Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Message: drainage blocked
The pipe in the back is not clogged, it is wide open. When we removed the cover for the pump in the front and open the valve, the water obviously drains out. However, when you put it back together and try to run it, it will go through a cycle and when it gets near the end of the cycle that when the message appears drainage blocked and won't drain.
  • 750 Answers
Scgawlik,
Happy to assist you,
You said,
The electronic type washers , can be unplugged and after 5 minutes restarted and the system is then rebooted. This resets the system and clears the codes !
If the drain is not blocked then you have a faulty sensor or a bad pump
Posted on Sep 14, 2008
I have a bosh washing machine WFO2462 and my problem is that: washing solution does not completely drain. I have cleaned the pump several times but the problem still remains and every time I want to use...
I believe that it's on the front bottom right side of the machine. Press the tab down and open the little door and you'll see a hose and a circular cover. You need to place a little towel on the floor and a shallow pan. Pull the drain hose out just about 6 inches and pull off the end plug. This will drain the remaining water in the washer. Put the cap back on the hose and tuck it back into place. Unscrew the round cover and pull which will be the filter. Should be clogged and rinse out the filter at the faucet and reinstall. That should do the trick.
Apr 21, 2017 | Washing Machines
I keep getting a E 4 signal. A Bosche rep told me the signal is due too much soap in the washer and can be cleaned out with softner. No luck. The cycle starts but stops in the middle with water left...
You can find this issue addressed on another site....
http://www0.epinions.com/review/pr-Bosch_WFMC_3200_Washing_Machine/content_158390980228
Due to popular request, here is more information on the E:04 problem, and some assorted tips:
If you get the E:04 error, he first thing to try is turning the washer off and back on again. You will more than likely have to begin the cycle over, but sometimes this will clear the message.
Since clogging up the drainage pipe, I have gotten that E:04 message when I've used too much laundry soap. I think that's the main reason people see that message. Just turn the washer off and start the cycle again WITHOUT adding any additional soap. I think the suds somehow make the washer think the drainage pipe is clogged.
The other thing that can happen is a genuine clog, like in the case I described in my review. The Bosch is excellently engineered to protect the pump from damage. There is a circular panel on the front of the washer that hides the drainage hose. Remove this panel (simple, but there is a knack to it) and you can pull the drainage hose out. Keep a bucket handy because the hose will be full of water. You may lose a little bit of skin off your hand during this process, and it's best if you can have the salesman demonstrate this procedure for you. That panel is not the easiest thing to remove. You have to reach in past some sharp metal to get to the drainage pipe. Wrap a towel around your hand and BE CAREFUL. It's definitely worth a shot if saving a service call is worth it to you (and clearing out clogs are NOT covered by the basic warranty). My service man assured me that removing this panel would not invalidate the warranty, but you may want to check with your dealer before you open up yours.
It's been about six months and I still adore my washer. I've found the Temp Boost setting is best for cotton towels, Delicates is great for, well, delicates, the Warm Permanent Press setting is great for jeans, and Cold Permanent Press great for most clothes. To avoid getting small items stuck between the glass and the rubber inner seal, do not overload the washer. If I try to wash too many socks, one will now and then end up in that small space. You can cram one big thing in the washer and it will still get clean (I regularly wash a bathroom carpet in there), but DO NOT cram it full of lots of little things. Follow the helpful loading instructions for each cycle.
Nov 04, 2010 | Bosch WFMC 3200 Front Load Washer
Rinse fault f18
F-18 means the pump is blocked. When the machine fails, there may be an "electrical" smell as the motor has laboured. This is normal. Clean on bottom right corner and you should be fine. Drain pipe clogged. Follow insrtuctions that came with machine to drain using the little pipe bottom right. Then unscrew & clean rotor. pull out wahing machine and check drainage pipe at back is not blocked. Unscrew the drainage pipe from the sink waste and clear out. Also enaure pipe is kept high off floor and is not too long. This will help drainage and prevent pump trying to pump waste water upwards. If the pump is too old or worn out then it needs to be replaced. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 28, 2010 | Bosch Exxcel WVT3250 Front Load Washer /...
The screen is flashing F3, what does this mean?
the drain pump of the washing machine is either got loose or its not working or the drain pump is blocked. Water outlet fault (Grey Hose) If F3 is flashing in the display, there is a problem with drainage. Check: • that no objects are stuck in the drainage hose outlet. • that the drainage pump is not blocked by foreign objects. Clean the pump (see the "CLEAN THE PUMP" chapter MENTIONED BELOW FOR MORE HELP). • that there are no kinks in the drainage hose. ------------------ CLEAN THE PUMP Checking the trap and drainage pump The washing machine has a trap, where coins, hairpins and the like can get caught. To clean the filter and drainage pump: 1. Make sure the machine is empty of water and that it is switched off at the mains. 2. Open the hatch for the drainage pump as shown in the illustration. 3. Drain out the water, into a bowl, for example, by unhooking the drainage hose from the pin inside the hatch. 4. Unscrew the cover anti-clockwise and remove. 5. Remove any foreign objects from the trap and pump assembly. Check to see that the pump blades, right at the back, will rotate. 6. Screw on the cover, replace the drainage hose on the hatch pin and close the hatch.
