Question about Sanyo ECJ-B35S Micom 3.5-Cup Rice Cooker
Replacing clock battery on the ecj-b35s
According to the manual, the battery is integrated into the main body and requires taking it to a dealer for replacement. Now how hard is it to replace a battery anyway.
I am just not sure exactly where it's located. Assume it's under the front plate where the menu and button are located since that's the logical place.
Has anyone replaced one of these batteries and has some good pointers before I start taking things apart! I would rather do it right the first time rather than have to search around for it by taking different thing off looking for it.
Any help, suggestions would be appreciated
This web site has a photos on how to open the Sanyo rice cooker:
http://www.efsowell.us/ed/SanyoECJ-B35SRiceCooker
The solution shown is to install an external battery pack,
but in the battery looks like a 3 volt Panasonic CR-2354/HFN .
(picture is too blurred to read a part number,
so you should check your own cooker).
http://www.digikey.com carries this part
(listed as P274-ND) for $1.90 plus $7.50 UPS ground service
(only carrier authorized to ship lithium batteries)
I used this battery to repair my William Sonoma SR-MK10S
Fuzzy Logic Rice Cooker which is the same as a
NationalSR-MM10N. I found the Panasonic repair manual at
http://www.usersmanualguide.com/panasonic/rice_cooker/srmm10n
-david
Posted on Feb 21, 2009
  • Syuriya May 28, 2012
    The photo URL is broken.
  • dai7
    dai7 May 29, 2012
    Google will help you find the new location:
    http://www.efsowell.us/ed/projects/Sanyo...
Desolder the battery soldered to the pcb.If the connecting pins are welded to the battery, take is apart by force. Then solder the pins back to the pcb. then place the new battery.
Posted on Jan 26, 2009
    Champion:
  • 242 Answers
Take it apart and find the part number from the battery. Make sure if it's a soldered battery, your replacement has solderable tabs built in.
Posted on Sep 17, 2008
  • bill king Jul 07, 2011
    1. Remove the two screws at the bottom of the face plate. Remove face plate.
    2. Remove the three screws holding the clock assembly to the cooker body. One screw is visible at the top and the other two are hidden under the tabs on the plastic cover. Lift the tabs and remove these screws.
    3. Remove the 3 mounting bolts at the bottom of the cooker. Pull the bottom section off the cooker.
    4. Pull out the clock assembly. The battery is on the circuit board.
    I couldn't pull out the bottom section. Where is it separate? Any tricks I can apply?
    It is frustrating because I can see the battery from a hole in the plastic panel, but I can't reach it!
After removing the positive and negative tabs from the dead battery, simply solder the correct tab to a Renata battery holder(614-SMTU2450N-LP). Purchase 3 volt lith battery(658-CR2450) and insert into holder. Both parts are available at Mposer Electronics. Next battery replacement is a snap-out-old, snap-in-new. Of course you'll have to disassemble/reassemble the faceplate, bottom, inner control panel, and two(one metal/one plastic) plates. It takes about 1/2 hour for this process, and you now can replace batteries easily when required.
Posted on Jun 27, 2012
I hsve a 2008 saturn sky base 2.4L. The dealer says I need a new body control module. My question does the new BCM require reprogramming? If it doesn't then I will replace myself. Thanks
Body Control Module (BCM) Replacement and Reprogramming
If the BCM is replaced or requires reprogramming, the following procedures must be performed in the specified order:
BCM Setup -- Using a scan tool, go to Vehicle Control Systems » Computer/Integrating Systems » Module Setup » Body Control Module. Select Setup BCM and follow the on-screen instructions, making sure to select the proper RPOs and input the VIN correctly.
BPP Sensor Calibration--Refer to Brake Pedal Position Sensor Calibration
Program Key Fobs--Refer to Transmitter Programming
Setup SDM Part Number in BCM -- Using a scan tool, go to Vehicle Control Systems » Computer/Integrating Systems » Module Setup » Body Control Module. Select Setup SDM Part Number in BCM and follow the on-screen instructions.
