Question about Philips 55PP9363 55" Rear Projection HDTV-Ready Television
Turns on and goes right back off
When trying to turn our TV on either by the on/off button or remote, it sounds like it's coming on and then goes right back off.
  • 30 more comments
  • mvsvette Nov 11, 2007
    When turning on the TV either by the remote or the TV itself, the blue light turns on bue the little red light flashes until it turns off. After it turns off the blue light rapidly flashes.
  • Anonymous Nov 15, 2007
    WHEN I TURN IT ON IT CLICKS LIKE IT JUST TURNED ON BUT NOTHING COMES ON NO PICTURE OR SOUND I CLICK THE POWER BUTTON AGAIN IT SOUNDS LIKE IT TURNS OFF. IT DOESNT MATTER IF I USE THE REMOTE OR THE POWER BUTTON I GET THE SAME RESULT
  • marv24 Nov 17, 2007
    same thing but now its smoking
  • CD-Johnny Nov 17, 2007
    Just to add an extra detail to this posting, I have a TOSHIBA rear projection set....if I leave the tv unplugged for three days, it works fine when plugged back in, but as soon as you turn it off, the unit will not come back on until it has been left unplugged for three days. It seems that once the voltage drains from "where ever the voltage is stored", it works okay.
    Is there a component in these sets that controls the level of voltage? You can hear some sort of "protection breaker" clicking on and then off when the tv has been plugged in, then turned off, then turned back on again.
    Perhaps that might my problem?
    Thanks.
  • Anonymous Nov 20, 2007
    turns on but no sound or picture
  • kolassa Nov 25, 2007
    WS-65909 Same problem. Did the Devise/Menu press for diagnostic and received 2 blinks then1 blink.
  • 21 Beachside Dec 02, 2007
    When turning on the television, the green light comes on and you hear the click. After two seconds it clicks off. No picture or sound ever happens.
    Also for the past few weeks prior to it not coming on, the picture would be distorted. It would be somewhat curved with double images in some areas along the edges. Every now and then if you tapped the TV, it would straighten out. Now it won't come on at all, just the ckick on then back off after the two seconds.
  • Anonymous Dec 18, 2007
    tv ws55711 turns on for one or two secoconds and then back off
  • Anonymous Dec 24, 2007
    64 in Mitsubishi 1080Hd tv Acts green power light comes on for a second or two but the tv will not come on or power up.
  • Domingo R. Hernandez Dec 26, 2007
    When turning on tv there's a click and there's a globe on the screen as if it were on. the screen as shows picture. But, while waiting for the picture or changing channels and waiting for some sign of the pictulre. And nothing .
    Then I'll even try to turn it off and there's No respond. But if I wait long even it will go off by itself.
  • Anonymous Jan 02, 2008
    My wife unplugged the projection screen tv and every since than I am not able to get either a picture or sound no sign or anything
  • Pankratz93 Jan 13, 2008
    we rarely turn our TV off - we've had the tv since 2004 and have probably turned it off < a dozen times maybe 2 dozen. My husband prefers to have it on all the time and just turn down the volume so we can sleep at night. He says this helps preserve the TV. But could this have caused the problem with the component that could be shorting out? I turned the TV off last night because the lights from the TV were really bothering me. Now it won't come on. This happened before when I accidentally turned the tv off and it came on after trying for a few minutes.
  • haunze Jan 14, 2008
    Well I will b sitting there watching my tz50v51 and it will just shut off. Then after it shuts off the red light over the power button will start blinking. I really want to know what is wrong with my T.V.
  • steve 1956 Jan 20, 2008
    I have the Hitachi 43FWX20B 43 inch Projection Television that has shut off from time to time. Recently I could not turn it on at all. Later in the day I tried it and it clicked on. I left it on all night so that I could watch football. We turned it on and off all week and this Saturday it did not come on. I have to unplug it to get it to click on for about 3 seconds and it clicks off.
    I know that I need to call a service rep, but I would like to confirm that the cost to repair will not exceed the value of the set. I have owned it for almost 4 years.
