Question about GPX DV7500 System
The volume is way to high even on the lowest setting
I recently setup my GPX 7500 system. It works great except that the volume even with the TV volume off and the system volume at 1 it is really loud. I have also reviewed the audio settings in the hopes that I could fix it but could not figure out what is wrong with it. How can I set it up to reduce the volume?
Sorry I don't have a solution. We have this model and ours is loud also, at the very lowest setting. I disconnected some of the speakers, and sometimes have to put the working speakers into a drawer to lower the sound.
Posted on Dec 12, 2006
WE HAVE A RCA HTS 5000 THAT WE CAN NOT FIGURE OUT HOW TO ADJUST SO THE VOLUME IS NOT ALWAYS SO LOUD BUT THAT CHANGES WHEN THE MOVIE OR SOUND CHANGES
Need more info. Are you using the volume control on the unit as your main control or the volume on the TV? I have a setup in which my sound is routed through a 5.1 Teac amp. The sound level on the amp os set and not changed. The volume control on the TV dictates the amount of sound. If the amp volume is set too high, then this will be amplified even more through the TV's sound input (the red and wite RCA cables).
If this is the case, turn down one of the folumes (the one that remains unchanged) and see what happens.
Jun 05, 2011 | RCA Audio Players & Recorders
Hi i just purchased the GPX ht219b 5.1 home theatet system and it works great for the radio and the dvd player but for the cable t.v it does not sound loud can you help me?
If you're drawing audio from the Cable Box, good. If the Cable Box has a variable audio output you might need to defeat it in the menus somewhere. Look for something like "Fixed". That way the volume control on the box will not affect the feed to the GPX.
If you're drawing audio from the TV, why? See above.
Dec 31, 2010 | GPX HT219B Theater System
Volume is too high even on lowest setting. My Coby MP620 Mp3 player plays the music too loud. It's on the lowest setting, 1/30-something. It's not my earphones because I tried using different ones but it's...
I have a coby mp600 anyone plzzzzzzzzzzzzz someone help me my volume is full blast no mater what setting,,,how do i fix this problem plzzzzzzzzzzz!!!
Dec 17, 2010 | Coby MP620 MP3 Player
We are having problems with our volume! We have a HD 1080P We almost always have to turn the volume up to 40 or above just to hear it. Also when we plug in our HDMI to play from our computer there is no...
check that your cable box has its volume set all the way up, i suppose you are using one, for the hdmi you can only get video from a comp, you need seperate lines for your speaker, usually there is audio in by the hdmi connectors.
Jul 18, 2009 | Philips 42PFL5603D - 42 IN. LCD HDTV
Cannot lower volume on ipod or am/fm radio
Returned it...I called the manufacturer, they said its defective,return it.
Jan 16, 2009 | GPX iLive IB-R2807DPBLK Portable Music...
Subwoofer volume and sound
i had the same problem when i tried to adjust speaker output levels, distance and equalizer manually without using audessy setup..so i reset everything to factory setting (0s)..and then ran
audessy setup..reduce volume on your subwoofer to slightly above minimum(behind the subwoofer) before running the setup..once audessy setup is completed successfully..i started changing setup
manually..changed speaker config for front speaker to small (it is set as large by audessy setup), this should automatically adjust center and other speaker configuration (if not make sure to set them to small as well), then set the cross over frequency to 120..increase the volume on your subwoofer and now you should hear it fire..if this does not help..try playing some rock music with all channel streo mode..if your subwoofer does not fire even for this..then take the system back for exchange..
Dec 28, 2007 | Onkyo HT-SR800 System
The volume is too high when the alarm comes on
There are several complaints in FIXYA and they are all about this same fault condition....the volume is too high when turned on...
Because of the high number of complaints about this same fault I would suggest that its a manufacturer fault.
So the manufacturer should be contacted about it to ask for your money back..
Cheers From YUBEUT..
Nov 12, 2007 | GPX HM3817DT Shelf System
Connecting to front inputs of a Toshiba tv
As a replacement for "Dolby Digital DT3 AV cable" can be used a " 3.5mm (mono) to RCA(or coaxal)" Cable.
Just make sure that DVD Player set for "SPDIF/RAW" or "SPDIF/PCM" output
Oct 12, 2007 | GPX PDL805 Portable DVD Player
Volume setting is very high
That is unusual, and sounds like a manuf defect. If your unit is still under warranty, I would say send it in. If not, give them a call, and get a quote for repair. Unfortunately, due to the quality and value of these units, it will probably be cheaper to buy a new one.
Sep 21, 2007 | Crosley Conductor CR73 Turntable
GPX DV7500 System Logo
144 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
