Question about KDS Avitron 195TF Monitor
Black Screen I can plug the monitor up the power light comes on green, I hear something click's twice, but don't fell any static on screen
  • evileyes Sep 14, 2008
    Question where is the inverter located in the monitor?
    Hey thanks for trying but I have no clue so just went and bought another one but thanks for the help.
    Champion:
  • 293 Answers
HEY...It's seems your evileyes had burnt a holes to your backlight inverter. Hehehe... Well, you need a new inverter or you can fix it yourself... by replaced a capacitors. Good lucks!
Posted on Sep 14, 2008
  • Cj T
    Cj T Sep 14, 2008
    Evileyes,
    If you had a LCD monitor, your inverter is located in were you plugged your power cord. If you had a LCD monitor with a AC Adapter. Then the inverter located inside, it's a rectangle piece on the left hand side. Don't forget to checked you AC Adapter too...seeing if it have power or not. With power it should lite green. If not, you will need to replaced the capacitors too. But if you got a CTR monitor...
    don't bother to fixed...get a new LCD monitor. Hehehe.... Have a nice weekend!
My screen is black
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.If it seems like the laptop is up and running but the screen is not displaying anything then the issue is with the screen. Take a flashlight and shine it on the screen and look very hard and you might see the icons or something very faintly on the screen. If so, your LCD Inverter needs to be replaced. It is located at the bottom of the screen and covered by the strip that goes around the screen. IIf you don't see anything on the screen then try plugging an external monitor to the laptop. I can be any kind of monitor, even the old big fat crt's as long as it has a vga cable that can go into your laptop's vga port. If you see the image on the external monitor, that means your video card is good and the screen needs to be replaced. Sometimes you might have to hit the FN key plus one of the F1 thru F12 keys to get the image to display. The correct F1 thru F12 key will either say CRT/LCD or it will have the icon of a display on it. Press and Hold the FN key then hit the correct F1 thru F12 key. This will toggle the the image to display either on the computer's screen, the external monitor screen, or on both screens.
Mar 25, 2012 | Computers & Internet
How can i get my sylvania netbook to work when i turn it on and it wont do anything all it does is stay at a black screen? Need help with my sylvania computer problems
When you plug in the power cord do you see any lights either on the power cord's adapter or on the computer that indicates that the power cord is plugged in? If not, your power cord might be bad. You might have been running off your battery for the last time you used it and since the power cord was bad it was not charging your battery so it eventually drained all battery power.
When you turn it on do you hear any fans running, any hard drive running, cd drive clicks once and you see the light on the cd drawer come on for a second or two, lights anywhere on the computer? If so these are signs that the computer is trying to boot. If not you might have a motherboard issue.
Static Charge Buildup can also cause the computer not to boot. Remove the power cord and battery from the laptop. Press and hold the power button for 30 seconds then put the power cord back in (leave the battery out) and try to reboot. If it boots, you had a static charge buildup and can put the battery back in now.
Is the computer actually up and running but the screen is black? If so take a flashlight and shine it on the black screen. If you can bearly see the icons on the desktop that means your lcd inverter is bad and needs to be replaced.
If the computer is actually up and running but the screen is black, try hooking an external monitor to the laptop. You can use any type of monitor, even the big fat crt monitors as long as it has a vga cable to plug into the laptops vga port. You might have to press the FN (Function Key) and one of the F1 thru F12 function keys to get the image to display. Normally the correct F1 thru F12 key will have CRT/LCD written on it or it will have an icon of a display. Press and Hold the FN key then hit the correct F1 thru F12 Key to display the image on the external monitor. If it shows, that means your Video Card is ok.
If the computer is on and running but the screen is black, you don't see any icons on the desktop when you use a flashlight then your lcd screen will probably need to be replaced. It might be something as simple as the lCD Cable is loose or just needs reseated (pulled aloose then plugged back).
You'll have to take the screen apart to get to the lcd inverter and the lcd cables.
