 | Electrolux Dishwashers
Miele G863 SCVi All lights blink at the end and it doesn't dry
Check the web for,
2011-11-25_043923_g600__800_miele_service_manual.pdf
I found that PDF while working on fixing my Miele dishwasher and found it more helpful then most advice on the web.
Dec 30, 2012 | Miele Dishwashers
Maytag Model # MD87609AWB3 after rinse cycle it stops. I have to push button to finish drying cycle
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 24, 2011 | Maytag Dishwashers
Dish feels hot but not drying
sounds like your heating element is not working prtoperly or you are not washing in very hot water stop washer in middle of cycle and open it if steam come out hot steam be careful keep face away when you open itif not hot that could be the problem,A appliance serviceman once told me if water is hot enough and end of wash and rinse cycle not to run the dry cyvcle just open dryer a few inches and let the steam out Run hot water over a plate or a pot and set it in the drain tray in your sink notice how fast it dries itself while draining in the tray very hot water in a dish washer dopes the same good luck with this problem I hope my advice helps you oh yes one more thing always run the hot water till it get hot before you turn your dishwasher on
Dec 15, 2009 | Kenmore Dishwashers
Our ls12 ev03 dishwasher won't turn on, every time it is switched on it says'I'm still drying' with it's flashing light evn when it has not been programmed to do anything
It could be that it was opened before it had finished its last cycle. When you switch it on again, it wants to finish. You could either leave it on until the drying light goes off, or force it to finish the cycle. I'm not familiar with that model, but on mine I have a Stop option on the dial. On the machine I had before, I had to press two buttons together to force the end of cycle. Worth a try. Good luck.
Jan 06, 2009 | Dishwashers
Indesit DI620UK Dishwasher fault
If the dry cycle has a problem, check these:
Heating element
Drying fan
Thermostat
Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element.
Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat
Jul 19, 2008 | Dishwashers
Dishwasher problem
My dishwasher Indesit DI67S will not run on the number 1 cycle. It will fill and then when that programme finishes it jumps straight to the drying cycle missing all the rinses out etc. If on the number 2 programme it goes all the way through but then doesn't dry. I've also noticed that the water doesn't seem to be heating up much and certainly isn't drying. Is this the element or something else? Once its reached the drying cycle the light for this just flashes then I have a job to try and reset the machine. It can take endless attempts. Will switching the machine off at the mains solve anything or is it the element?
Thankyou
Oct 09, 2007 | Indesit 24 in. DI67 Free-standing...
Hotpoint 24 in. HDA1000Z Built-in Dishwasher Logo
141 people viewed this question
Top Hotpoint Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
