MY FENDER GUITAR AMPLIFIER IS MAKING A HUMMING BUZZING NOISE
    Scholar:
  • 83 Answers
Not sure yet, but before considering a fault with the amp, does it only make this humming noise when not plugged into the guitar? I am thinking that the cable might be faulty.
If it while the cable is plugged in the guitar, does the humming disappear when you turn the volume control(s) down on the guitar? I am thinking that one or pickups may be faulty.
Posted on Sep 14, 2008
After 2 days of use i am getting no pick up off my guitar...the amp lights up but all I am getting is a humming noise.
If it's humming when something is plugged into the input, but not when nothing is plugged in, it's most likely the cable. If it hums when nothing is plugged in, the amp is defective and you need to return/exchange it.
Dec 30, 2015 | Fender ® Frontman 10G Electric Guitar...
My fender fm 65 dsp amplifier squeals and feeds back every time i turn it on
Is it plugged into a guitar at the time? If so, it sounds like you're using a speaker cable instead of an instrument cable. There is a big difference. Look on the cable to make sure. If guitar is not plugged in would be a completely different diagnosis.
Mar 05, 2013 | Fender Musical Instruments Corporation...
When I turn amp on there is a loud humming that does not stop.
try plugging into a different socket if that doesnt solve problem you may need to replace cord. sounds like a loose neutral in socket though.
Dec 01, 2012 | Fender Frontman 212R 100W 2x12 Guitar...
My 412Hot Rod Deville has terrible humming/white noise when distortion channel is on
It doesn't happen often but I suspect that the high gain input jack is defective. With nothing plugged into either input jack part of the signal is grounded and there should not be any noise. It might be that plus a noisy preamp tube. Try swapping the first two tubes to see if there is less noise. Carefully bang your fist or use an insulated tool's handle to hear if the noise changes. It might be an intermittent solder connection as well.
Jul 15, 2017 | Fender Hot Rod Deluxe Guitar Combo...
Frender frontman212r has a huming noise when pluged into guitar.
If the humming ONLY happens when a cable is plugged into the amp, the problem is in the cable or the guitar. Poor quality cables or wrong cables will result in hum. Defective wiring or connectors in the guitar OR having the guitar near a source of magnetic fields will result in hum. We cannot diagnose these possibilities remotely.
Oct 01, 2011 | Fender Frontman 212R 100W 2x12 Guitar...
Imput plug not picking up guitar and making fuzz noise
Inspect the jack for damage... including solder where it attaches to the circuit board. Common problem when someone trips over a guitar cable. Loop the cable through the handle of the amp to REDUCE the chance of this failure.
Sep 02, 2011 | Fender Fm25dsp 1x10' Guitar Combo...
Pro Junior III Guitar Amplifier - Hello,When I turn it on there is loud buzzing noise that does not change with volume.Thanks
There is likely one of three problems:
Blown rectifier in power supply.
Bad filter capacitor(s) in power supply.
Shorted power amp chip causing the riple on the power supply to reach the speaker.
Mar 13, 2011 | Fender R) Pro Junior III Guitar Amplifier...
Deville 212 overdrive channel making Loud humming noise
It sounds like a filter capacitor(s) has failed. The electrolytic caps dry out and cease to perform allowing unfiltered power to reach the preamp sections and get amplified.
Being this is tube with high voltages, an experienced person should work on it due to shock danger.
I assume you checked the tubes for shorts as well as emission since a heater to cathode short could cause this as well.
Sep 30, 2009 | Fender Hot Rod Deluxe Guitar Combo...
I have just purchased a Yamaha EG012 and a Yamaha GA-15 Amplifier. I've followed the instructions adn plugged everything in, but when i turn on the amp and adjust the volumes there is just a buzzing noise...
You may have a switch with 2 settings somewhere on your amp - one for active and one for passive. try changing that.
If this doesn't work, make sure you got the guitar in the line input, change the lead for another incase it's faulty, turn the volume up on the guitar to activate the pickups, and rock-out when you find the problem and fix it.
Dec 30, 2008 | Yamaha Electric Guitar
258 people viewed this question
 Grubhead
Grubhead
