Question about Brother HL-2040 Laser Printer
Hl 2140 error light is flashing
Error light is flashing
  • 3 more comments
  • emilyelle Oct 29, 2008
    I have the same problem, and nothing will make the light go off. There is no paper jam. Both covers are closed. I have held the Go button down and that doesn't help. The printer will not print anything.
  • postal dude Dec 22, 2008
    Same exact thing here. Flashing red "error" light, nothing in memory, doors all closed, even uninstalled and reinstalled
  • jimbomojo Apr 02, 2009
    same exact problem. no paper jam. memory is not full. cover is closed, etc. I have checked everything but can't get the error light to stop flashing. very frustrating.
  • LaDancerly
    LaDancerly Jul 05, 2014
    Exact problem. And I thought I had checked everything, but it was indeed a paper jam caused by a tiny rip of paper 1cm x 50mm must have torn of a sheet at some stage. I finally found it took it out and put the toner/drum back in and and presto the printer error light went out.
  • Junkrepair Apr 24, 2015
    I suspected a paper jam, so I pulled out the tray, and the next sheet was sort of being grabbed by the feed mechanism, so I thought that that was the problem, so I pulled that sheet out and thought I was done. But I wasn't. The error light kept flashing. You have to open the front and pull out the cartridge. Then maybe you'll see there is another sheet inside. Just follow the directions in the manual for clearing a paper jam.
Got the same problem, but in fact it WAS a paper jam. Open both the back panel (can you see the orange roller clearly? If so, no jam) and the front panel. Grab the handle and take out the toner and drum and check there is no paper. Chances are there will be.
Posted on Dec 22, 2008
  • 1 more comment
  • alexanderb99
    alexanderb99 Aug 31, 2012
    Much to my surprise, I did indeed have a paper jam. Thanks so much for this post. I was getting really ****** off about the red light until I found your solution.
  • LaDancerly
    Thank you. I thought I had checked everything including paper jam, but it was indeed a paper jam caused by a tiny rip of paper 1cm x 50mm must have torn of a sheet at some stage. I finally found it took it out and put the toner/drum back in and and presto the printer error light went out. Everything is fine. Did not see that tiny bit of paper the first 4 times I seached - so if anyone else is having the same error problem keep checking cause it is most likely to be a paper jam or a tiny bit of paper or plastic hiding somewhere in there! Not too much can go wrong with this basic laser printer.
  • Jaipal Bhandari
    Jaipal Bhandari Sep 07, 2015
    Thanks My problem solved It was paper jam.
Hold the GO or the flashing blue button down for about three seconds, and while continuing to depress the GO button, turn the power off to the printer. Wait about five seconds, then turn the printer back on, wait three seconds, then release the GO button. Everything will be reset. This works assuming you don't have a paper jam, low toner, etc.
Posted on Mar 20, 2011
  • 70 Answers
Could be several problems
front cover not closed
fuse cover -behind back cover - not closed
memory full
  • Press the Go button to print the remaining data in the printer memory.
    Cancel the print job if you want to delete the remaining data in the printer memory. To cancel printing, press the Go button while printing for about 4 seconds until all the LEDs light up. The Ready and Error LEDs will flash as the job is being canceled.
  • Reduce the complexity of your document or cut the print resolution.
Posted on Oct 02, 2008
  • 1 more comment
  • saraswatir Mar 25, 2011
    It worked for me! Thank you.
  • pvparmar1 Sep 15, 2011
    The Toner LED is on.
    The Toner LED is on. what can i do for this Toner Led Idication pls help me it is urgent for me? pls............
I tried everything said above no paper jam. Then I turned of the printer, then back on and it worked!
Also don't go sticking your fingers in the back by the back roller. I burnt my finger on something that was super hot.
Posted on Sep 01, 2010
I took some of the paper out of the tray. i guess it was too full. maybe they shouldn't allow you to put that amount in if it's going to stop it from printing? smart thinking, brother.
Posted on Aug 05, 2009
Well I'll be! Of all the simple solutions, often the most difficult are the most overlooked. Mine was the old paper jam. I looked for paper jam, but didn't go deep enough into the printr. Thanks for the tip!
Posted on Jun 29, 2010
    New Friend:
I have four light( tonner,drum,error,go) blinking problem in my HL 2140. I have tried all the process i know but it doesn't work.I have still same problem.I had reset my printer but the problem is same. Can I get solution of it? Which part of my printer is in problem?
