Question about Kenmore 15516 Mechanical Sewing Machine
Needle thread tangling around bobbin
You advised someone about solving this problem by telling them to adjust the bobbin tension. I have a different machine (Kenmore 15516) with the same problem, but can't figure how to adjust the bobbin tension. Can you help?
  • RenRod Sep 15, 2008
    Thank you! I adjusted the tension on the bobbin, but, unfortunately, it didn't solve my problem. Thanks for the suggestion and the information!
    To address my needle thread tangling (horribly) in the bobbin compartment, I rethreaded the bobbin. I cleaned the bobbin and the feeder feet, I changed the bobbin and the thread. I changed the tension on the needle thread and the bobbin thread. NO FIX! Then, I changed the needle - the problem was fixed instantly. I sewed awhile and then put the original needle back in. No problem. I think perhaps that the problem is being caused by the needle getting out of alignment somehow during sewing. If you are having the same issue, try it. It can't hurt!
  • pinkcassie Sep 30, 2008
    My machine will work fine until i run out of bobbin thread and have to pull out the knob to refill the bobbin. When i get the machine threaded back up and start to sew the thread gets all bunched and tangled in the bobbin holder. If I loead my machine in my truck and go for a drive, when i get home it works again. Could somebody help, maybe i am hitting something when i change it back from bobbin winding to sewing and i don't realize it.
  • 56 Answers
There should be a screw on the side of the bobbin also a screw on the bobbin holder so that you can ajust so you can time the mechin
Posted on Sep 15, 2008
  • jwag500 Feb 13, 2011
    Weird and inexplicable, but it worked. I was have thread tangling in bobbin chamber. I removed the needle, then put it back in, and the problem resolved itself!
What is happening when I sew and 3 threads come out of the bobbin? Or when it just freezes up and I can't get the needle to go up or down?
basically the problem comes from incorrect thread tensions
the main thread responsible is the needle thread as the tension is far too loose
tighten up that tension and it makes the needle on the up stroke pull the thread around the bobbin carrier and collects the bobbin thread and pulls it up to the material
with the needle thread too loose the needle thread is wrapped around the bobbin carrier again giving you the 3 threads ( 2 needle threads and 1 bobbin thread and the tangle jams the bobbin movement
Sep 29, 2016 | Sewing Machines
How can I prevent bobbin thread from bunching up and tangling?
First thing to do: install a brand new needle and clean the lint/dust from the feed dogs and bobbin area. Make sure you are using the right needle and thread for the fabric being sewn.
All About Needles
Second thing: remove all the thread from the machine. RAISE the presser foot and rethread from the beginning making sure that it is threaded correctly through every thread guide (consult the owner's manual). And verify that the bobbin is loaded and threaded in the bobbincase properly.
AVOID using old, fuzzy, and bargain bin threads.
Set the upper tension to the midway point between the high & low number (this is the factory standard although every machine may slightly differ). Now perform a new stitch test.
If the upper thread is creating a thread mess under the fabric, the upper tension is too loose. Tighten it.
If the bobbin thread is coming up to the top of the fabric, loosen the upper thread and retest. Sometimes the upper thread tension is not enough to prevent the bobbin thread from coming up. In that case, the bobbin tension may need to be tightened. (Search the internet for instructions for adjusting the bobbin tension. NOTE: bobbin tension adjustments should be done in micro-increments as a small adjustment will make a big difference in the result. Be sure to test after each adjustment.)
The tension is correct when the upper thread and bobbin thread meet and cross in the middle of the fabric. This will change whenever fabric, needle & thread are changed, so a sewist needs to be comfortable with regularly making upper thread adjustments.
One other thing to try is pull the bobbin thread up through the fabric before stitching and gently holding the thread tails when taking the first couple of stitches.
https://www.youtube.com/watch?v=caPzulMMlMU
Jan 25, 2016 | Sewing Machines
I've had my singer simple 3116 for a number of yrs. For last few weeks I've had problems with the bobbin stitch, it sews fine for a few seconds then jumps & the stitches are a tangled jumbled mess , I've...
