Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Dishes dirty you put them in (and have to just about wash them totally first) and they come out dirty
  • 1 more comment
  • cott203 Sep 23, 2008
    I have almost the same problem ... I don't have to prewash but when the load get finished and I go to the dishes everything has this sort of debris on it ... like it didn't rinse correctly and then the heat almost baked it on ... plates and glasses are the worst.
  • Anonymous Oct 09, 2008
    Same here only mine is white.. WTH..I was thinking it was our somewhat hard water...but..now I wonder..My metal dishes look old also and the thing is useless as far as I'm concerned..My next dishwasher will be from a different maker for sure..
  • Anonymous Oct 13, 2008
    This is the worst dishwasher we've ever had. This dishes never come out clean and the mold builds up in the dishwasher. Ugh!
No solution, Same problem..
Posted on Oct 09, 2008
Did you rinse them off first
Posted on Sep 14, 2008
mastatech
  • 478 Answers
SOURCE: Dishes are dirty when finished water still in bottom of machine
you have a drian and /or pump and motor you didnt give the brand . It would help. call 704-819-6557 for free tech support and parts.
Posted on Mar 14, 2009
jmeredith
  • 417 Answers
SOURCE: Dishes are still dirty after washing. There is
hi,
have you cleaned out the aerator at the sink? its the silver canister thing that comes up through the sink that hisses when the dishwasher drains. pull the cover straight up and off unscrew the inner plastic nut and clean that out in there. look down in there for obstructions. you can go under the sink with a screwdriver and undo the drain line and and put it in a bucket and run a cycle to see if its draining. if its not draining your going to have to take the bottom rack out and study how the wash arm, the pump inlet screen all come undone, most brands are serviceable by the consumer, mostly just phillips screws. you may be surprised what you find down there. you might want to have some bleach in a spray bottle and a couple car rags handy to clean as you go..
good luck
jm
Posted on Feb 14, 2010
  • 949 Answers
SOURCE: Dirty dishes, pump acid wash.
I would not recommend using acid in a dishwasher it could lead to premature seal failure and damage the internal components.
There are cleaners that can be used that are dishwasher safe such as Lemi-Shine, Glisten, Rinse Aid dishwasher cleaner etc. Vinegar works pretty good too.
Depending on what the symptoms were a pump cleaning may be needed, before you act check out these tips I put together, feel free to send me a message back with any questions.
http://www.fixya.com/support/r4666624-hard_water_calcium_white_powder_build_up
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Posted on May 06, 2010
heatman101
  • 43501 Answers
SOURCE: My SMEG Dishwasher is not cleaning my dishes
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
75osrha
Posted on Sep 29, 2010
heatman101
  • 43501 Answers
SOURCE: It simply washes poorly. Leaves soap film on
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on Aug 13, 2011
We have a Bosch SHU3307UC dishwasher. Two friends swear by theirs, saying they put everything in dirty and the load always comes out clean. That does not at all work for us. My wife has to just about wash...
Put dirty stuff in will eventually keep a tech like me very busy. We love to come and charge you alot for cleaning your dishwasher. Remember the Maytag commercials where they put a cake in it? Still got the dishes clean but before long it will cost you big time. Just run everything under the tap. Pot and pans should be lightly washed also. Watch how you place the dishes. Most dishwashers spray up from the bottom. Block it, and the spray will not reach the top.
Nov 28, 2010 | Bosch 23 in. SHU3307UC Built-in Dishwasher
Mold growing on dishes
Recommend that you run another cycle with no DW soap aded, waiting until the dishwasher has filled with hot water and begins to do the first wash cycle. Then add 1/2 cup of bleach to the water and close the door. Allow the cycle to finish. Run it normally with a standard load of dirty dishes. Note: These high efficiency dishwashers count on the "dirt" of the dirty dishes to help wash/clean the dishes. Recommend you not rinse/wash the dishes before you put them in the dishwasher.
Watch for any occurrence of the black dots and repeat the bleach treatment.
Jul 22, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Mar 14, 2009 | Dishwashers
GE PDW9700 - The dishes do not get cleaned
Same as above problem: I have had this dishwasher for less than 4 years and the dishes as of about 2 years ago stopped getting cleaned. I use the recommended dish liquid and rinse and lightly clean the dishes before I put them in.
What a piece of junk!! gs
Feb 26, 2009 | GE Profile PDW8400J Built-in Dishwasher
Food particles are on dishes after washing
Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
Jan 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
My dishes comes out still dirty
I put a bottle of CLR in the dishwasher and I did a wash without any dishes. Repeat if needed.
Aug 18, 2008 | Maytag 24 in. MDB5651A Built-in Dishwasher
Hotpoint BF1620
What you will find is that the plastic nut fixed on the back panel that the top drawer pushes into has lost the rubber inner layer. Replace and your problem is solved
Kamal
Apr 15, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Dishes do not come clean grit on them
either dirty wash arms of insufficient water
Feb 24, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Dirty glasses
there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishes. the dishes look dirty because your water has a lot of calcium and magnesium in it making them appear cloudy or dirty. the dishwasher filter reduces those minerals and my dishes look perfect now. no more dirty and grimy looking dishes. i also dont waste time washing them by hand before and after the dishwasher. hahaha you can get it at www.dishwasherfilter.com. use code DFMTEN and you will get 10% off. it fits right under your sink and is very affordable. you will be glad you bought this product. thanks
Sep 29, 2007 | Tricity Bendix 24 in. BDW53 Free-standing...
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
71 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
