Question about Initial 9510 Portable DVD Player with Screen
Dvd player won't play mini-DVD recorded on Canon DC100 camcorder
It flashes "loading" continuously, but never gets past that. The DVD plays on another DVD player, but skips. It plays perfectly from the camera to the TV. Other (e.g. commercially purchased)larger-size DVDs play fine.
3 Suggested Answers
silly girl
  • 513 Answers
SOURCE: dvd not loading
The general amateur fix, and one with surprisingly high success rates is to brush dust accumulated on the laser lens. This is assuming you get this with all disks, otherwise better not risk opening it. Plug it out, open the screws, open it up, if necessary remove another board covering the lens, and gently brush the dust off. Assemble back and hopefully you're solved. Anything else is for the lab(motor, lens assembly, focusing problems etc) Good luck
Posted on May 31, 2006
SOURCE: Won't load DVD for Initial IDM-7110
First check and see what is happening inside. Take something small and stick n the lock mech, which is the hold that a small part of you top to the player sticks in to tell the unit that it is closed. See if the lense light up and moves up and down and also see if it moves forward a bit and back to start position. If player does not do any of this then with fingers move lense down line abit to see if anything is obstruting path. You can move all the way down then place DVD in and try again
Posted on Aug 14, 2007
SOURCE: Will not play the entire DVD
your dvd reading head is out of sync open the lid hold the button that is pressed when the lid is close now with your finger move the head till the screen say's no disk that should be right to the center place a disk in and hold the button with your finger and notice a red light under the disk rotating pressing the next of fast forward button watch the light go to the outside of the disk . it should go right to the end without making a noise and read the entire disk if not keep moving the head till it does . your problem should be fixed there is no other reason to read only a part of the disk other then the disk it self is dirty.
Posted on Feb 05, 2009
0 characters
1 Points
When I try to load a DVD-R disk in DVD drive, I get a continuous Load message....
Hi again try another brand TDK R GOOD .cheers Hi a DVD-R IS A RECORDING disc if u have recorded on it . & u r trying to play it in another DVD with out ( FINALIZING ) it .u will get a continuous loading message hope this helps
Feb 01, 2016 | DVD & Blu-Ray Players
Playback on recorded disk
The DVD has burned incorrectly and the data has likely corrupted somewhat to the point where the DVD player/writer can't read it. You may be able to watch it on your computer with a DVD drive. Try saving it to your computer, then erasing the disc and trying to record something short to it and play it back - if it plays back, it's likely to have been a recording problem, however, if you get the same problem, it may be a dodgy disc, a faulty DVD player/writer, or a format problem. Try this, in order left to right. Copy DVD to PC -> Erase DVD -> Record on DVD from TV -> Play back If plays back Erase DVD -> Continue as normal If not Buy DVD-RW (emphasis on the minus) -> Try using that If that works continue as normal, otherwise... Return the DVD player/writer under warranty for repair/replacement.
Sep 17, 2007 | iLO DVDR04
Sony rdr dvd recorder / vcr combo.... I put a instructional video and the dvd won't go past the copy write warning.
have you checked the cd for deep scratches because i had a dirt bike game that did the same thing
Mar 05, 2013 | Sony RDR-VX525 DVD Recorder/VCR
I have a Panasonic DVD-RV31. Will this old unit
Depending on the video format such as AVI MP3, MP4. WMV. Most players will play mp3, wmv, and kodak formats. It should play. Does it play other burnt videos?
Aug 25, 2009 | DVD & Blu-Ray Players
The DVD s recorded from the hard drive won t read on other DVD players Am I missing a setting or what could the problem be. The DVD only play on the player I do the recording from namely the Model LG...
All dvds recorded on a diffrent player have to be finalised before they will play on a diffrent machine I think that you should find the finalise command in your menu ... hope this helps Reagrds Vortash
Apr 19, 2009 | LG RH266 Recorder
Dvd players are only made to last a couple of years(the laser goes bad).If you play scratched disc's it won't last that long.Hopefully you didn't pay alot for the player,and if you did then you can get the laser repaired but its expensive.I usually wait until the things go on sale and pick one up for 20 or 30 dollars.When the laser burns out after repeated use I just buy a new one because fixing them is more expensive and unless you want to continue having problems its easier to buy new.These guys that put alot of money in these units are just wasting their money.
Jan 18, 2009 | Sony RDR-GX300 DVD Recorder
Read mini dvd's
If it is capable of reading DVD-R or DVD+R look at your manual it will tell you what formats it will take.
Dec 17, 2008 | Sony DVP-NS55P DVD Player
DVD playing
You may have to buy a new player! because its not compatable ( you need one that plays DVD+ DVD- and dvd RW!) and the players that play these formats are no more then a regular dvd player (seen them for as low as $30.00 at wall mart!
Dec 10, 2008 | DVD & Blu-Ray Players
Dvd "unknown disc" message coming up
Have you tryed to use a lens cleaning disc yet. The laser lens on these players and recorders alike, must have the lens cleaned every oince in awhile. If that does not help, most likly you have a bad laser pickup assembly and you will need to replace the plaer as to have that repaiered, you could buy a new unit. Good Luck
Mar 23, 2007 | Daewoo DV-6T955B DVD Player/VCR
Initial 9510 Portable DVD Player with Screen Logo
27 people viewed this question
Top Initial DVD & Blu-Ray Players Experts
Jonathon summesfield
David Steeves
David Steeves
Level 1 Expert
Are you an Initial DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
