Question about Sony KV-32XBR450 32" TV
Can't hold a picture
While watching cable TV, the set will hold the audio of the channel i'm watching but a distorted b/w image of a local station will take over the screen. Sometimes that images freezes. While watching a DVD, again the audio will work perfectly but the image will freeze. At one time I actually ejected the DVD from the player and the frozen image still stayed on my screen. Anyone know what's wrong and if its worht repairing?
  • Anonymous Mar 14, 2014
    My daughter paused a show she was watching and turned off the tv now is still on it and won't come off
  • 1,476 Answers
Your problem while watching cable tv sounds like a bad tuner with little or no adjacent channel rejection. The problem with the DVD and I think to some extent the cable sounds like a video processing problem. This unit has digital video circuits and could easily cause the problem you describe. The easiest and probably the cheapest solution would be to replace the board with a refurbed unit. Two companies which sell refurbed boards are PTS Electronics, Bloomington, IN (www.ptsinc.com) and Tri-State Module, Evansville, IN (www.tristatemodule.com). Good luck.
Posted on Jun 23, 2006
SOURCE:
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
We have a LG42lx6500. when you turn it on after being off for a few hours the picture colour is distorted for a couple of minutes before correcting. At times you can see the individual pixels. Sometimes...
Hello
Make sure TV is on the correct channel or input. Check the cables for correct routing from TV to any other devices. Check cables to ensure they are tight and secure.
An analog signal converted to high defintion resolution will cause lines, blurriness or fuzziness in the picture. Change the resolution to a lower or native setting using the media device (cable box, DVD,). This may be an issue that requires a service call to cable provider.
A problem on one channel may just be a error on that channel. If using an antenna, it might need to be adjusted in order to ensure good signal strength. For digtal channels, go into TV Menu. Check the DTV signal. Weak signal can cause picture distortion.
If another device is being used such as a cable box, DVD player or VCR switch between devices and test picture. Check routing of cables that are used to control the image. This should be a series of red, white and yellow cables.
If a VCR with a cable box, make sure the VCR and TV are set to the correct channels for video signal to pass through. If problem is still occuring, try another set of cables. bad cables can cause picture distortion.
Bad cables can cause picture distortion as well. Try another set of cables. If picture is better than when using the cables replaced, this was the issue. If cables are not an issue TV may require service.
Apr 26, 2011 | LG Televison & Video
Screen distorted,cannot watch dvd or vcr
If you are located near a tv station that is broadcasting on the same frequency that your dvd player is trying to use, you will pick up some of the stations' signal that will cause some video ( and sometimes audio) interference. To remedy this you need to set the dvd player to use another frquency (channel). To do this there may be a small switch on the back of the unit or you may have to do it through the players' programming menu where you would look for something like 'output channel select'. I hope this helps :)
May 27, 2009 | Samsung DVD-V5650
Can i get regular tv
To get local over the air channels, you will need to connect an antenna as your signal source instead of Cable on the back of the set. Then you will have to go into the TV menu for signal source and select the Antenna/air option. Then you will have to go to the auto program/scan menu and scan in the stations. This may take a few minutes.
Now you can watch local stations for free.
I believe the FCC "must carry" rule require cable to carry local stations also.
Mar 04, 2009 | TruTech PVS31170S1W 17 in. LCD Television
On CNN or during football games banner is cut off
It sounds like you're watching wide screen content on a 4:3 tv, so the screen may be zoomed in so that the bars that would normally be on the top and bottom are not showing. Because the picture is zoomed in, images that would be at the top and bottom are off the screen. If you're watching from a home receiver (Uverse, DirecTv, Xfinity, etc.) you need to change the video settings to let the receiver know that your TV's aspect ratio is 4:3 (full screen) and not 16:9 (widescreen). Also, if your channel lineup has the option of watching CNN on a standard definition channel, that would also help because the shape of the image would be what your tv was designed for. If you watch 16:9 programs, you will have to choose letter box mode (bars on top and bottom because the shape of the widescreen image does not match the shape of your tv), pillar box mode (bars on either side) zoomed, or stretched. Stretched will make the shape of everything appear distorted, as it squeezes a widescreen image on the sides to make it narrow enough, so that everyone will have tall and skinny heads like an old Kung Fu movie. The sharpest picture would likely be to watch 16:9 (hi def) content in letterbox mode (bars on top and bottom) so at least you get the proper aspect ratio that the sports were recorded in, and it comes from a sharper source (HD vs SD). I would just deal with the bars, because even with a widescreen tv, there will sometimes be bars because that's how programs are sometimes recorded, for different visual impact or cinematic effect.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
Jun 16, 2017 | Mito Car Audio & Video
Not receiving my local cable stations
You need to make sure the TV is set for "cable" tuning and not "standard" or "air." (If you are getting only local off-air channels and no cable stations at all, be sure you have a good cable and connection to the set. Normally, even if the TV is set for "air" you will get the low-number cable channels 2-13.) This is usually a selection through the TV's set-up menu. With a universal remote, it may be difficult or even impossible to get to all the menu entries. Most replacement remotes don't support all the original remote functions. Try with yours and good luck. Once you get the TV set to the proper tuning, you should have all your cable channels.
Jan 03, 2009 | Durabrand BH1304D 13" TV
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
No sound or tv signal
Probably need the TUNER either fixed or replaced.
Apr 27, 2008 | Toshiba CZ27V51 27" TV
Cable stations interrupt while watching DVD
Remove power from your cable set while watching DVD and see if the problem magically goes away. If that's the case, the cable box is to blame...accordianman
Feb 03, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Chang hold a picture
I think I already answered this question but here it is again. Your problem while watching cable tv sounds like a bad tuner with little or no adjacent channel rejection. The problem with the DVD and I think to some extent the cable sounds like a video processing problem. This unit has digital video circuits and could easily cause the problem you describe. The easiest and probably the cheapest solution would be to replace the board with a refurbed unit. Two companies which sell refurbed boards are PTS Electronics, Bloomington, IN (www.ptsinc.com) and Tri-State Module, Evansville, IN (www.tristatemodule.com). Good luck.
May 29, 2006 | Sony KV-32XBR450 32" TV
Sony KV-32XBR450 32" TV Logo
78 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
