Lenovo IdeaPad Z560 Notebook Logo
ashim aggarwal Posted on Sep 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Downloaded ppt from microsoft site,started setup....setup iis not working and task manager is not working ,,and win 7 does not shut down........i have to hibernate everytime
Anonymous
Level 2:
Sergeant:
  • Expert 170 Answers
  • Posted on Sep 10, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
170
Questions
Helped
23256
Points
516
Please install a antivrus and scan your system and try again
When Win Zip started was going to buy it but it did not work on Windows 10 and all of a sudden they overtook the whole screen and I cannot close or see anything
Press CTRL and ALT and DELete together in select task manager. Select Winzip from running applications and select end task
Then install 7zip
https://www.7-zip.org/download.html
How to set up a FTP server in Windows 7
You can use MS products (FTP Service and IIS Management Console) or a third party software (FileZilla.)
To use MS, you have to enable FTP under "Add Features" in Programs and IIS service.
Then you have to configure IIS:
  1. Run Administrative Tools -> Internet Information Services (IIS) Manager
  2. Expand the local machine
  3. Right-click "Sites" and add "FTP Site"
  4. Call it "Default FTP Site" and create the path like "C:\inetpub\ftproot"
  5. click "Next"
  6. Enable Start FTP site automatically, select Allow SSL
  7. click "Next"
  8. Enable Anonymous Authentication
  9. click "Finish"
1helpful
Hi i purchased amd athlon x3 450 and only one core is showed in task manager,performance tab
Hi.
If your system is running XP then there is a file from Microsoft that you can download that may fix the problem. Remember once you have installed the fix you have to restart the computer for any changes to take effect.
Click on the link below for the download.
http://www.microsoft.com/downloads/en/details.aspx?FamilyId=C2AB5A48-8240-4934-BBD8-34FB8A0FCE3B&displaylang=en
If your sysem is not XP and you are using Vista or Win 7 then don't download this fix as it will not work. Instead right click on Computer and select Properties from the sub menu. When the properties window comes up have a look at the processor under System and see if it shows how many cores the processor is currently showing.
Please let me know how you get on.
Good luck.
I have now Win XP (SP2) on my HP ProBook 6555b. It dont wona shut down!
Hold down the Ctrl key and the Alt key then press the Del key. This will then bring up the Task Manager. Then click on Shut Down then click Turn Off.
This will then shut down your laptop properly.
2helpful
3answers
CANT GET IT WORKING ON WINDOWS 7
Un-install the drivers installed on the PC and remove the web-cam, Now connect to the microsoft official site and download the legal driver for the VX 3000 applicable for Windows 7. Install and connect the web-cam which will be detected and installed.
4answers
Please give me site for free down load converter for microsoft save as PDF or XPS add in for microsoft ofice 2007
There are quite a few free PDF creator on the Internet to choose from.
I suggest you Google search for these programs.
Cute PDF is one I recommend, try this WEB site -
http://www.cutepdf.com/products/cutepdf/writer.asp
1helpful
How to activate task manager on my pc
It can be done easily by editing the registry. I will try to explain in detail. Follow these steps
1. Check that your PC is virus free. Install Antivirus program if required.
2. Regisry is enabled. Goto run command from start menu OR Press Win key+R and type 'regedit'. It would show up registry.
3. If registry is enabled you can edit it.
4. Open notepad and paste the following four lines
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System]
"DisableTaskMgr"=dword:00000000
"DisableRegistryTools"=dword:00000000
5. TYPE the file name ENABLETASKMANAGER.REG
6. Choose 'all files' option from 'Save as type'
7. Now you should have a registry editing patch. Please note that its extension is .reg
8. Double click the patch to add it to registry and task manager would be enabled.
9. Alternatively, you can download PROCESS EXPLORER, whichis a replacement of task manager from internet. It works even if the taskmanager is disabled.
Hope this helps. Let me know if you need any further clarification/ help
CreativeTECH
I am having AVG Pro. on my Vista. Now I con't use
Go to AVG's homepage and look for a removal tool. Uninstall the software and download Microsoft Security Essentials...It's free and perpetual. You may also consider upgrading to Win 7 or downgrading to XP. Vista is the reason many folks are back to XP and Microsoft's reason for creating Win 7.
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
