Question about Maytag Refrigerators
I have maytag model mb1956hew 19 cu in. fridge. The problem is the fridge does not get cold, but the frezzer is fine. I have checked to make sure that all the doors are closed and the seal on the doors are fine. Fridge is about 3 years old
5 Suggested Answers
  • 2920 Answers
SOURCE: fridge left open all night and wont cool but the freezer still works.
time for a new fridge
Posted on Aug 27, 2008
SOURCE: Sub Zero Model 680 - Light in Fridge and Control Panel out
replace door switch
Posted on Sep 03, 2008
  • 62 Answers
SOURCE: Fridge not keeping cold
check the controls and make sure they are set properly, so that you are getting air into the ref. also a common thing is that the evap fan motor could be bad and not blowing air into the ref area. it could also be the start of a defrost problem
Posted on Sep 06, 2008
eagle338
  • 4889 Answers
SOURCE: Jenn Air JCD2389 fridge not cold on fridge side
You have plugged the defrost drain line.This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and thawing it out with a heat gun (be careful of melting plastic) or actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube.
Try it and let me know!
Posted on Sep 27, 2008
  • 6 Answers
SOURCE: (1.7 cu) Chefmate Fridge Doesn't Get Cold
The Chefmate 1.7 fridge uses a thermalelectric device (TED) to provide cold air. There are no moving parts there. The problem is usually in the power supply. That is the PCB on the left side behind the back cover. If the fans are running then your thermostat is bad or the TED is cracked. You can buy these ebay or other places on line. To change one you must carefully remove the large heat sink. The TED itself is only about two inches square. If you decide to replace this unit be sure to get a supply of heat sink glue. Otherwise you will end up with a hot (or cold) spot on the TED possitly causing another crack.
Posted on May 27, 2009
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
Frezzer works frig does not
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 14, 2011 | Maytag 25.1 Cu. Ft. Bottom-Mount...
The frezzer seems fine but the fridge will not cool
heatman101
Apr 28, 2011 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
What is the cu ft on the Maytag fridge model RTT1900D?
ok let me help the model # RTT ( 19 )00 D LOOKS LIKE A 19 CU FT TOP MOUNT MAYTA REF . I HOPE THIS HELPED mm . majic **** .. ( most model # will tell the cu size unless kenmore . thanks for using fix ya mm feed back pls ..
Oct 22, 2010 | Maytag Refrigerators
My Kenmore refrigerator is not cooling properly. Freezer portion works fine but not refrigerator. Came on suddenly.
I had the same problem. The frezzer worked but the fridge was not getting cold. What I have learned is that the frezzer make the fridge cold, so if the frezzer is working then something is blocking the cold air to get into the fridge. Most likely ice. The air come in at the bottom of the inside of the fridge next to the frezzer. Pull everything out of the frezzer, then unscrew the plannel that runs along the back and you see if there is ice. If so turn frezzer off and dry out the frezzer. I used hot water.
Sep 28, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The fridge is not getting cold, frezzer is working fine
unplug unit and let defrost overnight, use a blow dryer to speed things up if you like , return air ducts are iced up by the evaporator coil,
Nov 06, 2009 | Maytag MZD2766GES Side by Side...
All of sudden our Maytag side by side isn't keeping things cold in the fridge. The freezer is just fine. We vacuumed out the back near the fan and emptied it. After letting it thaw out for the day we...
check evap. for freezing on inside back pannel it could be defrost element on the evap. tis will freez up the evap and not let air go to fridg comparment.. replace defrost element. you can pull back panel in frezzer comparment and check element with omh meeter for resantence.....
Jul 29, 2009 | Refrigerators
Fridge problem
I don't know about the hot points for sure, but all the maytags (I used to work for maytag) have a damper valve in the air tunnel that feeds cold air to the refrigerator. If the damper went bad, it would block cold air flow into the refrigerator. (assuming this model has a damper)
Feb 16, 2008 | Hotpoint  21.8 Cu. Ft. Top-Freezer...
Refrigerators Logo
18 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