  • Anonymous Feb 07, 2008
    i have a ts-5545 that as soon as i try to turn it on it sounds like its comming on but goes right back off before the picture comes on
  • Anonymous Feb 08, 2008
    TV RCA / VIDEOPLUSGOLD / GEMSTAR //when i try to turn it on it sounds like it,,but then it just turn right off,,can u please help me with this problem,let me know when u find a solution,thank u. yjrrosario@yahoo.com
  • Pankratz93 Feb 20, 2008
    We're trying to get our TV fixed - it is a short in some sort of circuit board. The repairs should only be a few hundred bucks - if the repairman ever calls back that the part was in. We ended up buying a new TV but will repair the other TV and give to my father in law. So far it has cost me $50 for the service call and repairman said it would be $150-$200 for the part plus labor to put it in.
  • melbox Feb 24, 2008
    picture now come on after 2 seconds it shuts off
  • Anonymous Mar 16, 2008
    turn on with remote or master power, turns on then back off and the red light starts flashing. can hear power relay click twice.
  • Toad07 Apr 23, 2008
    when we turn out tv on the power button turns green and it come one but as soon as it does it goes right back off and the power button start blinking red
    i have a sanyo 65 inch. and every time i turn it on it comes on then it goes off and then it starts blinking red.
  • Anonymous Apr 28, 2008
    my tv. used to worked perfectly, until last two days when I turned it on it goes off by itself.I have tried to turned on again but i have the same problem. I unplugged it for many hours, I went back to it. still the same. PLEASE I NEED A HELP. THANK YOU.
  • RockinRuss May 09, 2008
    TV clicks on goes off and is flashing fan code. Replaced 2 fans, still have same problem!!
  • wqneu May 30, 2008
    i meet the same problem, if i press "menu" and "device" button together the code is 2 3
  • bandit40 Jun 06, 2008
    I have a hitachi 50fx30b and when I cut it on the red light comes on but then goes off...in the beginning. Now the red light does not come on but the led in the back near a fuse comes on red but none of the green led lights come on at all...could this be the control board..the board that actually has the switches on it to cut it off and on
  • hanzy Jun 18, 2008
    When trying to turn our TV on either by the on/off button or remote, it sounds like it's coming on and then goes right back off. There is occassionally a flicking green light with what looks like a clock
    Any Ideas
  • Anonymous Jun 19, 2008
    hiya my samsung hcn436w stays in stadby mode and thats about it you turn it on then it just goes back to standby please help
  • Mike Stager
    Mike Stager Aug 03, 2008
    Just had the set fixed for no video through the coaxial inputs. They replaced the entire circuit board with an upgraded revision. Have had the TV for less than a week. It worked fine, and then I lost TV reception. I get a fuzzy picture in PIP mode, but nothing on the large screen. Inputting commands makes some screen flicker. I got video just fine by running through the VCR and into the RCA inputs, and now this morning, all it does is click on then off, no picture/sound. Sounds like the power switch trips.
  • Anonymous Aug 07, 2008
    i turn it on then after 2 sec or so it turns right back off. it's done it 3 different times to me, i took it a part wiggled some wires and it would be fixed, but can't seem to fix it this time.
  • barrygill Aug 21, 2008
    Hi I turn on th tv the red status light goes green flashes twice then turns off and flashs orange 5 times in a row every couple of seconds.
    The temp and lamp light seem fine they dont flash at all.
    Any ideas?
    Thanks in advance
  • Anonymous Aug 31, 2008
    as soon as i turn it on it goes right off,no picture just a quick sound then off,after 2-3times it wont go on at all
  • stacybarja May 11, 2010
    please send me a circuit map for my sony kp51ws520 tv to check if iside is okay ....
  • 1,476 Answers
Sounds like a common problem where the Horizontal Output Transistor shorts due to heat, loading by a partially shorted flyback or yoke or old dried heat sink compound. If the HOT is ok then there is probably a short in another component. This can be determined in most cases by isolating each module one at a time. In other words disconnect the audio circuit and try, disconnect each crt separately, etc. If no shorts are determined check the power supply for proper output voltages. All this would need to be done by a tech or someone familiar with the process. Repair cost should not be that much compared to the cost of a new set.
Posted on Jun 22, 2006
It sounds like the High Voltage is having a problem. I had the same problem and it ended up costing about $250 to fix the high voltage from a TV repairman
Posted on Feb 19, 2008
My big screen you can turn it on and it goes right back off i dont know what the problem is
Posted on Apr 19, 2008
  • 21 Answers
I have just had the same problem with a SP47W3HFX and when I took the back of and switched on with the remote I saw two what looked like diodes arching and fizzing on the left (from front) tube's circuit board, when I unplugged, waited and then touched the curcuit board to unplug the ribbon cable and see if it would run on two tubes/lamps, the bottom part with the coil, etc came away from the upper part. new tube needed, parts anyone? What else could have been damaged?