Posted on Dec 17, 2012
After refilling drum, my printer(HL- 2040) does not work! There is always paper problem when paper get into catridge. I tried everthing I have known but I could not resolve that problem! Please help..
Posted on Aug 13, 2010
  • s_eden185 Nov 10, 2010
    Had the same problem with Paper Jam. Checked everything, no jammed paper. Removed toner and lo and behold, undet the toner assy, a small piece of loose clear plastic in the middle, removed and away it went.
  • 4 Answers
Posted on Apr 24, 2015
SOURCE: Paper jam in Brother HL-2140 printer
I have the same problem - try what it says at this link. http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000026/faq000026_015.html?reg=us&c=us&lang=en&prod=hl2140_all
Posted on Mar 18, 2009
ihwsolutions
  • 137 Answers
SOURCE: Brother HL-2140 Error light is flashing
Try to unplug the power from the print, wait 1 minute then plug back in.
This may remove the error.
Posted on Sep 26, 2009
virtualhost
  • 2185 Answers
SOURCE: HL 2140 does not print
This is a common problem to your brother printer model 2140. You need to turn off your printer and take out the toner. Look for the side and you will see a small hole on both sides. This is the sensor. You need to cover it with electrical tape.
Here is a detailed video on how to do it:
http://www.youtube.com/watch?v=hPCGZZIdXyM
Good luck and hope this helps you.
Posted on Sep 30, 2009
Testimonial: ""Thank you so much! it saved me valuable money!!""
Jimsta01
  • 405 Answers
SOURCE: how to fix hl 2140 drum ERRORS
You need to open the front cover of the machine and remove the cartridge (drum and toner) On the top right there is a tab that you need to slide from left to right about 20 times, then bring back to home position
Posted on Apr 16, 2010
  • 261 Answers
SOURCE: HL-2140 error light on.
HI check the manual about this error
Posted on Oct 21, 2010
Why brother hl 2140 error light
The error light indicates something is wrong with the machine. The error light in combination with another light indicated that the problem lies with that item.
If there is an issue with a job not being able to be printed you can press the go button to allow it to continue (Normally happens if you send a job to the printer using paper other than what the printer has in it)
Aug 29, 2014 | Brother HL 2140 Laser Printer
Tip
Resetting Blinking Toner Light HL-2140
Here is the procedure for resetting the Toner flashing light on Brother HL-2140 (sources for other answers here and self testing - specific to HL-2140)
  • Open the front cover and leave open.
  • Turn the printer off.
  • Hold the "white button" while turning the printer on. (All panel lights should be on.)
  • Release the "white button".
  • Press the "white button" 2 times (Pause, wait for all lights to come on.)
  • Press the "white button" 5 times. (All lights to come on again, then go out.)
  • Cancel "maintenance driver" install, if prompted
  • Close cover.
  • Power cycle printer.
This will:
  • reset the toner light (stop blinking)
  • restore the printing darkness (when toner light flashes, printer prints lighter to save toner)
  • keeps the printed page counts and drum life info
on Mar 06, 2011 | Brother HL 2140 Laser Printer
ERROR LIGHT KEEPS ON FLASHING
Check the user manual and compare exact sequence of flashing lights in order to determine what the problem is.
Feb 27, 2014 | Brother HL 2140 Laser Printer
ALL LIGHTS ARE FLASHING BROTHER HL-2140
hi i have brother hl2140 laser printer but all light are blinking
give solution how to solve this
Mar 27, 2012 | Brother HL 2140 Laser Printer
After paper jam cleared HL-2140- printer continues to flash error error error------- What is solution
Be sure the front door is closed and that the fuser door is closed. Also be sure none of the sensor flags are stuck down. Also try pressing the Go button to see if the error clears.
Jul 07, 2011 | Brother HL 2140 Laser Printer
Error light is flashing red
check if the paper tray is empty.
or if you didn't check you printer before
http://www.ehow.com/how_6764715_troubleshoot-2140-compact-laser-printer.html
Feb 04, 2011 | Brother HL 2140 Laser Printer
Drum and error lights flashing
brother hl-5340d
all lights are flashing on top
Nov 01, 2010 | Brother HL 2140 Laser Printer
Get error light when trying to print labels - HL 2140
The driver should pop up a error message. Possibly is due to clean corona wire. Slide the blue lever several times across (at the drum unit).
Dec 10, 2009 | Brother HL 2140 Laser Printer
Sep 26, 2009 | Brother HL 2140 Laser Printer
Brother HL-2040 Laser Printer Logo
33,450 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
