We have purchased a 2nd hand "ROWA" television, ,model number "RTM686" which has stereo sound, when watching any program on most channels backgrond sound and music keeps fading in and out quite loudly above the normal audio level
In the end we sorted the problem ourselves, although the stereo sound now does not work at all,
we merely removed the video & audio leads from the rear of the set ( stereo sound) and moved them to the side which only emits a mono signal. although the sound is now only of the quality of a normal tv, we can at least enjoy watching a larger screen. An update in the near future to a large flat screen is on the cards.
Posted on Sep 30, 2008
Universal remote code for Rowa Television Model S21M62PF And Serial no. ECH101277B-110
Your universal remote probably has a code search feature that allows you to seek a code that will control your Rowa TV. If you search through all codes stored in the remote without success, you may have to try another universal remote.
Mar 08, 2015 | Universal Televison & Video
How to open rowa crt tv service mode
rowa tv service model no 14f 1nf
Jul 02, 2012 | Televison & Video
I have no volume on certain channels
The most common problem with no volume only on certain channels is the TV is programmed for 2nd Audio, also referred to as SAP which is a feature activated to transmit a second language such as Spanish. If you push your menu button on your remote control you can toggle over to Audio Menu. Then find the feature that allows you to adjust the sound for Mono, Stereo or 2nd Audio (SAP). Adjust the menu to highlight Stereo and that should cure your problem.
Hope this helps with your particular problem.
Dec 05, 2010 | Philips Magnavox 42MF521D/37 Television
2nd hand tv. don't have remote. tv screen reads
You can get the remote for your model at www.tvrepairworld.com if you dont see it listed call them or send a email with your model number. they have thousands of remotes available but only list a few.
Jan 09, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
The speakers in my new 2nd hand car won't play
if one speaker in car is shorted or bad.It will cause the whole system to mute .You may need to have someone to disconnect one speaker at a time or pull out radio.Some systems have a seperate amp in rear of car .Check fuse for that amp//goodluck
Jul 30, 2009 | Car Audio & Video
Using my universal remote contol,lost sound on 2 TV channels
The solution is to change the audio input from SAP (secondary audio programming - default on TV sets sold in Canada) to Stereo or Mono. Your remote will need to be able to access the "Menu" settings screen for your television set.
May 07, 2009 | Samsung TV Remote Control
Second hand car stereo no code
The radio will have to be removed from the car dashboard
.Then please quote the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
Also quote the MAKE of CAR it is fitted into.
Please note: Not all stereo codes can be calculated from the Serial Number
Mar 17, 2009 | Sony WX-C570 CD Changer
No sound from daewoo 42" plasma
This particular model doesn't have internal speakers. It has two removable external speakers mounted on the left and right side of the tv. If you didn't get the external speakers with the tv, you won't have sound unless you use a surround sound setup.
May 23, 2008 | Daewoo DTS42 42 in. HD-Ready Plasma...
Background sounds
go to the sound menu and shut off the BTSC-sound, SRS Panoramic 3D sound and place it into stereo.
Jan 20, 2008 | Polaroid FLM-3201 Television
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
