Question about Garmin GPS
Turned on NUVI 310 this morning and it has a 7mm white stripe running vertically down LHS of screen; when used last time it worked fine. Have tried powering on-off several times together with reseting unit (button at rear) and resetting the factory defaults in menu (settings) to no avail. Any ideas ? Thanks alot.
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Very possible that the LCD display has failed. I have these in stock but I would not recommend that you to attempt to replace it on your own. Please email me at ks3r at sharc dot net and I'll provide you with a quote to repair this problem. I have references.
    - Jim
Thanks Jim - I have returned the unit as still covered under warranty; the garmin tech suggested a hardware problem so your diagnosis is on the mark. Apprecaite your posting. Cheers.
Posted on Sep 16, 2008
How to calibrate garmin Nuvi 2597LMT touch screen
try poweing it on while holding the upper left corner.
Jul 11, 2014 | Garmin GPS
Black Vertical Stripe Our Hitachi plasma TV has just started displaying a vertical black stripe about three inches wide right down the middle of the screen. This stripe comes and goes every hour or so,...
try doing white wash feture in options see if u can get it out this way 1st before having to take aprt cheak cables are using old style sumtimes they do get glitch do factory reset thx for using fix ya . nick
Feb 03, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
NP50 has white vertical stripe down left side of screen
Display is faulty, I would say. Prove it with an external screen.
Mar 06, 2014 | NEC Office Equipment & Supplies
Red hues all over the images on screen
The TV is a plasma screen. There are several circuit boards that will go bad over time that affects the picture quality. TV Parts Universal TV Stands DLP Chips ShopJimmy You can get the parts here and replace those boards yourself.
Apr 10, 2017 | Panasonic TH-42PZ700U 42 in. Plasma...
Right half of screen is Black with a White vertical stripe
Yeah, I have this exact same problem, except my mom slammed my laptop shut in frustration around half an hour ago, so that's why it's like this. The right half of my screen is black with two colorful stripes (mostly white), but the left half is visible. I've researched a bit and found out that this is because the LCD in your monitor has burnt out, and since you don't have a monitor to attach, the only thing you can do is to go to where you bought the laptop and either get it fixed for free or return it for a brand new one (if your warranty still stands). If not, you might as well get a new laptop. I think my warranty has expired, so I'll get a new laptop, hopefully.
Hope this helps!
~Sam.
Jun 08, 2009 | HP Compaq FP 7317 17" Flat Panel LCD...
Vertical white striped screen
If a lot of pressure is added to the screen this can cause it to fracture internally. Sounds to me like you need a trip to an Apple repair center if you've already tried rebooting it.
Apr 12, 2009 | Apple iPhone Smartphone
My iphone's screen is white with vertical stripes
try to restore ur fone manually.
that should work
Dec 29, 2008 | Apple iPhone Smartphone
White stripes evident each time the printer is started up from cold
Those solid ink machines are designed to be left on 24 hours a day, 7 days a week. (it uses about $20 in ink to turn on each time)
When turned off the printhead nozzles can get clogged up with dry ink, which causes white stripes. Running the eliminate light stripes routine purges the printhead (using another $10 or $12 in ink). When it becomes a continuous problem the printhead needs to be replaced....very expensive and time to get a new printer !
Jan 12, 2007 | Tektronix Phaser 860 Thermal Printer
GPS Logo
87 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