You may have a burr from an errant needle strike on your bobbin case or even on the bobbin itself. Check to see if there are any rough spots on or around the bobbin.
If you don't find anything, you may want to remove the bobbin assembly and clean the lint out from the lower assembly. Sometimes the smallest amount of lint or pieces of thread can cause problems with the bobbin.
You didn't mention if the tangled thread happens on the top or the bottom of the fabric. If it is on top, then it is a bobbin issue. If it is on the bottom, then it is an upper tension/thread issue.
Try removing the bobbin, thread, and needle. Rethread the entire machine using a different bobbin and a new needle. This may solve your problem. Good luck!
Jul 07, 2014 | Sewing Machines
Brother innov-is cs8080. Tangles underneath all the time Sometimes top thread wraps around the shuttle. Will not move forward. Have cleaned shuttle and changed spool but still not difference. Could...
Check your bobbin threading tension (is bobbin thread loose on bobbin?); check needle thread tension (does it snag or jump when feeding?)
Be sure bobbin case, etc. is properly installed in shuttle housing.
Aug 29, 2013 | Brother Sewing Machines
Thread tangles underside
First let's make sure you threaded the upper thread properly. It MUST be threaded with the presser foot in the UP position. (this opens the tensions discs slightly and allows the thread to be seated correctly) Sew a test seem on the same type of fabric. If it is now sewing ok... you are good to go. If you still have some problems. Make sure you grasp the threads as you start a seam. Did that solve it? If not.. you'll have to adjust your top tension slowly testing the stitch after each adjustment... tighten the tension until it no longer nests underneath.
Good luck.
Aug 20, 2012 | Singer Sewing Machines
My bobin thread gets tangled and loose
have you checked the tension? In the older machines you could adjust the thread tension by tightening the screw on the side of the bobin case. With alot of the newer machines you have to lift out the bobbin and then lift out the casing to adjust the screw on the underside of the casing.
Oct 28, 2010 | Sewing Machines
Burnette 65 bobbin tangling can't adjust thread tension
Have you replaced the needle with a new one? Your needle may be bent or in wrong, or the wrong size. You may have a bad needle. Check that the upper thread path is running freely and is not tangled or wrapped around anything. Make sure that the bobbin is unwinding in the correct direction as well, most bobbins, this is clockwise as the bobbin faces you. If you are using inexpensive thread, it could be the thread that is the culprit. Uneven thread in the needle will not flow through the needle properly, and cause bunching as well. Save it for the bobbin, and use good thread in the top.
Jul 16, 2009 | Bernina Bernette 75
Needle thread breaks while quilting on machine frame
My friend and I both have the Juki 98Q but on different frames - we were both having problems (needles breaking, thread getting tangled) we removed the thin metal thing inside the bobbin case and have had no problems since (over a year now!).
Nov 01, 2008 | Juki TL-98Q
Thread breaking.
Rethread the machine following these directions:
all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Remove the bobbin case and bobbin. Pull on the bobbin thread to make sure it doesn't pull too hard. It should have some tension on it but not a lot. Insert the bobbin and bobbin case into the hook assembly and pull on the bobbin thread again.The tension should still be about the same. If it is tight, you need to look at the bottom of the pin that the bobbin case sits on and see if there are any threads looped around it. If there are , you need to remove them.
Hold the top thread , turn the hand wheel and see if the thread is catching someplace around the hook assembly. If it pulls the thread up easily, put some fabric in it and see how it works.
Make sure the thread is through the take up lever.
sewman7
Sewman7
Jul 09, 2008 | Euro-Pro Fast and Easy 420 Mechanical...
Bobbin tangles up thread and jams machine
Hi, Is it your bobbin thread or the top thread wrapping around the bobbin. I just got a used PE150. The top thread keeps wrapping around the bobbin. It is not picking up the bobbin thread. Did you find a solution for your problem?
katfou
Jan 30, 2008 | Brother XR-65t Mechanical Sewing Machine
Kenmore 15516 Mechanical Sewing Machine Logo
377 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
