Question about Hitachi 27CX01B 27" TV
Screen flashes When I switch on the tv the screen flashes and switches off. Sometimes after trying several times the tv does turn on.
  • 1,476 Answers
I can't say that I have seen this on a Hitachi, because I haven't, but I have seen it on older Zeniths. The problem with the Zeniths was in the power supply. An electrolytic capacitor changes value and slows down the switching of the power transistor. This means sometimes it works, sometimes it doesn't. Replacing the cap solves the problem everytime. I would look in this area. Good luck.
Posted on Jun 23, 2006
My Samsung tv model CS - 29M20MH switch onto standby mode with led flashing several times then switch off - no screen coming on
From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Jul 20, 2015 | Samsung Televison & Video
Why does my t.V keep switching to dvd screen.
TVs turn on in the last screen they were turned off. Try switching screens using the remote control. If the dvd screen keeps coming back, try pressing or tapping on the manual key located on the side or bottom or back of the TV panel. Sometimes this key gets stuck up. If this does not work, try unplugging your home theater and turn on the TV. Most TVs automatically switch to DVD when they sense signal from HDMI cables.
Nov 26, 2014 | Televison & Video
Daytek television will not turn on.
There is a manual switch on the bottom of the TV. Flick it on and TV screen should come on. The power light will come with this switch off but the screen won't. It had me cursing for a while until I saw the little switch.
May 15, 2010 | Televison & Video
Lcd tv loses picture, power lght flashes grn; picture return
It sounds lamp is weak in TV and requires replacement.
I would be in better position to help you out if you post model and brand of your TV.
Dec 31, 2009 | Televison & Video
The tv will turn on but no the screen wont. and
Replace the lamp would be the first thing to try. Lamp door switch on this model is notorious for going bad. If you replace lamp and still won't turn on jumper door switch. If you take off back you can see switch board.
Nov 21, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Mitsubishi WD-62627 62" DLP TV
Try this:
1) turn on the TV
2) from the remote control press MENU 2,4,7,0 then ENTER
3) tv will state on screen that it is INITIALIZING
4) when done press the front reset button.
5) should be good to go!
Oct 26, 2009 | Mitsubishi WD-62525 62" Rear Projection...
TV does not turn on. Stand By LED blinks 4 times and pauses and blinks 4 times again Tv will not turn on...when plugged in the red stand by light flashes 4 times...you can hear the tv turn on but a black...
Try to remove the vertical IC sometimes it become Shorted causing the B+ to drop. after removing try to switch on back check the B+ if ok and the LED not blinking then change the vertical IC.
Jun 01, 2009 | Sony KV-27S42 27" TV
Canon sd10 elph , screen is black,turn it on or off still black
Try inserting and removing the A/V cable plug a few times (that TV cable that came with the camera that hardly anyone uses). There's a little contact switch inside that turns off the screen when the cable is inserted. Sometimes the switch can become a little dirty with corrosion and can turn off the screen. Inserting and removing the cable plug a few times can sometimes clean the contact switch. Good luck!
Oct 21, 2008 | Canon Cameras
Flashing in and out picture
This is crt base failure due to corrosion. That is why to wont get clear picture initially when you switched on in long interval period. Change crt base problem solved.
Sep 09, 2007 | Toshiba 27AF41 27" TV
Hitachi 27CX01B 27" TV Logo
57 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
