Question about Sony STR-D665 Receiver
Sony STR - D665
While playing a CD, the receiver suddenly stopped working. The usual LED lights that display "CD" , "TV", "Tuner" no longer showed up on the front. I checked the settings to make sure it was not a user error, turned everything off for a while, but it still does not work. Can this be fixed easily, or do I need t go out and get a new receiver?
  • lisa caraccio Jun 11, 2006
    Thank you for the feedback. I tried both ideas but the problem remains unsolved... When removing the fuse, the surrounding glass was very dark and i could not tell if the needle was broken. I bought new fuses, 5V 125A, but when I replaced it, the fuse immediately blew as soon as I powered on the receiver. Is there a trick to replacing a fuse? This is my first time so maybe it's blowing up for some reason i don't know about. I've blown up 4 now :-)
    Thanks again for your help!
    Scholar:
  • 117 Answers
Hi Spike, The first thing I would try is to reset the system. Turn off the receiver and then hold down the power button for 5 seconds. "Enter to clear all" will appear in the display. Press enter and "Memory Cleared" should appear in the display. You are now back to factory settings. If this does not work, try checking the fuse. Take the two screws off from the back top of the unit, and the two screws on each side of the unit, and pull the cover off from the back. You will see the fuse in the back right side (if you are looking at it from the rear) Pull the fuse out and see if the wire is broken. HOPEFULLY one of these solutions will fix the problem. Please let me know how it works. Best regards, nightdiver
Posted on May 29, 2006
Kdc-mp
put a cd cleaner in your cd player see if that helps.
Feb 16, 2014 | Kenwood KDC-MP435U CD Player
How do I display the radio ID number, so that I can listen to Satellite radio?
Verify if the radio is "Satellite ready" or if it comes with the remote tuner unit. I believe you have to buy a separate tuner add-on and antenna in order to activate the satellite circuitry - THEN it will show you a radio ID. I think ONLY the Alpine comes with the tuner. I would call Crutchfield and they can tell you what all you need with that tuner to make it work with the satellite radio.
Jan 14, 2012 | Panasonic CQ-DF783U CD Player
I think I have my cables run improperly/no eq when playing tuner
You could tell us how the tuner, cd and eq are connected for a start. I suspect a Tape Monitor or Source/Tape switch is involved, either in the EQ itself or on a receiver if you have one.
Then you could start isolating for bad connections and cables by swapping the (separate???) tuner into wherever the CD is connected.
Jul 16, 2010 | AudioSource EQ200 Home Equalizer
ONIDA DFX-7100 DVD player unable to play VCD/CD
dvd player s-video pin use to tv tuner card
May 18, 2010 | Televison & Video
I can't pair D665 with T-mobile G1
HI,
Hi, first you have to enable the Bluetooth to scanning mode,
To do this, press and hold the power button continously for 10 seconds, you may have a stable LED, this shows that its in discoverable mode, Now perform scanning and you may get your device and you can pair and make it work
Please rate this solution if this solves your issue, or leave me comment ill help further
RNJ VINODKUMAR
Dec 17, 2009 | Sony STR-D665 Receiver
The AUX stopped working. I can get CD and Tuner
I don't have a solution, but did you ever get this working again? I'm having the same issue. Thanks
Jul 12, 2009 | Kenwood KTS-300MR CD Receiver
483 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