Posted on Nov 25, 2007
4 Suggested Answers
SOURCE:
  • 50 Answers
SOURCE: Clicking sound!
Is this a dlp?
Posted on Feb 16, 2008
Ecollier2012
  • 3459 Answers
SOURCE: I have a Philips 50 inch TV.
May be related to a faulty IC. Check www.magnavoxhelp.com for a fix.
Posted on Jun 26, 2008
SOURCE: Flashing power button no picture or sound!!!
Ive had this problem... Usually all that is needed to be done is a few reboots... First unplug and let sit for one min and then plug in and allow three mins for it to boot... Didnt work retry and retry
Posted on Jan 01, 2010
How do i program my rca remote to my 42 inch samsaung tv
you can try a code search
  1. Turn on the tv you want to program.
  2. Press and hold both the button for the component along with the power button until the light comes on and stays on.
  3. Press the play button every 5 seconds until the device turns off. A bank of ten codes is being sent each time.
  4. Press the rewind/reverse button to see if it turns off/on again. Wait 2 seconds and press again until it turns back on. You may have to do this up to 10 times until it searches through the bank of ten codes sent.
  5. Press and hold the stop button until the light goes off. This saves the code.
Mar 03, 2011 | RCA 3-Device Universal Remote
The tv has power .the red light is on ,but when it turns on,the green light comes on but then it turns right back off ant the light goes back to red it has a round 1/2" button like plastic plug in...
Tod,
The little plastic button you are referring to is the IR receiver for the Remote. When the TV turns itself off, are there any flashing lights on the front or rear of the unit. Look through the vents in the rear for any flashing lights or try tuning the tv on in a dark room and see if any lights flash and reflect off of walls. If there are flashing lights tell me how many flashes and what color and I will try to look them up in the manual.
Nov 02, 2010 | Pioneer PDP-425CMX 42 in. Plasma...
RCA universal remote
I programmed an rca universal remote by:
TURN ONTHE TV
HOLDING DOWN THE TV ANDTHEON/OFF BUTTON ATTHE SAME TIME.UNTILTHEON/OFF BUTTON STAYED ILLUMINATED.
PRESS THE PLAYBUTTON IT WILL BLINK,IF TV DOES NOT GO OFF PRESS PLAY EVERY 5 SECONDS UNTIL TV GOES OFF.
ONCE TV TURNS OFF HIT THE REVERSE BUTTON THE TV WILL COME BACK ON.
HIT THE STOP BUTTON TO SAVE THE CODE.
REPEAT THIS BUT HOLD THE OTHER DESIRED DEVICE INSTEAD OF THE TV.
HOPE IT WORKS
Igotthisinfo from google....then typed in rca universal remote...there was a sight for programming remote.
Jul 26, 2008 | Sanyo DS24425 24" TV
TV turns on, then immediately off again
hi nel2874
so, you have a television that turns off immediately after you turn it on.
It sound like your power supply on the unit is out. Because I don't know the value of your unit I cannot comment on replacing the unit. But I would recommend that you use our website to find a Flat Panel TV Repairman near you. You may want to call to get an estimate on replacing the power supply before considering replacing the unit.
Jun 22, 2008 | Televison & Video
Tv won't stay on
i have seen this before and it may be the front power button being stuck and when your remote turns it on the stuck button turns it back off again. I have an older mitsubishi that will not boot up right sometimes and i have to unplug it and plug it back in fot it to come on. I used to pick up broken tv and fix the power buton and resell them
Mar 27, 2008 | Televison & Video
Changed bulb, now tv does nothing. . .please help
same problem. TV turns on but no picture or sound. when i press power button on the remote control orange light flashes for about a minute and goes back to red.
TV won't turn on. It iz frustating me a lot ay !
Mar 07, 2008 | Televison & Video
Sony TV power and volume not working
Since remote does not work, try taking out batt and turning on by set. See if still turns up. It could be that the up button is jammed inside set. Does everything else works? See if you can go to menu and turn speakers off, this will allow you to work on set and not worry about noise.
Sep 04, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Philips 55PP9363 55" Rear Projection HDTV-Ready Television Logo
2,858 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
