Question about Mitsubishi VS-45605 50" Rear Projection Television
Mistubishi vs-45605 pip module
Thank You for the reply! I gave you a fixya! Im looking for a part that looks like this....
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=300257559350
Thisis the only mod that i have found and on that same page you sent me tothey had the schematics for this same board. The problem is that i havea wavy screen and everyone keeps telling me to mod out the PIP modulebut i cant seem to locate it. I know that my tv hasn't had this mod already and i want to do it myself but i cant find the part.
    Scholar:
  • 142 Answers
The PIP board is small and square and stands straight up on the main board. It plugs into a socket. It also has a ground wire that has to be unsoldered to remove it from the machine. It is located essentially in the middle of the main board near the rear of the set. Sorry I can't describe it any better. Go to http:\\www.tritronicsinc.com or call 1-800-638-3328 for parts. Thank you!!
barneyluc
Posted on Oct 01, 2008
I have a mitsu VS-45605 and it seems that all 4 main colors have split. is my tv toast?
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi
This is a case of bad capacitors in the PIP (picture in picture) module. If you have any electronics repair experience, you should be able to do the repair yourself. Here is some more detailed instructions:
http://forum.eserviceinfo.com/viewtopic.php?p=59404#59404
Jan 15, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi vs-45605
Hi
Posted to the link you gave. Good Luck. Thanks for the request :)
regards
robotek
Oct 18, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mits VS-45605 Picture Jumping - See video
Hi Jim and seirig
The PIP module(problematic with this model) can be removed and bypassed, there are guys on ebay selling kits to do this. You probably DO have capacitor problems in the vertical stages(as is the problem with the PIP module also). They do not always "bulge" as an indicator of failure. Often they just leak out. If the bulge occurs about a safety vent stamped into the top of them means they have overheated, and the stamped vent is meant to rupture to prevent them from exploding. If there is any white residue on the board or corrosion about any caps, this is casued by them venting on the bottom side instead, then they have failed. if they move about easily then their connecting legs, they may have corroded off up inside the can of the cap itself. Sometimes they can appear physically AOK, and be faulty. Checking them with a meter is really the only sure way of determining a caps worthiness. It is a common problem with any electronics these days. They just dont build them to last. Surface mount capcitors actually have a shelf life even in storage!! Replacing all the caps in a stage to resolve a problem like this is often gives the best result. One failing cap can put pressure on others, and the overheating issue may reoccur. Best to get quality brand parts to replace failed caps. These guys are everywhere in the world, and easy to navigate, just search for you part :)
A FixYa is a good reward for my time to extend this advice to you. If you have more questions, I am also happy to attempt to answer them for you. Cheers
regards
robotek
Oct 03, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi vs-45605 with wavy lines
The first things to check are the filter caps in the main power supply area. Usually this rolling is caused by 60 cycle hum coming from the wall. Try that first and update this with your results. Also, while you are in there, resolder any joints that appear grainy or have rings.
Dan
Sep 23, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitshishi vs-45605 again
Thanks for the FixYa, I see now what your dilemma is. There is another ebay auction up that also claims there are 5 different PIP boards to mod out. check here
He may be the better bet to go with, and promises to email the mods to you and where to find the board. If they all look different,may be the problem you are facing. .The mod itself is just pulling the PIP PCB, and then jumpering the in/outs for video with a couple of capacitors. Its possible that some versions of the set don't have the PIP PCB, but unlikely . Do you have any pcbs that look remotely similar... the pcb may be different, but will have similer connectivity and function.
robotek
Sep 14, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi vs-45605
G'day mate
To all accounts it does, this can be checked by verifying that it has TWO antenna inputs. To get the PIP working, you will need to split and feed both antenna inputs. Seems to be set up this way to cater to PIP with set top boxes/convertors that have RF outputs
the 2 tuners can be spotted as the shielded assemblies with covers either side in the lower right corner of this pic. There is a mod floating around that involves bypassing the PIP to fix a fault that the set develops. This may have been done to your already.
check here for details.
Hope this helps you. A fixya rating is a great thankyou for my efforts to assist you . Cheers
regards
robotek
1992 mitsubishi vs-50va2
This symptom is typical of the infamous PIP module with the leaky
electrolytics. If the corrosion has not become so bad that the board is
unrepairable, you can change all of the surface mount caps and clean up the corrosion
Jan 26, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Picture has horiz. lines
There is no vertical hold in the tv circuits now adays. You may find a vertical center or a vertical height. Your problem sounds like (if it has PIP Thats Picture in Picture) its in the PIP module and its a small module that stands up and most models of Mistubishi this module is no longer availabvle. The problem with the module is the small pana caps are leaking and ruins the PC traces. I have heard that theres a kit available on E-Bay to jump out this module. Now if its not the PIP model then it could be a few capacitors in the vertical sweep circuit. Also the B+ feed off the Flyback that supplies voltage to the vertical output IC could have a bad or leaky capacitor in the circuit. If your not a tech or solid state troubleshooter theres not much you can do and SHOULD take this set in to a repair center. Good Luck
May 21, 2006 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-45605 50" Rear Projection Television Logo
122 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
