Question about Coleman Heating & Cooling
I have a Coleman Patio heater. The flames are very yellow & I don't believe it is sending as warm a flame as it should. Would like to know how to adjust air intake or similar to alter this. I am a plumber gasfitter by trade and do have an understanding of how it works.
  • 828 Answers
The primary air adjustment is located at the burner inlet. To little air and you have yellow flame. To much primary air and you get flame lift off from the burner. The adjustment may be locked in position by a screw. To change the adjustment you must loosen the locking screw.
Posted on Sep 14, 2008
Burner comes on at 3.any lower goes out.6 inch yellow flamestarts on rite side under pressure.not burner rite of burner
Troubleshooting :: AZ Patio Heaters and Replacement Parts
azpatioheaters.com/pages.php?pageid=11
How do I replace starting striker switch on a tall patio heater? How do I clean ... Why is my burner flame low? Why does ... Why does my pilot light, but goes out when heateris turned on high or low? Why do I get a yellow flame and black smoke? ... 6. Can I convert my LP gas patio heater into a natural gas patio heater? NO.
Nov 17, 2015 | Heating & Cooling
Yellow flame
the burner air ports are blocked lack of air to burn needs a service as it will start to soot up
Dec 06, 2010 | Coleman (5040B750) Patio Heater
My patio mushroom heater lights up ok but keeps going out by itself after about 5 to 10 minutes and then can be started again inatantainiously by starting pilot light and away you go until it goes out...
Here's a few things to check. When you light the pilot, is it a strong blue pilot flame, a weak blue flame or a lazy yellow flame? Is it heating the thermocouple enough to make it red hot after a few minutes? If the pilot is small blue or lazy yellow flame, it may be dirty and need cleaned. When the burner lights, the weak pilot flame may diminish causing the thermocouple to cool off enough to shut down the main burner. Clean the dirty pilot orifice by using a can of compressed air with attached straw. (The same canned air you use to clean computer keyboards) Blow it into the pilot assembly where the pilot flame burns out from and blow thru the air holes on the side, if applicable. You might also check the thermocouple itself to make sure the tip is not partially burn't off. It should be a smooth, rounded tip. Replace the thermocouple if cleaning the pilot orifice doesn't solve the problem. Douglas
Aug 05, 2010 | Coleman (5040B750) Patio Heater
Pilot turns on but when I switch to turn it on,
When you light the pilot, are you holding it down for 30-60 seconds. When you release the pilot button, does the pilot flame stay lit? Or does it only go out when you turn the knob to on position. Make sure the pilot flame is heating the end of the thermocouple and that it's a strong blue flame, not a lazy yellow pilot flame. Make sure the tip of the thermocouple is not burn't off, which usually happens with lazy yellow pilot flames. Replace thermocouple is nothing else works.
May 13, 2010 | Coleman 5040-751 BackHome Open Flame Patio...
On a patio heater why is the flame yelow and noisy
Your gas/air mix is not correct. Not enough air. You should be able to adjust the unit and correct this. Read the manual first to find the adjustment and procedure. When properly set the unit should have a blue flame with a white or very small yellow tip. Thanks for using FixYa and for the generous rating.
hardrocko
May 05, 2010 | Heating & Cooling
Charmglow paito heater flames
It is a problem take it back to the store to get it replaced there is a problem with gas getting to the jets and it could be several things, if they can tell you whats wrong or they will replace it free of vcharge hope this helps, if you have any problems let me know and I will try to help. to do that clcik on the link you will recieve for this post.
Avid101
Sep 01, 2009 | Coleman (5040B750) Patio Heater
Coleman Patio Heater wiring
This must be a top secret heater design. Coleman is dwfinately of no help. The whites go to the ignitors or the output of the spark generator. The black is generaly a ground. Good luck.
May 30, 2009 | Coleman 5040-761 Open Flame Patio Heater
Patio Heater pilot lights won't stay lit
crappy pilot flame (not properly heating the thermocouple), bad thermocouple, thermocouple loose where it screws into the pilot safety valve, bad safety valve magnet.
One or more of those is the problem.
Oh...there is also a saftey switch...in case it tips over. It will also cause the pilot to not stay lit (if the switch or wires that go to i are faulty)
May 30, 2008 | Coleman (5040B750) Patio Heater
Coleman Gas Heater for home
I have a Coleman gas heater. My heat won't come on. I can here the blower comming on when I turn on the thermonstat. However no heat will come out. I went up in the attic and the heater instructed me not to light it with a flame. There was a yellow spiral kind of pipe with what look like a little yellow open and close valve. It looked like you should turn it and let the gas come in the heater from the gas line.I wasn't sure if it really was how to turn on the heater. I need some help. should I call the gas company or another company.
Nov 27, 2007 | Uniflame 200209 Open Flame Patio Heater
Coleman patio heater 5040A770
These heaters are not designed to be operated below 40 degrees F. If the heater is used below 40 and if you have a gas tank containing less than 25%, the unit will not operate for long and will start going out. If the heater all of a sudden goes out without showing any flickering or pulsations, you have a bad gas valve, there is no thermocouple on this model. Fill your tank and try the heater again. If it continues, give Coleman a call at 800-835-3278.
Nov 15, 2007 | Coleman (5040B750) Patio Heater
Heating & Cooling Logo
76 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
