Question about ASUS M2A-VM (0610839149438) Motherboard
No video at all
Brand new m2a-vm installed with new power 650W and try to boot with onboard vga to monitor. I see and hear nothing. Would I get beeps from just the motherboard without a speaker attached? I unplugged everything internally to try to isolate the problem. I've remove the memory and only have the processor and m/b connected. I get nothing on my monitor. I tried reseting the bios but still nothing. anyone know what the default video is supposed to be? Is it supposed to be DVI? Thanks for any help.
  • 1 more comment
  • netmail2 Sep 14, 2008
    I have new machine that is a week old. Today when I turned it on I have nothing, no video, and the hd is not being read. I see that the dvd drive seems to be read. I do not have a boot disk. It seems as if the bios was fried or erased. Does anyone know where to get a boot disk or have any suggestions. I don't know how to reset the bios. Can Anyone help with that?
    Thanks
    Ken
  • embertr Sep 14, 2008
    Hi Turabsu
    This motherboard and cpu were put together at the computer shop where I purchased them both new. These were tested prior to my pickup. So this was the initial build when I arrived home I attached the 24pin and 4pin power, as per the motherboard manual. I have tried bringing up the system both with and without memory. Shouldn't I get some video output even without memory? or at least some beeps from the board if this is incorrect? The video I attach to is the onboard vga...is this correct for the bios default?
  • embertr Sep 17, 2008
    I took out the memory which, although it appeared to be of a supported type, was causing the issue. Better in the long run cause I upgrade to twice the amount of memory I originally had. This is what happens when you take a chance on used memory. Thanks everyone for your help.
  • 4 Answers
I had a similar issue after I upgraded the bios. It would clear when I would reset the CMOS using the instructions in the manual.
1.) You have to power the system off completely, making sure the light on the motherboard near where the power, hd light and other jumpers are, is off.
2.) Move the jumper to the 2-3 position and count to 10 slowly.
3.) Move the jumper back to the 1-2 position and power the computer back up.
You should get the default Asus splash screen and you can hit F2 to get into the setup to configure.
Now once I upgraded the BIOS to v1901, if I disabled the Asus splash screen I would get no video, so I had to leave that enabled. It isn't a real big hassle, I just like not using anything I don't have to.
I believe you can save it as a file and transfer it to a USB pen drive, or burn it to a CD.
Posted on Sep 20, 2008
I fixed mine today. I took out both the clock battery and the memory sticks at the same time. I waited a minute and put them back in. At that point I had video. I went into the bios and and reloaded the default setting. That took care of it. I am using the PC now.
Now I am trying to make a boot disk and a back up disk of the current bios. However, without a floppy drive and only a dvd writer I can't figure out how to do it.
Posted on Sep 14, 2008
    New Friend:
  • 68 Answers
First of all, I'd like to congratulate you for purchasing an M2A-VM motherboard. Yes, I mean it. It is one of the best motherboards available for te price band.
For getting display, you must have four components,
1. CPU (alongwith cooling fan)
2. Motherboard
3. RAM & of course
4. Power Supply (SMPS)
They must be connected properly and after attaching power supply unit you must ensure that a 24pin connector as well as a separate 4pin connector are connected to the Motherboard.
If the display doesn't come, the trouble may be with any of the four devices connected together. for advanced trouble shooting, please elaborate exactly when and how the problem has been generated. If the problem arised at the stage of initial assembly of the components, please check the components individually, if possible, replacing with another prouct of the same type.
If the problem arised on a running machine, please remove the RAMs from the slot, wipe the connectors of the RAM with a softe clean cloth and re-attach. If possible, you may wish to clean the RAM-slots on the board with a vacuum cleaner. In most cases, cleaning the RAMs do the needful.
Please try & reply.
  • Utsav Bhattacharya
    Utsav Bhattacharya Sep 14, 2008
    PS: Whenever you are fiddling with the hardware components of your PC, make sure it is turned off, else you may damage the system to the level beyond recovery.
    Utsav Bhattacharya Sep 16, 2008
    I've said already that for availing display, you must have four components,
    2. Motherboard
    3. RAM & of course
    connected and working perfectly.
    Let me try to troubleshoot for the four basic components.
    SMPS: If the CPU Cooling-fan is moving, the SMPS is working.
    CPU: In my experience, I've never found a boxed processor to be faulty.
    Motherboard: One of the main culprits of its own or for compatibility (with RAM) issues.
    RAM: The other culprit behind the failures.
    Let us limit the discussion regarding the RAM/Mobo compatibility. Please check for the frequency and compatiblity of your RAM with the motherboard. For this you may look into the motherboard manual or mobo manufaturer's website.
    PS: Yes, you should get long beeps at an interval of one second if your RAM is not connected to your Mobo (but may not get with all Mobos).