Dec 28, 2016 | Saturn Cars & Trucks
I can change the time on radio clock but it just stays on that time
I had this problem after a main dealer repair that required the battery to be disconnected for a couple of hours. I put i right by leaving the battery disconnected for 12 hours until all the memory including radio presets had cleared. After reconnecting it returned to normal. I t may take yours longer or less time but the radio presets clearing seems to indicate it will restore the clock.
Oct 24, 2013 | 2007 Toyota Aygo 1.0
Ecj-s35 replacement pot
I have a ECJ S35S rice cooker with like a new inner pot but is not working and needs parts :(
May 20, 2012 | Sanyo ECJ-S35 3.5-Cup Rice Cooker
Where can I get a inner pot replacement for sanyo ECJ f50s?
Inner pot replacement can be found at amazon, click here: Amazon com sanyo inner pot and take a look. Wish you best of luck. Cheers
Arthur
Nov 13, 2011 | Sanyo ECJ-F50S 5-Cup Rice Cooker
I need the user manual for the Sanyo ECJ-S35K 3-1 2-Cup Rice Cooker. Can you provide me a link?
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 17, 2011 | Sanyo Microwave Ovens
I need a cooking instrutions guide
good day,
hope this link below will solve your problem.
cooking
try amazon.com
Jul 16, 2010 | Sanyo ECJ-B35S Micom 3.5-Cup Rice Cooker
Air bag replacement
There is something called a clock spring that is to be replaced and time an air bag is deployed. The main risk is an unexpected deployment while installing a new one. This can kill you!!! You must disconnect the battery(both terminals) and wait 30 min for backup power in the control module to go away. then be careful not to create static while handling the bag. Always hold it so it faces away from you if it where to deploy. There is a yellow conector on the back side and two screws to remove and replace the bag. The clock spring requires pulling the steering wheel. I believe you can rent steering wheel pullers.the clock spring just has screws and a connector. this is not rocket science it is done daily in body shops just follow the precautions and you will be fine
Apr 24, 2010 | 1993 Toyota Camry V6
Dashboard light replacement
1) The clock slides out by carefully prying with a fine screw driver. Take care not to scratch the dashboard fascia. It has a mini light bulb in the back. take it to the dealer / parts shop so they can see the proper color. Accord dashboards came with 3 different color plastic covers on the bulbs. Also, when you take out the clock, you will be able to see the 3rd screw that is holding the a/c controls fascia.
Feb 03, 2010 | 1998 Honda Accord
Problem with Nikon Coolpix Digital Camera internal battery
Hi
This is a design glitch with these Nikons and many people are complaining about it. The clock battery is supposed to take a small charge from the main battery - enough to maintain the settings when the camera is not in use. However the clock battery that is used is not sufficiently strong enough to hold a charge for an adequate length of time.
As this is somewhat of a design flaw it is unlikely that a new clock battery will make any significant difference to the problem you are experiencing. Neither is it a user serviceable job and for these reasons I do not recommend that you try to replace the clock battery.
Nikon themselves say the following;
"The clock-calendar is powered by a separate rechargeable battery, which is charged as necessary when the main battery is installed. If the camera has been stored with the main battery removed for a long period of time, the clock may need to be reset.
Once the main battery has been reinserted, the clock battery will recharge in several hours, during which time the main battery should be left in the camera."
Hope this helps. Thanks for using FixYa.
Oct 26, 2009 | Cameras
Sanyo ECJ-B35S Micom 3.5-Cup Rice Cooker Logo
4,017 people viewed this question
Top Sanyo Kitchen Appliances - Others Experts
David Payne
David Payne
Gerry Harvey
Gerry Harvey
Irene Tulloch
Are you a Sanyo Kitchen Appliances - Other Expert? Answer questions, earn points and help others
