Question about Hitachi 53UDX10B 53" Rear Projection Television
Blue and yellow out of alinement
I have blue and yellow lines and all the people have blue out line around their heads. The picture has a blue bow at the top and up from the bottom. It worked fine last night. Please help.
hbeakes@ec.rr.com
  • Kekoa Oct 16, 2008
    Same problem as described.
    Genius:
  • 1,139 Answers
Hello hbeakes,
I posted this before, I matches what you are requesting , so here goes:
It sounds like you convergence amplifiers have malfunctioned. If possible can you post a picture of what is happening. Again by the description you gave it sounds like the convergence amplifiers.
If you go to a shop the cost will about $400 - $500 (includes parts and labor).
If you do it yourself the cost will be about $25.00 - $50.00 (includes parts labor is free)
If you choose to do this yourself, here are the basic instructions:
1. Unplug the TV set
2. Take the rear bottom panel off
3. look for a large heat sink with two large black ICs (STK392-110) (6 sided components but rectangular in shape) on it, and remove the board the ICs are on from the TV set.
4. Unsolder the components using a soldering iron and a suction solder remover.
5. disconnect the components (ICs) from the heat sink
6. Unsolder all of the bias resistors and replace them with the proper values (usually 220, 150, 3.3, 2.2, and 3.9 ohms)
7. install the new ICs (STK392-110)
8. solder all connections IC and bias resistors
9. Inspect for shorts
10. reinstall circuit board
11. Plug the TV set in and turn it on.
I hope this helps
Thank you,
Shuttle83
Posted on Oct 03, 2008
Jvc manual
Well there is no yellow, there is only red, blue and green, Blue is the set line the other 2 need to be aligned to. If blue is bent or out of alignment then there is a problem with some internal chips that would require a good deal of soldering skill
Jan 03, 2012 | JVC AV-48WP30 48" Rear Projection...
Convergence Adjust
It means probably one of the two convergence ICs has blown
Jul 13, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Color problem with Toshiba
tv is on it's 'hospice' end of life routine..unless you want to gut it completely, and replace all the electronics..
Apr 19, 2008 | Televison & Video
Bowed picture. Red,green, & blue lines around picture
Go to menu setup look for Convergence,see no Convergence.U have an open Fuse(FL231)located right side of the Flyback Transformer.
There is 3 in a roll small brown rectangle looking caps,but they are fuses,it the middle one is dead.
Aug 23, 2009 | Televison & Video
Alinement of blue cross with red and yellow.
you will need to call someone in to realign the picture...
Feb 16, 2009 | Pioneer SD-532HD5 53" Rear Projection...
I have a 53 in. sony projection tv,. bowed picture tubes?!?
Replace Both STK convergence ICs will have part number on them STK392-560 use same part number on your STKs. Also around ICs ck pico fuses 5/6amps they are green or yellow.
Jan 07, 2009 | RCA P56930BL 56" Rear Projection...
Blue horizontal line
Hi Brian,
Sounds as though you have a bad convergence chip ( there are two convergence chips on the board ). I suggest you change both and apply lots of heat silacon grease. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | JVC AV-56WP30 56" Rear Projection...
Bowing in the middle like an hour glass
OUCH!!!! Don't kick me...would be my response if I were your TV
Convergence amps problem.
If it works after a kick I'd say poor solder joints on the convergence amp leads
Dec 17, 2006 | Zenith IQB50M90W 50" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
