Question about Dell 924 All-in-One InkJet Printer
Highlighting My printer is yellow highlighting all of my documents that I print and the ones that I copy. It looks like someone took a yellow highlighter to each page and used it to highlight everything. Any ideas? I looked at settings, have turned it off and on, and am out of ideas. Thank you.
  • Anonymous Sep 22, 2008
    Mine is highlighting everything blue
    Guru:
  • 558 Answers
If your printer is a USB printer then do the following:
First of all please remove the USB Cable from your PC completely.
Restart your PC without connecting USB cable back to your PC.
Now connect the USB Cable into the USB Jack from both ends and start your PC.
After doing above steps please reboot your PC finally and printer
Let me know the result, so I can further investigate the problem.
Posted on Oct 06, 2008
I have a Samsung scx 4623fw printner. When I print one page, the machine will send 2nd page following first page causing page 1 jam at exit 2 and p2 jam on exit 1. It happens every time. Can someone h
On the document that you are trying to print, go to the very last word, of the last page.. hold the shift key down & use your down arrow to highlight anything below, no matter how long it may be highlighting white space. Hit your back arrow once. Check the last word for punctuation & spelling, resale your document & try to print again.
A lot of times in the course of 'composing', extra carriage returns or tabs or spaces, are added to the bottom of the document. I have just explained how to clear the second page printing. It may also remove the erroneous codes that may have formed.
Rebooting a printer has the same good effect as rebooting your computing device. It clears up a lot of confusion that has stacked up since the last time you did it.
If you have printed labels with this same printer, you may have part of a label throwing off the paper path. Also make sure that the paper guides in your paper bin or manual feed area are close, but not touching or pinching the paper. This can cause paper to go off of its normal print path.
Good luck.
Toby.
Aug 31, 2015 | Office Equipment & Supplies
Adobe 7.0 : The highlighting tool is erasing my text and just
if you do not save it ...just go to edit ..in the left upper corner ...and roll back a few times..it will fix..also reloading the original document will do that too
Nov 13, 2009 | Adobe Acrobat 7.0 Professional
I am making a copy of an article on my computer.
If you are copying from an internet source, file copy the document to your computer. Next step is,
go to your document settings or adjust the font size by highlighting all the text in your document. set to desired font size you want most probably you need 16-18 in size. save it.
Jun 22, 2009 | Cannon i70 Printer
Every time I try to print the dreaded yellow error box comes up.
Are you using the "same" printer with your 2 PC? or 2 different printers?
If you're using the same printer, check your cables, power supply, drivers, inks, and lifetime of the printer.
If your using 2 different printer you might have a virus in you pc.
Apr 06, 2009 | Computers & Internet
Printing old copied images not saved
go to the printers & faxes documents & look for your printer model, now see if there is any pending documents there & delete it.
Feb 03, 2009 | Lexmark X2500 All-In-One Printer
Printing pdfs with highlighted text/shaded areas
That just means that you don't have a postscript enabled printer, or possibly you're using a black and white only printer. You might be able to print highlighted items normally on other printers, but will have to remove the highlighting to see the text on the one that you have. Alternatively, if removing the highlights isn't possible, you might try selecting all the text and then pasting that into a new document in a word processor or another similar program. If you do have a color printer, and need to print what you're seeing, you can arrange the document so that it is centered on your screen and then press: "Alt + Print Screen" at the same time. You can then open MS Paint or a similar photo editing program and paste ("Ctrl + V") the screen capture into the program.
Let us know if you need further help.
Hope this will FixYa!!!
Oct 30, 2008 | Adobe Acrobat 7.0 for PC
Random yellow highlighting
I don't think it would be a hardware problem. If anything, there's a setting on the program you're using doing it. If not that i'd check the printer manual and the buttons or setting of that.
Oct 18, 2008 | Dell 942 All-In-One InkJet Printer
Printer malfunction
2 possible soultions,
1. The color required to print the text ( ie: black or a variation of ) may have run out and needs to be refilled or replaced.
2. The other way that could help, is to select only the text you wish to print, by highlighting the entire text of the email, and then press and hold Ctrl while you press P to bring up printing shortcut menu and then check the "Print selected only" before attempting to print.
This should give you only the selected text, but if your black or the color required to print is empty, it may appear blank on the page, or show a low ink error.
Jan 12, 2008 | Lexmark X5150 All-In-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
