Question about HP LaserJet 2300dn Printer
Text printing problem
4 Suggested Answers
  • 1126 Answers
SOURCE: HP Laserjet 2015n printer
According to the user manual, page 38, automatic duplexing is only available for LaserJet 2015d, 2015dn, and 2015x. LaserJet 2015n is only able to manually duplex.
You will need to buy a different model printer to do automatic both sides.
Posted on Aug 22, 2009
  • 1719 Answers
I think it not the paper tray. It is the paper pick-up roller. When the rollers get dirty or worn-out, the printer fails to pick the paper, which results in paper jam. So, remove the paper tray and toner cartridge and locate the paper pick up roller in the middle. Clean it with luke-water and lint-free cloth. I hope this would fix the issue
Hope this helps! Good Luck!
Posted on Jan 07, 2011
  • 1121 Answers
SOURCE: Downloading printer drivers for hp
Select the OS, down load..
Posted on Sep 12, 2011
0 characters
1 Points
Replace cartridge on hplaserjet2300dn
Thank you for your inquiry.
HP LaserJet 2300dn The HP LaserJet 2300dn printer is the same as the HP LaserJet 2300n printer, except that the printer comes with a built-in duplexer (for automatically printing on both sides of paper).
Here is a link to the user guide that will help help you with a lot of common problems including managing the print cartridge area on beginning on page 68.
If this is a new toner cartridge the installation instructions will be included inside the packaging including instructions on eco-sensitive means of disposal of old cartridge.
If this is your first time installation you will find it's very simple.
  • Turn the printer off.
  • Open the top cover.
  • If new - remove any orange tabs labeled remove 1st. If this is a replacement cartridge grab the old toner cartridge by the finger hold indentation and pull up.
To prevent damage to the print cartridge, do not expose it to light for
more than a few minutes.
Be careful not to touch the transfer roller (the black, rubber roller located
underneath the print cartridge). Skin oils on the roller can cause
print-quality problems.
  • Install the new print cartridge. It should slide easily down the guide slots on either side.
  • Close the top cover.
If the print cartridge is difficult to reinstall, make sure that the registration
plate has been flipped back down into position and that you have
pushed the print cartridge firmly in place.
  • Power the printer back on.
Hope this helps helps. Please keep us updated and remember to rate this answer.
Thanks for using FixYa,
May 16, 2011 | HP LaserJet 2300dn Printer
How to use HP Laserjet 2300 dn offline. This printer is a network printer
Thank you for contacting FixYa with your inquiry.
This printer can work very well via a standard printer cable directly connected to your computers LPT Terminal. Most of Microsoft's current Operating Systems already have the LaserJet J2300 drivers built in and will automatically install when connected.
To confirm your connection to go to your computers printer setup and ensure the driver is configured to print from LPT1 port and click on print a test page. (Start/Settings/Printers/LJ2300 - Right Click on properties then click on the tab for ports. The general tab should have a button to print test page)
The network card that comes with your printer (Jet Direct Card) will not be used with this method nor will the Ethernet cable be required.
Dec 14, 2010 | HP LaserJet 2300dn Printer
HP laserjet 5200 printer taking too much time to print a page..
HP 5200 prints 35 pages/minute, however, system configuration and software reduces print speed. So, If there are no changes in those parameters, you're document is too complex to print quickly.
Try to send a test or a text page to calculate the difference.
Also bare in mind that first page takes longer to print due to printer heat-up procedure.
Nov 09, 2010 | HP LaserJet 5200 Printer
After connect to a computer this give me a test
From the Control Panel, go to Printers & Scanners (or Devices and Printers in Win 7) and make the HP printer the default printer.
Next print, don't hit the "print" icon on your software, but instead click the File text-link and choose "print". This will bring up the print menu and show you where your printed docs have been going.
Change the printer's submenu choice to the HP laserjet.
Mar 29, 2010 | HP LaserJet 2300N Printer
HP Laserjet 1100 - prints test page text & image on envelopes
try to uninstall the drivers and reinstall them it should fix it
Jul 20, 2009 | HP LaserJet 1100 Printer
I have a problem in hp laserjet 2300dtn printer if i print any thing it's printing pcl xl error subsystemn : KERNEL Error: IllegalOperatorSequence Operator : 0x1b Position : 6
sorry, was there any paper jam bvefore this happen? if so call a techian to service. if not try uninstall the printer and reinstall it again.
Jun 16, 2009 | HP LaserJet 2300dn Printer
We have a HP Deskjet D1320 printer. I can print my email, pictures and items off the internet, but cannot print any word documents or notepad documents. When I print an excel document, I get an incomplete...
I have a HP Deskjet 1300n printer. I can print my email, pictures and items off the internet, but cannot print any word documents or notepad documents. When I print an excel document, I get an incomplete page-the grid lines will print,and text garbage from a adobe program but not all the text. When I do a test print page, I get an incomplete text page, but do not know how to solve this. I have removed and reloaded the printer software-no improvement. There are no new drivers to be installed.
Sep 21, 2008 | HP LaserJet 1300 Printer
Printer only prints half a page
this is a driver problem, try reinstalling the printer with the laserjet4 driver which is a universal PCL driver, this should solve the problem. If not, there is also a blank HP Laserjet driver
May 10, 2008 | HP LaserJet 5L Printer
Hp Laserjet 2300dtn
If you do this within the printer driver you will be able to select what media type you are putting in the machine i.e. Card,Plain,Letterhead and so on. Once you have selected what media you must also select tray 1 then open the rear door so when you print the page goes straight through the machine.
I know this is a bit late but seems like I'm the only printer engineers on here.
Hope this works
Thanks J
Dec 06, 2007 | HP LaserJet 2300dn Printer
HP LaserJet 2300dn Printer Logo
29 people viewed this question
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
