Question about Sharp VT-G21 21 in. TV/VCR Combo
Sharp vt 2128m
1.My set is always reading there is a tape inside the vcr yet there is nothing inside,and I can not insert a tape into the vcr. 2.How do I connect a an extenal dvd player?
  • 1,476 Answers
You didn't say whether the unit was shutting down. Usually when there is a fault in the VCR the TV shuts down to protect the unit. Your unit has a fault in the tape system. It has a bad sensor or something in it which is triggering a fault. Sometimes kids put things in the slot and cause this kind of problem. Using a flashlight look into the slot and see if there is an obstruction. If there is try to get it out. If you are capable and understand TV safety, unplug the set and remove the back to look for any foreign objects in the set. If there are no foreign objects you will probably have to have the set looked at by a shop if you want the VCR to work. If you have composite video and audio inputs on the unit you can hook up an external DVD player with an RCA patch cable. Hook the same colors together on each unit. Yellow for video, red and white for audio. You will have to select the input through the menu. Good luck.
Posted on Jul 12, 2006
Tape Stuck
I've checked the entire user manual which notes problems like this need to be referred to authorized service personnel. Myself, I would unplug the entire unit, put it on a kitchen table using a phillips (cross-tip) screwdriver to remove the top metal shell. Remove at least 2 screws each side and 2-5 rear screws securing the top. Nothing like peering inside to see what is causing the VCR to get stuck and help remove it. No release pinhole or tape freeing ejector will work if the unit's tape is tightly wound around some internal object or the tape is stuck because something foreign is inside the unit. Best of success. ZT3000 "Beta tester of "0"s and "1's"
Aug 17, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Sound and just a Static picture when playing a VCR tape on a Sharp 13vt-N100
More likely a damaged tape got inserted, if the video heads get blocked or even partly blocked every tape after will do this, heads can be cleaned manually (careful if not sure how to do it) or a cleaning tape MAY clear this up or not.
Oct 15, 2012 | Sharp 13VT-N100 Combo
VHS Tape won't stay in compartment
Going to have to look inside but expect to find that tape is not going all the way into position and having the tape pulled out and up against the drum with the video heads.
If it does not fully load a transport problem exists--drive idler and or belts.
Faintly possible also is something that does not belong inside got in past the door and is jamming it up.
Apr 24, 2012 | Panasonic DMR-EZ485VK DVD Recorder/VCR
VCR playback sound and pciture don't match
That is a tape path issue. The new VCR has the problem, usually the guide post for the tape sticks out when it shouldn't making the sound late for the picture because the gap between the video head and audio head is wrong.
Mar 31, 2017 | Philips Magnavox 20MC4304 20 in....
Picture blinking on a Sharp Quos HD TV
A lot of times with recorded tapes, the tape that's inside doesnot work well with vcr s. I have had this problem with old and new vcrs and if you keep trying then the device will eventually eat the tape.....
Apr 10, 2017 | Televison & Video
Error Code F03
What worked for us when we saw F03? Taking the toothbrush out of the VCR! I kept resetting the unit and nothing worked. Finally, I decided to see what would happen if I stuck a tape in. It wouldn't go in because of the toothbrush! I took it out, reset the unit again and it was fixed.
Maybe the error is not F03, but FO3 meaning there is a FOREIGN OBJECT stuck in the VCR.
Feb 13, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Sharp VCR fault
The video head probably needs cleaning. Remove the top cover, and using a lint free cloth (like maybe a dishtowel) moistened by a bit of rubbing alcohol, or a specific for head cleaning product, clean the rotating head carefully. This head is about 1.75 inch diameter and sits toward the back of the VCR mechanism. It is motor driven and will rotate at a carefully regulated speed when a tape is inserted.
Note: Most late VCRs state they have an automatic head clean feature, but it doesn't always get everything, especially if you have a tape that is loosing oxide badly.
Dec 04, 2007 | Televison & Video
Open Questions:
Sharp VT-G21 21 in. TV/VCR Combo Logo
184 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
