Init® - Crosscut Paper Shredder Model: NT-PS10CC
I am using your vegetable oil method on my INIT cross shredder tonight. I fed more than 10 pages and the whole thing got jammed. I switched forward and backward, unplugged and used a screwdriver and scissors to pluck the pages from between the teeth. I did get cut, but not severely. I am hoping that INIT will respond to the oil treatment as well as the Fellowes.
4 Suggested Answers
  • 7 Answers
SOURCE: I need a plastic gear for my shredder it is a init mt-ps10cc
what is the machine
Posted on Aug 24, 2009
FixinFax
  • 3085 Answers
SOURCE: Fellowes MS-450Cs crosscut shredder quit
No, your shredder blades are dull. No replacement parts are available. Sorry
Posted on Nov 27, 2009
  • 61 Answers
SOURCE: init shredder not working the motor is running but
Probably a stripped gear in the drive chain caused by overloading. Parts are not usually available for these low-priced machines. Sorry.
Posted on May 14, 2010
Can I use olive oil for my shredder
Yes you can.
Canola oil is better. It is the oil recommended by shredder manufactures and it does not have any odor.
Feb 26, 2014 | Dynex - 6-Sheet Crosscut Shredder
My shredder squeaks when in use, does it need regular lubrication? If so, what do I use?
Visit the link below for various types of shredder oils.
http://www.factory-express.com/Shredder_Oil__Bags-2025.htm
Regular use of paper shredders creates paper dust that can dry out components, dull the blades, clog the machine and burn out the motor. However, with proper oiling and maintenance, a paper shredder can last for years.
Oiling a shredder can be accomplished using one of two quick methods. The paper method limits excess oil to the paper, reducing the chance of it splattering when you turn the machine back on. This method is more common than the second and can be used with all kinds of shredders. The paperless method may be less common, but it is just as effective at removing dust buildup from the blades of the shredder.
The Paper Method:1. Place a sheet of paper on or above a surface that will not be marred or damaged should you spill oil on it.2. Apply the oil to one side of the paper in a wide zigzag pattern across the whole face of the page to ensure sufficient coverage. Do not saturate the paper with oil.
3. Turn the shredder on and run the oiled piece of paper through the shredder. As the paper shreds, the oil that has been absorbed by the paper will lubricate the blades. The motion of the blades will distribute oil so the shredder continues to operate smoothly.
3. Feed a few more papers into the shredder to absorb residual oil from the cutting assembly. The Paperless Method:1. Set the shredder to manual mode so you can control the direction of the blades and the amount of time the blades are in motion.2. With the paper shredder turned off, squirt a solid line of oil into the paper entry lengthwise across the paper-shredder blades.
3. Start
the paper shredder in reverse, allowing it to run for 10 to 20 seconds before stopping the blades. This will evenly distribute the oil to all parts of the cutting assembly.
4. Return
the shredder to automatic mode. Then feed two or three sheets of paper into it to absorb the excess oil from the machine. Tip:
How often you should oil your paper shredder depends mostly on how much you use it. Office shredders that see heavy use every day will need to be oiled several times a week, while home machines used occasionally need be oiled only a few times a year. Cross-cut shredders will require more frequent oiling than other paper shredder varieties because they have more blades and create much more paper dust.
You can purchase a shredder lubricating oil from any major electronic or office supplies store or you can contact Royal customer service at 908-429-4357.
Feb 20, 2012 | Royal Sc120 Shredder
I have the CX6 shredder, the paper get jammed in the feed,can i oil the feed?
How to Oil a Paper Shredder shredder_oil.jpg Paper Shredder OilProper shredder maintenance is required by all paper shredder manufacturers to maintain warranty coverage. Perhaps the most effective way to care for your shredder is to oil the cutting heads regularly. Why should I Oil my Paper Shredder?
The frequency of shredder oil applications is determined by a number of factors. First of all cross cut shredders must be oiled more often than strip cut shredders do. A cross cut paper shredder will require regular applications of shredder oil while a strip cut can go for a longer period of time without decreased performance. Secondly, paper shredders that are used more will need more lubrication. A paper shredder under heavy usage will need oil about once every four hours, while one under normal use will only require oil once or twice a month. Most manufacturers recommend oiling the cutters once every 30 minutes of accumulative shredding, but an easy way to remember is just to oil your paper shredder every time you change the bag. The type of material as well as amounts fed at once can also effect performance and lead to the need for oil.
Directions
You should only use specifically designed shredder oil to oil your paper shredder. This oil is designed to lubricate precision heat treated shredder cylinders, and any other lubricant or oil will void the manufacturers warranty. So don't use WD-40 or the like to oil your paper shredder.
Shredder oil can come in both liquid and aerosol varieties. However, the most common is liquid shredder oil.
The first way to oil your shredder is to spray or squirt lubricant into the opening and onto the cutting heads. The oil is packaged in a squeeze bottle and is applied directly onto the cutting head in a fine stream. This is done through the paper entry throat. Take 1-2 seconds to oil from one side of the opening to the other. Turn the machine in reverse for about 10-15 seconds to allow the oil to transfer to all parts of the cutting head. The final step is to shred a few sheets of paper to remove any excess oil.
The other, and perhaps most common, way to oil your paper shredder is illustrated in the image above. Simply spread a small amount of shredder oil onto a piece of paper in a zig-zag type motion. Make sure that you spread the oil over the entire sheet. (NOTE: you don't need to soak the paper in oil, just ensure total and even coverage.) Feed this sheet through the shredder and then operate the machine in the reverse mode for a few seconds. This will make sure the oil is dispersed throughout the shredders cutting cylinders. The final step is to shred a few sheets of paper to remove any excess oil. You may want to repeat this procedure depending on the results, and is recommended for up to three applications to be assured of thorough oiling.
You should oil your cross cut shredder on a regular basis. If you are shredding a small quantity such as only 50 sheets a week or if you are using a small shredder, then you should oil your shredder every other day. If you are shredding a large quantity such as hundreds of sheets, then oil after 30 minutes of usage or after you empty the bag.
Start oiling your paper shredder now. The shredder will run smoother, faster, and put less strain on the overall motor, gears, and bearings.
Oct 03, 2011 | Office Equipment & Supplies
Should the shredder ever be oiled? if so...where
Directions
Dec 16, 2010 | Office Equipment & Supplies
I have a Royal VF810 crosscut shredder and I have lost the operating manual. How could I get another one?
Doubt if you will get a new operators manual on a "consumer" model machine....remember this is a "light-use" shredder...only run the machine at 70% of its maximum rating...lubricate it occasionaly by putting shredder oil on a sheet of paper then shred the sheet of paper...only run it for a "max" of 5 mins then give it 10 mins to "cool down".....
Jun 14, 2010 | Royal Office Equipment & Supplies
Init shredder not working the motor is running but the shredder part is not working. This started after clearing a paper jam. Model is NT-PS10CC
Apr 28, 2010 | Office Equipment & Supplies
I need to find parts for my paper shredder NT-PS10cc
Here is the customer support info for that company. They should be able to help you with the parts you need.
http://www.initproducts.com/t-contact.aspx
Jul 07, 2009 | Aurora Electronics AS1500CD Shredder
1,272 people viewed this question
jasbo
jasbo
