Question about BenQ FP71G 17" LCD Monitor
Monitor keeps goin in to standby
Hi is there a part i can bypass an d where on the board is it, so the monitor stops going in to standby
    Champion:
  • 220 Answers
If the Display shuts down after you see a BenQ logo at startup but power LED remains on,the problem is with the Invertor board.Transistors 2SC5707 are known to be defective with other related components.You can try replacing if u are technically able and willing.
Samir.
Posted on Sep 20, 2008
Why my lg lcd pc monitor has no standby light and its dim light
check board shorting check smps voltage,check board shorting,check memory ic.
Jun 04, 2012 | LG Computers & Internet
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Apr 21, 2012 | Samsung SyncMaster 2493HM Monitor
Monitor won't power up the indicator just blinks on and off different monitor on the same computer works fine
Hello Sir, hi, your monitor is on standby mode, which means the power supply cannot power up the main circuit board, this is mainly cause by a shorted component that need to be analyzed and replaced, This symptom can also be cause by a defective switching regulator section of the power supply. We usually replace the entire power supply board. if no replacement board is available then we repair the board as our last stance. If cost of repair exceeds a new one, we dump the monitor and buy a new one instead.
Aug 12, 2010 | Gateway FPD1975W 19" LCD Monitor
Hi, I have an LG Flatron TV which I bought 6 years ago. Good picture, no problems until now. I put the set on standby via the remote. Later, when I put it on via the remote all I got was sound and no...
Since the screen keeps turning off and sound only remains have a look at the inverter board for any buldging capacitors which look like blue cans, there is most probably a short in the inverter and the powersupply is sensing this thus turning it back into standby to prevent damage to the tv.
jonno
Nov 04, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Red LED lights
power supply shot ... sometimes x board or y board
Oct 02, 2009 | Pioneer PureVision PDP-5030HD 50 in....
I have exactly same problem
Sound like your display is having issues with the inverter board. When the power supply detects a short circuit, it turn off by itself. When you try several times, you may be able to "bypass" the circuit protection but the damaged parts still having problems. This issue may be related with the DELL display issues.
The display needs to be fixed by someone with experience in electronics repair.
Sep 29, 2009 | Microsoft ChiMei CMV938D 19" Widescreen...
No active standby button, hybernate facility not found.
In the control panel, go to performance and maintenance then click power options. Or, right click the desktop and select the screen saver tab, then click the power button. If the hibernate tab is missing, either your hardware does not support standby/hibernation mode, or it is disabled in the BIOS. If the hibernate tab is available, click Enable hibernation to do you know what.
May 07, 2009 | Computers & Internet
My screen will not power up. If I disconnect the current, wait a few seconds then re-connect - the standby light will go on. As soon as I try to turn on the computer - the standby light turns to green, a...
Hi rj05
I'm sorry to have to say this but you will have to take the monitor in to a repair shop. There is a definate hardware failure inside the monitor.
Regards
Go-Tech
Dec 15, 2008 | Computers & Internet
Fujitsu plasma monitor 42" - keeps going to standby.
It is the soft wear protection system error. You should asked for service.
May 11, 2008 | Daewoo DSP4210GM 42 in. Plasma Television
Standby mode
Check the video connection the video card. You can try another monitor to see if it does the same thing. The video card could be bad.
Jul 15, 2007 | Hyundai ImageQuest F770D 17 in.CRT...
BenQ FP71G 17" LCD Monitor Logo
145 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
