I have an LG WM2277H washer with the dispense drawer stuck shut. There feels like one of the cups that sit in the drawer for detergent or bleach may have popped up and is hitting on the inside. The drawer comes out about an inch but no more.
  • RchrdMendoza May 18, 2009
    I have the same problem. The drawer is stuck and will not open more tan about an inch or so.
  • 1,462 Answers
Try sliding a knife in to force cup downwards
Posted on Sep 14, 2008
How do you use the tub clean?
Read these instructions carefully before
beginning the TUB CLEAN cycle.
Open the door and remove any clothing in
the wash drum.
Open the dispenser drawer.
Add liquid chlorine bleach or tub cleaner.
Some powder or tablet tub cleaners which
are manufactured for this purpose can be
(NOTE : Do not add any laundry detergent
or fabric softener to the drawer when using
- If using liquid chlorine bleach
Add liquid chlorine bleach to the bleach
compartment of the drawer.
(NOTE : Do not exceed the maximum
fill line and do not pour undiluted liquid
bleach directly into the wash drum.)
- If using powder cleaner
Remove the liquid detergent cup and
add powder cleaner to the main wash
- If using tablet cleaner
Add tablet cleaner to the wash drum
(NOTE : Do not add tablet cleaner to the
Close the drawer and washer door.
Select TUB CLEAN and press START.
NOTE : It is recommended that TUB CLEAN
should be repeated monthly.
If mildew or musty smell already exists, run TUB
CLEAN for 3 consecutive weeks.
After TUB CLEAN is complete or when the washer
is not used, leave the washer door open for better
ventilation and drying inside of the washer
Jul 05, 2014 | LG WM2701HV Washer
Water is leaking out of the detergent drawer. It
i would say the outlet from the bleach area is blocked clean out drawer unit
Apr 12, 2010 | LG WM2277H Front Load Washer
How to clean fabric softner dispenser sear 70 series cc3815443
hi friend,
step 1
Pull the dispenser drawer out until it stops.
  • Step 2 Reach into back right corner of the drawer opening and press the lock tab to release the drawer. Pull the drawer fully out of the washer.
  • Step 3 Lift the fabric softener dispenser cup out of the drawer.
  • Step 4 Run the fabric softener dispenser cup under warm water while rubbing it with a soft cloth or sponge.
  • Step 5 Place the cup back in the drawer and slide it back into the washer.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • You can also remove and clean the prewash, detergent and bleach detergent cups by following Steps 1 through 5.
    hope this helps u
    please rate me.....................
    thank u for using fixya
    Nov 30, 2009 | Washing Machines
    Detergent drawer will not open
    Here's a possible solution: Remove the two screws on the bottom side of the plastic clips on the back of the washer (leaving the clips attached to the washer's top), then use the palms of your hands to sharply push the top back about an inch and a half and lift the top off the machine. Now, if you can see enough through the translucent plastic to tell where the hang up is, you can drill a small hole in the top of it to allow you to push that part down so the drawer will open. Then, use foil duct tape to seal the hole.
    Jan 12, 2009 | LG WM-2277HW Front Load Washer
    LG Tromm Not Dispensing Bleach
    My wife has been complaining that the bleach and fabric softener dispenser still had water in it after washing. After removing the top to the washer I found that there are 4 components to the dispenser. 1. the solenoid (part of a 3 solenoid bundle) for the cold water, 2 the controller to the solenoid 3. The hose from the solenoid to the dispenser, and 4. The dispenser. After checking that there were no kinks in the hoses. I checked the solenoid found it had power at the right time but the flow was low. I shut off all the water and disconnected the lines going into the back of the washer I found that the cold water filters were clogged. After cleaning them (there were 2 for each hot and cold) The washer worked correctly.
    Nov 24, 2008 | LG WM-2277HW Front Load Washer
    Dispenser problems
    Open dispenser drawer and push down on center plastic tab at back of dispenser to allow you to take dispenser out of machine. Take the plastic pieces off and clean them. (they need to be clean in order to siphon the bleach, softener, etc out. If there is water left in them, the water fill valve is OK. Cleaning should fix your problem. If you are using concentrated additives, try diluting them a bit with warm water when you add them to the dispenser. Remember, only one tablespoon (max) detergent, one teaspoon (max) fabric softener per load.
    Oct 18, 2008 | LG WM-2277HW Front Load Washer
    Bleach dispener always full of water
    call for service, they will probably order the dispenser assembly (includes new drawer.)
    Apr 23, 2008 | LG WM2455 Front Load Washer
    He4t - monthly bleach cleaning cycle
    Washer Monthly Maintenance Procedure:
    This cycle uses higher water volumes in combination with liquid chlorine bleach to thoroughly clean the inside of your washing machine.
    1. remove any clothing or items from washer
    2. CLOSE door (duh)
    3. open dispenser drawer and remove the detergent compartment and set aside. No laundry products will be added at this time. You will be required to add only liquid chlorine bleach at a later step.
    4. For Kenmore Elite HE products press a specific combo of buttons.
    • Select Rinse/Spin program
    • select low spin speed
    • select warm/cold water temp.
    • select 2nd rinse option
    • push the "end of cycle" signal button 4 times within 5 seconds to start the cycle
    The machine will fill and run a short sensing cycle. This will take about 3 minutes.
    Step 5
    1. The washer will provide 4 short tones. Check the: ESTIMATED TIME REMAINING display for the codes indicated below:
    • if "Ab" (add bleach) displayed in the estimated time remaining window (you'll hear 4 short tones) proceed to Step 6.
    • if "rL" (remove load) displayed in the Estimated Time Remaining window an error tone will sound. The door will unlock.
      -open the door and remove the items from the washer.
      -continue the cycle by pressing the START button.
      NOTE: The water in the unit will dispense for a moment, then the door will unlock, lock again, and then the cycle will continue with another check for items in the washer.
      The machine will fill and run a short cycle to determine whether any items have been left in the washer. This will take approx 3 minutes.
      the washer will repeat Step 5 until it can determine that there are NO items n the washer and will display "Ab" (add bleach).
    6. Add liquid chlorine bleach.
    • If using the maintenance procedure for the first time, open the dispenser drawer and immediately add 1 cup liquid chlorine bleach to the Main Wash detergent compartment. The liquid bleach should immediately flow out of the dispenser.
    • If doing a monthly maintenance procedure, open the dispenser drawer and immediately add 1/3 cup bleach to the Main Wash detergent compartment. The liquid chlorine bleach should immediately flow out of the dispenser.
    • Water will be flowing into the dispenser drawer when the bleach is added ... this is normal.
    • Do not add any detergent to this cleaning cycle. Use of more than 1 cup of bleachw ill cause product damage over time.
    7. Once the cleaning cycle has begun, allow the cycle to complete. An est cycle time will appear on the display.
    8. After the cleaning cycle is complete, leave the door open, clightly to allow for better ventilation and drying of washer interior.
    9. Replace the detergent compartment divider.
    Feb 04, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
    Washing Machines Logo
    125 people viewed this question
    Top Washing Machines Experts
