Question about Motorola Mobility RAZR V3m Cellular Phone
Won't power up
Razr v3m working fine then i open it up 3 minutes later and only the keypad lights are on, the screen is just black and the phone is unresponsive... now it's turned off but when i push the power button the keypad lights come on, then they shut off after about 2 seconds. any reason why?
    Problem Solver:
  • 19 Answers
Device is bad or needs reset, remove the battery while the device is on and count to 30 then re-apply battery and power on!
Posted on Sep 20, 2008
Mykeypad has frozen it turns on but i cannotput in my sim no.
Hi, your phone did not really seize, it is the keypad and it is connected to the screen of the phone and it's makes the screen display.
It is faulty and it needs to be replaced. it also controls the keypad operation.
When you change it, it will work out fine.
Take care.
May 26, 2010 | Motorola Mobility RAZR V3m Cellular Phone
2007 razr v3m can make calls but display screen
problem the solved.What makes the screen of a phone white is when the screen of the phone is damaged or the flex of the phone has cut.
The flex of the phone is attached to the keypad of the phone. They are joint together.
The flex of the phone can get weak due to opening and closing the phone all the time.It might be the flex is weak and it needs to be replaced.
If when replaced and still no display, then it's definitely going to be the screen of the phone that will need to be replaced.
Would advice to prevent more damage on the phone, you can give it to a mobile repairer to check it for you if you can not.
Take care.
Mar 20, 2010 | Motorola Mobility RAZR V3m Cellular Phone
Motorolr RAZR v3 screen and key pad went black
No solution really. Apparently it was a malfuction with my phone and so my carrier is replacing it. Whew! Thank you for trying to help.
Apr 08, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Phone works but the screen is black
i think your despaleyhas damagei mean cell,s lcd is crashed are broken
you have to goo you nearest mobile repairing shop.
thaknx for asking fixyha
Dec 15, 2008 | Motorola Mobility RAZR V3m Cellular Phone
RAZR V3m external screen light
personalise setting and you can change it to 60 secs
May 18, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Backlight display not working
Hey Dannes1956,
The Motorola V3m has a light sensor, which is visible just above the right soft key -- the key above the CLR button. This light sensor turns the backlight on when you press a key in the dark and disables the keypad backlight when you are in a well-lit area.
Your phone sounds like it's operating normally. I believe they disabled the option to activate or deactivate that feature.
Hope this helps,
Mar 17, 2008 | Motorola Mobility RAZR V3
Motorola V3m keypad problem
open the phone and clean the keypad connector really good
Dec 11, 2007 | Motorola Mobility RAZR V3
Motorola razr v3 (black) screen has white blank
Well i suggest that you take the case of your phone and have a look at your screen maybe some of the screws have gone missing or the screen has just worn itself out? . Note youll need a t6 or t7 torx screwdriver to do this , hope i helped
Oct 17, 2007 | Motorola Mobility RAZR V3
Keyboard only partly working
Um check and make sure that behind your keypad and see if there not blocked by dirt or something with your connection although your need tabs to check and see to get of your keypad but be carefull if you dont know what your doing and aint got insurance dont do it, i also think there is a solved problem about opening the keypad up. Hope that helps.
Feb 11, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3m Cellular Phone Logo
87 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
