Question about GE Refrigerators
We have a 1992 GE Monogram Fridge. side by side. On the door the light for dE is blinking. I just noticed it so it just came on within the last hour or so. We are leaving town for a week early tomorrow morning so I need a response very soon. Thanks. Jim
  • 750 Answers
Solved!
Rebooted the system!Working as of chat!
Please Give me a solved rating here TOO!
Huuum
Posted on Sep 14, 2008
I am having big issues and the tech can't come out till next week. This morning my fridge was making a louder than normal sound. When I opened it up.....the crisper at the bottom was freezing my meat. The...
when did you last do a total manual defrost/clean vents and drain holes.if after, you still have problems call tech.this way is cheaper....also check door seal is touching frame all around
Feb 10, 2010 | GE Monogram® ZISS420DMSS Side by Side...
BLINKING dE(DEFROST) LIGHT ON OUTSIDE DOOR PANEL OF GE TFX27FH.
look for the manual its usually underneath...remove the grille and look inside. sometimes its taped up
i can help you troubleshoot if you find!
Oct 08, 2009 | Freezers
I have a monogram ZIS420 the freezer works fine
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 24, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
Red door spring GE monogram fridge side door
Spring closure part # WR2X8916 from Sears Parts.
Jun 29, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
GE monogram fridge: Poor Cooling after cleaning
Temporary solution.
Open the top hook. leave it open overnight.
Check in the morning if the temperatures comes back to normal. It works for me!
Jun 06, 2009 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram will not accept freezer/fridge
Turns out the problem was because we didn't shut the freezer door tightly. The temperature re4set itself in about three hours. All OK and no expense :-)
Jun 05, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Need to find model # for ge monogram 42" side-by-side (1992?)
on the 42" Monograms the Model & serial nomenclature are usually located behind the top panel in the center section to the right of the compressor panel. Hope this helps....Bill
May 18, 2009 | GE Monogram Side by Side Refrigerator
Ice dispenser will only dispense crushed ice
Ihave zannusi ZX99/5SI fridge freezer. Top-freezer compartment is not cooling. I have done as before, defrosted and cleaned both fridge and freezer but, with no luck. Freezer is working OK but top-fridge  is not cooling. Could you please help with advice in what to de next.
Thank you
GAZ
May 12, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Cold temps
Same thing happened to us. A baffle that conducts air from the freezer to the fridge gets stuck in the "open" position and needs to be replaced. That'll fix that problem but watch for others including the water dispenser that spontaneously begins blasting water across your floor. We've dealt with this twice.
Jun 08, 2007 | GE Monogram ZISS480DRSS Stainless Steel
Refrigerators Logo
96 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