Mar 24, 2012 | Sylvania G-Netbook
No display after reboot windows
If it seems like your system is running whereas you hear fans running, hear the hard drive running, see lights, heard the hard drive click during bootup, but there is nothing on the lcd screen then try the following:
1) Try hooking a external monitor to your laptop. It can be any type of monitor even one of the old style fat crt monitors as long as it has a vga cable to connect to the laptop. There is a sequence of keys you might have to hit to get the display to show on the external. Most times you hit the FN (Function key) and hold it while you hit the corresponding F1 thru F12 key that is for display. Usually the correct key will say CRT/LCD or it might have a display icon on it. If the image displays on the external monitor that means the video card is good.
2). Remove the external monitor and reboot the computer again. Now when it is done booting take a flashlight an shine it on the lcd screen. You are looking to see if you can faintly see the icons on the screen. If they are there but barely visible then the LCD Inverter is bad. The LCD Inverter is located at the bottom of the lcd screen just above the keyboard and the Strip around the lcd screen covers it. You'll have to take the lcd apart to get to it.
3) If you don't see anything when you shine a flashlight on the desktop, then the lcd screen has to be replaced. However, sometimes the cable on the back of the lcd screen has come aloose or just needs reseating, so unplug the cable and put it back then see if it shows an image.
Read Below if it is not booting at all when you press the power button.
Laptops don't boot for the following reasons: 1) Bad Power Cord. 2) Bad DC Power Jack where the power cord plugs into the laptop. 3) Static Charge Buildup. 4) Bad Motherboard.
The above 4 reasons are when you press the power button and absolutely nothing happens. You hear no fans running, no disk drive running, no one time clicking sound on the CD Drive and No light for a second or two when the CD drives click. In the case of a motherboard issue sometimes you will hear beep sounds or see blinking lights. Those beep sounds and blinking lights tells the technician what is going on with your motherboard and why it will not boot. If you see the blinking lights or hear beeps count them.
So you have a power light which means your power cord and dc power jack is good. So lets see if you have a static charge buildup.
Remove the Power Cord and the Battery from the laptop, then Press and Hold the Power Button for 30 seconds. After 30 seconds put the power cord back into the laptop, but leave the battery out. Press the power button to see if it boots. If it does you had a Static Charge Buildup and it's ok to put your battery back in. If it does not you more than likely have an issue with your motherboard.
Mar 23, 2012 | Computers & Internet
How to solve problem after reboot my notebook dell no displaY
Mar 23, 2012 | ASUS Eee Computers & Internet
Black screen no cursor no keyboard use
When you powered on the machine did you hear any beeps, hear the fan running, the disk drive running, lights blinking, hear the cd drive click, see the light on the cd drive door for a second or two when it clicks? If these things are happening you are getting power. If not, your problem might be with your power supply, hard drive or motherboard. Remove the power cord, then press and hold the power button for 30 seconds, then plug it back in and press the power button. if it boots you had a static charge. If you get nothing at all but a silent system your power supply is bad. If it sounds like your computer is running but you can't see anything on the screen you might have a problem with your screen or video card. If you have another monitor try using it and see what happens. if it works so you can see things then your monitor was bad. If it does not work with another monitor but you still hear fans, and see lights and hear the disk drive spinning, then your video card is probably bad.
Mar 17, 2012 | Gateway Computers & Internet
Sampo Flat Screen Black unless unplug and plug back in
i had the same problem now my monitor wont even turn on if i do that the power light just keeps blinking maybe its a sign of a dying monitor
Jan 16, 2009 | Sampo PD-70 15" Flat Panel LCD Monitor
Sony Bravia 40 inches has a defect
More then likely your power supply failed. If you do not hear a click from the relay during the power up cycle then your power supply failed.
Jul 29, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Black screen
EHT Transformer to be replaced
Apr 18, 2008 | ViewSonic P220f 22" CRT Monitor
Screen black
Bill, It could be your LCD backlight giving you problems. With the computer on and the monitor power LED green shine a flashlight in the lower left hand corner of your screen. Look for the ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. Depending on the monitor this is usually and economically repairable problem. Let us know if you have any other questions and please don?t forget to rate this posting.
Mar 06, 2007 | Samsung SyncMaster 910T 19" LCD Monitor
KDS Avitron 195TF Monitor Logo
93 people viewed this question
Top KDS Computers & Internet Experts
RobertFonner
RobertFonner
ray
Level 1 Expert
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
