Question about Olympus Camedia C-770 Digital Camera
My Flash suddenly will not pop up.
Suddenly my flash will not pop up. I hadn't used the camera for a couple months. Got it out, charged the batteries, and while checking it out, noticed the Flash wouldn't pop up. I haven't dropped it, or been rough handling it. Very strange indeed. I have used it very infrequently over the past 2 years since I bought it. Can someone help please??? Thanks, RandyT
  • Randy TThomas May 29, 2006
    My Flash will not pop up.
  • Randy TThomas May 30, 2006
    Thanks BMWRIDER, your solution worked. Apparently, the Flash was jambed, 'just-a-bit-, because it fits so tightly
    when closed. I used a thin bladed scalpel, applying just a little upward pressure under the left front edge, while pushing on the flash button, and BINGO it poped up. And
    has ever since.
    Thanks Again,
    RandyT
  • 215 Answers
Sorry but I have a 770 in front of me and it definitely doesn't have an auto popup flash the flash release button is on the rear towards the top and adjacent to the button marked with the flash sign and key. It's strictly manual. If this Button isn't working it means the mechanism is broken. I've had plenty of cameras where the flash wouldn't close but never one which wouldn't open. Try pushing the button and gently pry the flash open with a fine bladed screwdriver or something similar. If it won't open with a little gentle coaxing either strip the covers off and have a look or take it to a repair Shop. The only answer I can think of is the spring loaded release has lost it's tension. Or there's a breakage with the button. BMW
Posted on May 30, 2006
    Scholar:
  • 116 Answers
Hi Randy, It seems like the problem could be the settings. Try to set the flash manually, and then try to pop it up. If this doesn't work, and since the pop up flash release is electronic, have the camera cleaned at a camera shop. This would be a small price to pay if it works, and would be worth it for such a great camera. Please let me know if this works for you. Best regards, nightdiver
Posted on May 29, 2006
  • Bill DeLisi
    Bill DeLisi May 30, 2006
    Hi Randy,
    Just trying to help, but didn't feel like I deserved a POOR rating.
    Thanks a lot!
Digital camera power problem
No - you can probably replace it cheaper.
Apr 25, 2017 | Panasonic Cameras
Flash not working
Assuming that you haven't put the camera into a mode in which flash is disabled, either the charging capacitor or flash bulb is defective. It will have to be serviced so the appropriate part can be replaced.
Dec 03, 2007 | HP Photosmart 850 Digital Camera
Flash fires irregularly... good exposures, then suddenly 3 way under exposed/black then a good exposure, the a completely burnt out over-exposed shot! Completely irregular.
If you are referring to the internal flash I would say you are firing the camera faster then the flash can cycle. There is a green lightning bolt that will come on in the viewfinder when the flash has charged. If you fire the first one it may be a charged flash then again you may have popped the flash composed and tripped the shutter before the flash has had a chance to fully charge. You fire again depleting the charge some more and before it has a chance to recover you fire it again so the flash never has a chance to fully charge. You need to wait till the flash ready light come on in the viewfinder.
Dec 18, 2010 | Nikon D70s Digital Camera
Flash won't pop up
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 03, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Built-in flash not working
Please shoot in P mode. In P mode it will use the flash if you pop it up and not use it if it is down.
The flash uses LOTS of battery power. If you battery is weak the flash may take a long time to recycle (charge).
The Flash must be popped up and READY before you can use it. The flash is charged or READY when the RED light is on.
I hope this helps.
Apr 03, 2017 | Nikon D60 Digital Camera with 18-55mm lens
Nikon d40 built in flash not firing but it popped up
there is a sensor in there that tells the camera the flash is up you need to take it to a repair shop its not a at home thing
Mar 11, 2009 | Nikon D40x Digital Camera
My camera cannot use the flash anymore
Did you try fresh batteries? If your batteries are old, your flash may not build up enough charge to flash. Let me know how it goes, or if I can help you further.
Rob
Feb 17, 2009 | Samsung Digimax S750 Digital Camera
Flash won't work
Try in custom menu I think. Switch shutter release whilst charging firmware switch whilst flash charging a couple of times. Had sinilar thing with ist DS after firmware update.
Jan 08, 2007 | Pentax *ist DL Digital Camera
Flash not working
the flash bulb or tube does not go off suddenly. it gets weak after yers of usege or breaks only if the camera is dropped. most of the flash related problems occour for non charging of the flash. pls contact local repairer for this problem
Jun 20, 2006 | Casio Exilim EX-Z40 Digital Camera
Olympus Camedia C-770 Digital Camera Logo
184 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