Sapphire 100293-2GL RADEON HD 5570 2GB DDR3 PCI Express 2 0 x16 HDCP Ready CrossFireX Support Video Video Card Logo Problem with the Sapphire 100293-2GL RADEON HD 5570 2GB DDR3 PCI Express 2 0 x16 HDCP...
I'm not sure I follow all of waht you are doing and /or did however, this card requires a minimum 400w power supply so, make sure you have the power. It may or may not be a factor. These cards can be tricky sometimes and I will start by saying, the install should have gone in this order: Install the card, boot your system and insert your CD. Start by downloading all drivers and "utilities" from CD. You will not get all the bells and whistles taht come with the card unless you get them from the CD or, possibly from Sapphire, and reboot. Check in "programs and features" and device manager to make sure you see your device. Once you have done this, you can then upgarde your drivers from respective sites, AMD, Sapphire, etc. You definately have to unisatall all prior software that has anything to do with ATI/AMD prior to installing new software.You can do a custom uninstall and install here. At his point, I would go into "programs and features" and unistall all ATI/AMD software and start over. Any software from existing cards as well. You also need to reboot after each unistall or install. Where are you getting this 1250 from? Is it from the CD? This is alot to swallow and if I am missing something let me know. I can help you with the upgrade of the VGA driver nut, lets see if this works and, taht I am on the right track. Contact me at "add a comment".
Dave
May 30, 2011 | Computers & Internet
P5p800-vm how to disable the onboard vga?
Put the new video card in, connect the monitor to it, boot in the BIOS and in there set the video card to Auto.
Sep 27, 2010 | ASUS P5P800-VM Motherboard
Motherboard cd lost
Find another computer with a CD-writer and Internet access.
Access the ASUS web-site. Search the site, for your specific motherboard. Select and download the device-drivers for VIDEO and NETWORK. Burn the downloaded files to a CD-R.
Move the CD-R disk to your computer, and install the device-drivers.
Jul 22, 2010 | ASUS P5RD1-VM LGA775 Motherboard - ATI...
After installing a brand new motherboard on first boot up it displayed a colored checkard screen and nothing else (also displayed same thing wen displayed on a VGA monitor)
I would try a secondary video card. If you have an extra one lying around install that and then if it doesn't work I would get the motherboard replaced. If the secondary video car works than you have two options. You can use the second video card or return your motherboard. It sound like you onboard video port does not work.
Nov 01, 2009 | HP Pavilion ze4145 Notebook
Installing a new pci-e video
For one, what you can do is put in your old card. Install the NEW drivers for your 9500GT and shutdown. Install new Graphics card. (I would double check for an "ATX" power input on the card.)(, im sure it needs one) and that should hopefully help, Also consult your motherboard booklet and your graphics card booklet to see if the card is compatible. Hope this helps!
Sep 10, 2009 | EliteGroup RS482-M (RS482M10A) Motherboard
No Display
hi....good day...>try to replace the ATX power supply...< thanks and good luck...^_^
May 29, 2009 | ASUS M2A-VM (0610839149438) Motherboard
ASUS M2A-VM Motherboard is registering my GForce 7800
Did you disable the onboard video?
Click Here for review and comments regarding your board and video card.
Jun 29, 2008 | ASUS M2A-VM (0610839149438) Motherboard
M2a-vm mother board
Hi auriaskate,
Currently you are using the onboard PCI video adapter. This graphics adapter uses you're system memory to function.
If there is a problem with you're system memory the beeps can lead one to think there is a problem with the onboard video.
You can not remove the onboard adapter so there may be a problem with you're system memory. (I doupt you're memory is bad) but on the other hand it might not be fully installed correctely. Power off the PC & unplug the power cord from the PC.
Please remove you're system memory & firmly reseat it.
Plug the power cord back in. Start the PC & listen for any beeps except the 1 normal beep known as P.O.S.T = Power on self test. Any beeps after that there is a problem with a device connected to the board.
You're Asus M2A-VM uses an Award bios. Click on the link below to see what Award beeps mean.
http://www.bioscentral.com/beepcodes/awardbeep.htm
Try the memory reseat & check. Let me know if this helped.
Mike
May 03, 2008 | ASUS M2A-VM (0610839149438) Motherboard
With dvi monitor goes black for 2 second then comes back intermittently
To what I understand. Dvi and vga is only applicable to a system or CPU. Sorry if I am wrong.
Tia.
Mar 29, 2008 | ViewSonic VX2025wm 20.1" LCD Monitor
My pc doesn't boot up
Did you have onboard video before? What is the video card? AGP8x, AGP4x, PCIe? If you had onboard video, you'll need to change the settings in the BIOS and disable the onboard video. You'll have to plug in at the onboard to access the BIOS.
Jul 23, 2007 | EliteGroup P4VMM2 Motherboard
ASUS M2A-VM (0610839149438) Motherboard Logo
256 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
