Question about Refrigerators
Have got fridgr freezer freezer has been leaking water for sometime now freezer has stopped working but the fridge is fine
  • 725 Answers
You have a plugged drain hose it is behind the evaporator cover in the freezer, remove the cover defrost the ice , clear and clean the hose ... and it will work again
Posted on Sep 14, 2008
I have a Samsung RS21DPSM American Fridge Freezer it has stopped making ice the water dispenser works fine but no water going into ice maker?
check the line that runs up the back of the fridge u have to take the back off sometimes there is something wrong w that line or there could be some water has frozen in the top of the line that goes into ur icemaker inside the freezer
Feb 28, 2015 | Samsung Refrigerators
Water leaking under a fridge freezer
There can be 2 reasons for this ... the first is that the machine is causing condensation and is dripping on to the floor. Automatic defrosting fridge freezers do this but usually the quantity of water evaporates before any is on the floor.
If the Fridge / Freezer has an automatic Ice maker, or has a cold water supply, then I would suggest that there is a water leak to the system. In this case, find the water supply feed and turn it off to eliminate this as the source.
If this stops the leak, then either the supply is leaking or the problem is inside the fridge / freezer and you will need either a plumber or a repair man to fix the problem.
Aug 21, 2014 | Refrigerators
Water leaks inside food compartment
Your fan has stopped working. You need to either replace it or see if your defrost timer is working.
Jan 07, 2014 | Frigidaire FRT15B3A Top Freezer...
Fridge and freezer are working just fine. But, I keep getting pools of water inside my fridge. These pools stay to the back of the fridge on all levels and they sometimes turn to ice. I notice ice layer...
Your defrost drain is most likely blocked with ice or sludge. Now when your refrigerator goes into defrost it pours into base of freezer or just anywhere it can to pool up. Click Here=> Leaking Refigerators, just what may be happening Click here also=> Leaking Refrigerator's? Please let me know if you still have questions, Thanks, Sea Breeze
Mar 19, 2011 | Whirlpool Refrigerators
LG Fridge Icebeam Door Cooling Refrigerator Freezer is leaking water into very bottom of fridge. Fridge is only 6 years old. What could be the cause of this problem ? Many thanks for feedback.
lg ice beam refrigerator which has door cooling also is not cooling properly. the freezer is working there was ice accumulated in the rear corner of the freezer i defrosted but still the fridge is not cooling and there is a pool of water at the bottom most of the time. sometimes i see the fan inside the fridge is not working
Jan 11, 2011 | LG LRTN22310 Top Freezer Refrigerator
The freezer (top) works fine but water leaking in the fridge
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
May 31, 2010 | Refrigerators
Leaking water inside bottom of fridge, fridge not keeping a cold
Sounds to me you are having a ice blockage and or defrost problem. When that happens water can not get outside of the refrigerator. If you look inside the rear of freezer you may see a frost line or layer building on rear panel. You may just need to begin manual defrost until we can get a look at the evaporator coils and condensate collection tray. Unplug and begin and let me know your model number. I can help if you like, Sea Breeze
Mar 19, 2010 | Refrigerators
Leak in fridge from between fridge roof and freezer, fridge is still cold as is freezer however will not stop leaking
Hi, The drain hole located in the freezer defrost drain is plugged. Get me your model # and I can assist you further.
THanks
Vic
May 17, 2009 | Refrigerators
Amana SBD 522VEBONY - fridge freezer is not staying cold -
If your freezer works after regassing...and after sometime the problem occurs again. It seems to me that there is leak on the pipes in which where the gas runs, that is why it runs for sometime after regassing, after some time the gas that was loaded during regassing leaked through the atmosphere and the problem occurs again. It would be better if you replace it with a new fridge.
Hope this idea helps.
Jan 05, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
192 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