---------- This will help.please do rate the solution if helped.keep updated for further assistance.
Apr 29, 2010 | Asko W6021 Front Load Washer
Error code 20 Frigidare front washer won't spin water all over floor
error code 20 is a drainage issue,check the drainage pipe at the back of the machine if its kinked or blocked,also check the pump filter behind the front panel underneath the drum at the front of the machine if its clogged,unclogge. if after you unblock the drain pipe and clean the pump the problem still persists then the pump is bad,if you cant do it your self you can get a tech to clean it for you.hope this helps
Jan 10, 2010 | Frigidaire Washing Machines
Where is the filter onwma56
If your Hotpoint washer is a similar design to mine, you'll not have a user-accessible pump filter, so - presuming you're happy doing it and the machine is unplugged from the electricity of course - I rectified by the following:
1. Switched the machine to 'pump-out' and got rid of as much water as possible.
2. Unplugged and disconnected the pump-out pipe from the house drainage and drained off as much additional water as possible into a bowl by gravity.
3. Removed the panel at the bottom of the back of the washer to expose the pump, the bottom of the drum and the main washer motor.
4. On the right-hand side, you'll see the pump with the grey (in my case) drain pipe and a wide black rubber pipe connected directly to the bottom of the drum by an adjustable metal clip
5. The wide black pipe attached to the drum contains a ball-filter and is probably the source of your problems - undo the clip (watching for water of course; though none was spilt when I did it) - and lower it slightly to reveal the filter and - hopefully - the odd sock or so!
6. Clear the filter of the obstructions (the plastic ball can be lifted out by the way to aid doing this)
7. Make sure the ball is back in place and connect the wide black pipe back up to the bottom of the drum - ensure the clip is secure
8. Replace the machines back panel
9. Connect the drain pipe back up to the house drainage
10. Do a test wash !
Hope that helps - in practice it took about 10 minutes all together and is pretty easy.
Sep 23, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
I have f18 message and need bit of help with the solution
We had the same problem with opening the pump cover;
The solution was taking more of the washing machine apart because there was something blocking it from the inside and preventing it from opening.
Trying to force it may cause more damage so unplug everything and tip it backwards - no need to lie it flat, do it just enough so it is stable and doesn't fall over.
Take off the front bottom panel on the machine.
Undo the screw holding the filter housing to the front of the machine and lower it inside the machine, next unscrew the hoses and disconnect the wiring from it. This will allow you to pull the filter out completely and to open it up.
Clean the pump, check that there's nothing in the pipes/hoses and then put it all back together again in reverse order to which you took it apart in. (i.e. put together the last part you took apart and work backwards).
Sep 14, 2009 | Bosch Logixx WFT 2806 Front Load...
Frigidaire Front loading washer error codes E41 and E20
Hi
E20 is a drainage error. If there is water in the drum make sure the discharge pipe at the back of the machine is not kinked or blocked. You should also check the pump filter is not clogged - this is behind the front panel underneath the drum at the front of the machine.
E41 = Control board thinks the door switch is open. This points towards a faulty door switch on the machine.
Hope this helps. Please remember to rate my answer. Many thanks.
May 31, 2009 | Frigidaire ATF6000ES Front Load Washer
Need to remove drainage pipe, can't remove white plastic clip, is there a knack?
Remove power first! The pump is very easy to remove, ( unlocks from the base ) take the pump apart and check for foreign objects inside the pump assy. The power wires pull off and matters not which way they go back on. Also check the hoses to and from the drain pump for any  foreign objects. The pump is usually at the back right side ( looking at the washer from the front ).
May 07, 2009 | Hotpoint WF430 Front Load Washer
Water in filter ,pipe doesnt seemed blocked couldnt find anything undid it all
DEFINATELY A BLOCKAGE OR RESTRICTION ON THE DRAINAGE SIDE.DISCONNECT THE PIPING COMMING FROM THE DRUM TO THE DRAIN MOTOR. MAKE SURE ALL IS CLEAR. REMOVE PUMP AND OPEN PUMP HOUSING TO INSPECT.(BLADE COULD BE LOOSE ETC). FINALLY RUN WATER INTO DRAIN PIPE AND EXPELL WATER BY BLOWING HARD.IF BLOCKED, RECTIY. REASSEMBLE AND TRY AGAIN.
Jul 19, 2007 | Whirlpool AWM029 Front Load Washer
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
538 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
