Question about Hitachi GD 7500 Internal DVD Drive
Asp.net how execute tc.exe in asp.net
    Scholar:
  • 40 Answers
You have 2 options:
Execute the Shell command Shell("c:\windows\tc.exe",vbNormalFocus).
or
System.Diagnostics.Procecss.Start("C:\windows\tc.exe")
you can also check the system.diagnostics.process.startinfo namespace to find more functionality.
I hope this helps.
Thank You, Raphael
Posted on Jan 24, 2009
Definition of asp.net & .net frame work
ASP.NET is a web application framework developed and marketed by Microsoft to allow programmers to build dynamic web sites, web applications and web services
The Microsoft .NET Framework is a software framework that can be installed on computers running Microsoft Windows operating systems. It includes a large library of coded solutions to common programming problems and a virtual machine that manages the execution of programs written specifically for the framework. The .NET framework supports multiple programming languages in a manner that allows language interoperability, whereby each language can utilize code written in other languages; in particular, the .NET library is available to all the programming languages that .NET encompasses. The .NET Framework is a Microsoft offering and is intended to be used by most new applications created for the Windows platform.
Jun 02, 2010 | Microsoft ASP.NET Programming with MS...
I'm using windows vista. petz 5 worked well at first but then suddenly i keep getting resource id = 1020 errors from the program, and it closes itself. what is this and what do i do?
Updates to the IIS metabase were aborted because IIS is either not installed or is disabled on this machine. To configure ASP.NUpdates to the IIS metabase were aborted because IIS is either not installed or is disabled on this machine. To configure ASP.NET to run in IIS please install or enable IIS and re-register ASP.NET using aspnet_regiis.exe /i. OR user@domain.com failed an operation on
Jul 08, 2009 | Ubi Soft Petz: Dogz 5 and Catz 5...
What is the use of asp.net?
ASP.NET is a free technology that allows anyone to create a modern web site.
Microsoft's site for ASP.NET
Mar 28, 2009 | Computers & Internet
Asp.Net
about the dynamic forms/pages, u can use sessions in asp.net C#, theyre very easy to use and try using commands like server.transfer and respond.redirect in ur code. for the connectivity thigee u asked, :) m sorry my friend u cant get it like a pan cake, u gotta study w3schools odbc connectivity in asp.net tag for this :P
Dec 21, 2008 | Microsoft ASP NET WEB MATRIX (583797)
Http/1.1 internal server error
If you are running two versions of ASP.NET, you may get HTTP:/1.1 500 Internal Server Error when creating a new Web project or opening an existing Web project in Visual Studio.
This problem may occur when IIS is not sure what version of ASP.NET to use or where to locate ASP.NET files. One of the following solutions should fix the problem.
Solution 1.
  1. Remove web.config file from inetpub/wwwroot directory
  2. Go to IIS, Right click on Default web site / All tasks / Check server extensions and let it run
  3. Reset IIS by right click on IIS or call iisreset from Run command
Solution 2.
  1. Install ASP.NET again using the following command from your Run command: C:WINNTMicrosoft.NETFrameworkv1.1.4322aspnet_regiis.exe
    Make sure to change the windows folder and ASP.NET version folder with the version what you want to install
  2. Reset IIS
Solution 3. Applies to Windows Server 2003
Note: This is a Microsoft KB article:
When you try to create a new Microsoft ASP.NET 1.1 application after you change the script mapping of the existing ASP.NET 1.1 Web application to ASP.NET 1.0 on a Microsoft Windows Server 2003-based computer, you may receive the following error message:
The Web server reported the following error when attempting to create or open the Web project located at the following URL: 'http://localhost/822319ev1'. 'HTTP/1.1 500 Internal Server Error'.
CAUSE
This issue occurs because Windows Server 2003 does not allow two versions of ASP.NET to run in the same application pool.
WORKAROUND
To work around the problem, do one of the following:
Restart the IIS before you create a new ASP.NET 1.1 application. At the command prompt type the following command: iisreset
OR -
Create an ASP.NET application in a separate application pool. Create the script-mapped application (ASP.NET 1.0) in a separate application pool -- for example, in the ScriptMapappPool application pool. Then, create a new ASP.NET 1.1 application in an application pool other than ScriptMapappPool. For more information about how to create an application pool, visit the following Microsoft Web site: Configuring Application Pools http://msdn.microsoft.com/en-us/library/1kdfe21k(VS.80).aspx
Dec 10, 2008 | Acer Aspire 5610 Notebook
Need Printer Driver install program
This is the driver page, your driver is second from the bottom:
http://kb.efficient.com/display/1/index.asp?c=&cpc=&cid=&cat=&catURL=&r=0.4291803
Here is the user's manual:
http://www.theusermanualsite.com/mdownloads/b2192e1a-c2e2-9ce4-9144-e217cecb131f.pdf
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 17, 2008 | Siemens SpeedStream 2614 Router (ss2614)
Hitachi GD 7500 Internal DVD Drive Logo
296 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
