Kenmore HE2 Front Load Washer
My wife lost her wedding rings yesterday. We found her wedding band in our HE2 front load washer, but not her engagement ring. I checked the dryer (the HE2 dryer that matches the washer), but no ring. Looking at the washer, it seems very possible the ring could have slipped through the gap between the bellows and drum.
If the ring did slip through that gap, is it possible for the ring to be still inside the washing machine. Our fear is that the ring got sucked through the drain hose and is lost for good. Is there any place I can easily check to look for the ring. I've scheduled a Sears repairman to come out next week, but I'd rather get it myself and save money on the repair bill. We haven't done a load of laundry since the ring was lost.
  • 2 more comments
  • dawk20 Sep 14, 2008
    I checked the lint filter in the dryer and shined a flahlight into the filter area, but no sign of the ring.
    You mentioned a lint filter. I assumed you meant the lint filter in the dryer, but your second post makes it sound as if there is a lint filter in the washer. If there is, I'm not sure where it would be on the washer. I checked my manual and didn't see a lint trap mentioned.
    After reading posts about the pump under the washer, I pulled off the bottom kickplate to get to the drain plug. I unscrewed the plug and found a small collection of coins, but no ring. I guess the good thing is it looked as if it would be next to impossible for the ring to pass through the plastic filter to the drain hose. I ran about a gallon of water into the washer and unscrewed the cap a second time, but no ring came out. I'm hopinig there is a chance it still lies in the drum. Maybe running it a few times will get it to the pump filter.
    Oldgold, thank you for mentioning the lint trap in the washer. After my last post, I ran water into the machine several times but still, no ring. I noticed the tube leading from the drum to the trap was very large and made of a very pliable rubber. The tube also had deep ridges on its sides. I noticed two pennies were stuck in the ridges near the end of tube. Thinking there was a chance the ring may lodged in the ridges, I began pushing on the sides of ridges. Sure enough, the ring was stuck in the ridges of the soft rubber. It finally rolled out.
    My wife ran out to the grocery store to see if anyone found her ring there. I can't wait until she gets home to tell her it was in the washing machine! Thank you again. Now I'll be sure to clean out the trap monthly to be sure there are no loose coins in there.
Thanks so much for these 2 posts. I had thought I lost my ring in my Kenmore He2 as well, but didn't know where it would be able to fit through to get out of the drum. After 2 months of hoping it would turn up, and many wash cycles later, we checked the drain plug & there it was!
Posted on Feb 10, 2010
7/29/09 I had the similar problem. I accidently left my ring in my pants while washing them in our Kenmore He2 Plus front load washer. Thanks to this posting, I was able to find my ring. To begin I couldn't find my manual and it's not any easy task to find it online.
Instead of calling the repairman, I decided to take it step by step before deciding to call. I searched inside and everywhere possible that I could without using a wrench or any kind of tool. I then saw this posting and read the part about opening up the bottom kickplate where the drain plug is located.
Bingo!!! The kick plate is in front of the washer below the door. There are 3 screws located at the very bottom. You can either have someone lift back so you can get to the screws or you can do what I did, which was to use a thin tool box to hold it up. Once you get the 3 screws off the bottom cover or kickplate basically comes off by itself. There you will see the big drain plug. The plug is very tight, so it might take you awhile to open it up. Make sure you have a small bucket to catch the water that might come out, which I did. Lucky for me, I forgot to drain my washer before I started all of this. When I removed the plug I found that it had a little tray attached to catch anything that might plug the hoses up. There it was, my ring was there with a dime. Looking at my ring closely, I could see the damage the washer caused to it. It had dents and scratches, bottom line I did not lose it and my wife is not mad at me.
After finding the ring, I plugged the drain back up. Replaced the cover and 3 screws and that was it. Problem solved. No need for a repairman. Also, make sure you unplug the power.
Posted on Jul 30, 2009
    Scholar:
  • 83 Answers
Have you checked the Lint Filter?
Posted on Sep 14, 2008
  • Richard Florey Sep 14, 2008
    Does the machine outlet hose flush the water down the plug hole of the sink or into an overflow hole in the corner of the sink? The plug hole has small restrictive holes meaning the ring would not get past the plug hole and would still be in the machine.
    If it is into the overflow hole then there is the risk that it has gone further. I was hoping that the lint filter would stop it passing meaning it is still in the machine. The drain pipe would then go to the outlet pump from the drum as is the only outlet it could pass through. Maybe it is caught in the pump. I would recommend that the repairman pull that apart.
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
Lost engagement ring in washer dryer
Check the hoses at the base of the water pump.They could stil be there.
Jan 06, 2014 | Candy Washing Machines
HE2 Plus Front Load Washer: It vibrates and makes alot of noise....
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 05, 2010 | Kenmore HE2 Plus Front Load Washer
Lost my diamond wedding ring in washer. Where could it get stuck? My husband took the front off the washer, and opened the drain filter..nothing :( Could it get caught in the hose?
it could get caught in the water pump or between the water pump and hose outlet, it could be caught between the agitator and the washing machine tub or it could be in the **** Trap in the wall, since it's heavier than water it would be the most likely place. and if not there then the over fill tub on the sides.
Jun 13, 2009 | Kenmore Elite 45986 Front Load Washer
My kenmore he2 plus washer door gasket is loose.
it goes on the groove in the gasket at the door , the side view of the gasket would be a V, it goes right in the middle. make sure the gasket is first snug on the metal frame groove. the spring is very tight, start at top then work down, use a flat screwdriver to pry it in at bottom. it may help to wet the gasket
Apr 27, 2009 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
1,589 people viewed this question
Top Washing Machines Experts
