Question about Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor
Degraded graphic images
My flat panel monitor has begun having problems displaying pictures. The pictures, my own files, and those in ads looked ragged and appear to have small "blocks" of color that are visible rather than being in-focus and sharply defined. I've used the monitor controls to reset the monitor to its original factory settings. That didn't help. I've looked to see if there are any other drivers available, but I've only had the unit about 4 months and I've not found any. Any suggestions as to why the monitor is suddenly not displaying pictures correctly? Thanks.
  • 3 Answers
Sounds like your logic board is bad.
Posted on Jan 29, 2008
Sond ok back lit ok but no display
can you connect to a tv or another monitor???try this see if works;if not the problem is with the graphics if you can get picture on a tv monitor check the device manager..(right clik start control panel-device manager)if any items have a yellow triangle there is a problem.
Dec 12, 2013 | Sony KLV32S400A 32 in. LCD TV
Images are too big for monitor
You need a picture editing software: eg Photoshop, or Microsoft Office picture manager to resize of the pictures. make a backup of the files before modify them
Oct 05, 2012 | HP Excellent Vs19e 19" Flat Panel Lcd...
What is causing my TV to display inverted colors, like a negative photograph? The picture of my LN46A530 LCD TV has degraded an it looks like if I was seeing a negative photo.
TV display inverted colors, like a negative photograph because defective panel. Mostly from T-con board. Replace T-con board.
I hope that will solve your problem.
Thanks.
Mar 03, 2011 | Samsung LN46A530 46 in. LCD HDTV
My crt monitor has a white ghost image to the right. It looks like JPEG artifacts. I've replaced the monitor and I've tried another graphics card, but it's still there. The PC is an HP d325.
A ghost on your screen is usually caused by a second or reflection of the same image getting into your monitor, and the space between the real image ant the ghost is the delay in time or extra distance the second image travels before it is displayed on your screen. It is usually caused by a defective video cable or a cable longer than usual like 8 feet or more. Also is your monitor plugged into the same outlet as the computer, and is the case on your computer as all are possible reasons for your problem. Some times adding a ground wire from monitor to computer can correct problem. This can be a problem that takes some real detective work to find, and all I can do is suggest some possible causes.
Oct 09, 2009 | Samtron 76df 17" CRT Monitor
DISPLAY ALL SQUEEZED APART
Hi there.
You need to set the screen resolution.
Go to the control panel and chose display settings, you can set a resolution you are comfortable with there.
Good luck and thanks for using FixYa!!
Apr 22, 2009 | Computers & Internet
Getting lines across the monitor screen
It may have one of reasons:
1. "Dirty" supplying voltage in the monitor - check all electrolytic capacitor.
2. Bad controller chip - check if it gets extremely hot when working, also you may see darkened area on other side of the PCB where that chip is located.
3. Loosed connection between controller PCB and the display itself - disconnect the cable and clean contacts, especially of blade connector on display side, check if there are some overpressed contacts.
Mar 07, 2009 | Samsung SyncMaster 910T-Black 19" LCD Flat...
Loud pop/crackle and now picture is marbled...
The picture being displayed might just be the 480p resolution and it looks faded at times.
Aug 19, 2008 | Samsung SPN4235 42 in. Plasma HDTV
1901fp display problems
The problem can be with your browser missing the programs that support visualisation of pictures. Try installing micromedia flash player and any prompts that you may get from the visited websites
thnx
Jul 29, 2008 | Dell UltraSharp 1901FP 19" Flat Panel LCD...
Open Questions:
Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor Logo
81 people viewed this question
Clive
Clive
Alun Cox
