SOURCE: would like to know the gas tank capacity for a
YAMAHA
ROYAL STAR
Engine
Type: 1294cc liquid cooled 70 degree DOHC
V-four, four valves per cylinder
Bore
and Stroke: 79 x 66mm
Compression
Ratio: 10.1:1
Carburetor:
4 x 28mm Mikuni CV
Transmission:
5-speed
Wheelbase:
66.7 in.
Dry
Weight: 701 lbs.
Tires:
Front; 150/80V16 Rear; 150/90V15
Forks:
43mm Kayaba
Rear
Suspension: Kayaba mono-shock with adjustable
preload
Brakes:
298mm dual front discs with dual-piston calipers;
320mm rear disc with dual-piston
calipers
Seat
Height: 28.3 in.
Fuel
Capacity: 4.8 gallons
SOURCE: need to adjust shock absorber on 1996 yamaha royal star
put 45 lbs of air in the rear shock with a low volume air pump that has a check valve in the hose so that it does not bleed off the air when you take the air hose off of the bike the air fitting is located on the right side of the bike on top of the side cover looks just like a valve stem for a tire
SOURCE: replaced starter relay and stater in yamaha 1100 2001 v star
Charge battery to full, start in neutral, still clicks? Bad ground, or bad connection. Jump starter solenoid with screwdriver,etc. if motor turns over the relay is bad. Chaz Moto DC
SOURCE: Fuel tank capacity & range 97 yamaha royal star motorbike
4.8-gallon, teardrop-style fuel tank (including a 0.9-gallon reserve)
It has a cruising range of more than 170 miles (273.58848 k)
