Question about Dell Dimension 4300 PC Desktop
Computer does not boot
When I turn on my computer, I hear 6 beeps, the tower abcd lights on the back, ab is yellow and cd are green. I get no picture at all. I hear the hard drive running, please help me, thank you.
  • 3,940 Answers
AAGG is an indication of a memory error, reseat memory modules, if no luck replace the RAM
Posted on Dec 11, 2008
The tower turns on but does not boot the monitor
There could be a problem with the connection to your monitor.
Dec 21, 2013 | Gateway ATXSTF MNT Pro S P4 1500 Tower...
Cant turn my computer on and there is a yellow blinking light
How many blinks? Count and notice the patterns of the blinks (3 long blinks or 1 long blink followed by two short blinks).
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.If all the above fails, you problem could be your Video Card or a motherboard issue.
Apr 14, 2012 | Dell Dimension E510 PC Desktop
My computer is beeping and the green light is staying on but the red light is not on and it just beeps i changed the battery and still beeps and no signal
If you are receiving continuous beeps, it means that computer is not recognising the RAM (memory). In this you have to open the Computer and follow the below steps:
1. Turn OFF the computer
2. Open the flap of the Tower (Remove the screws from the back of Tower)
3. Now, On the Motherboard you will be able to see the RAM see the picture nanjia.jpeg
4. There should be two pins to unlock and remove it
5. Once removed, clean the terminal and replug it.
6. Turn ON the computer, it should take care of the issue
Thanks and regards,
Jitha
Nov 22, 2010 | Computers & Internet
I have an hp desktp that was working fine but now when i push the button to turn it on the button stays yellow and nothing boots
sounds to me like the power suplly unit as this would be the first thing i would change in the shop if this answer helps please rate it
May 13, 2010 | Computers & Internet
My Dell 8200 Desktop just stopped working. It turns on but doesn't boot; nothing appears on the screen. I was told this is the motherboard. Does that sound right?
two things
  1. What does the power LED on the tower indicate? Solid Amber? Flashing Amber? Solid Green?
  2. On the back of the Tower are 4 diagnostic LEDs, what do they indicate? Normally they flash thru several sequences and stop ABCD all Green. If the stop in another pattern, post the pattern.
Feb 13, 2010 | Computers & Internet
Screen will not come on hard drive light no light checked power supply is ok
Things to check:
  1. Power led on the front of the tower, it should be solid green when on. Flashing Amber is generally an indication of a bad power supply inside the tower
  2. Power LED Solid AMBER indicates system is not finishing the power on self test (POST) and you remove all connections from the tower except power and try turning on again. If no change, remove all PCI and PCI-E cards from system, try again, no change replace motherboard.
  3. On the back of the tower are 4 diagnostic LEDs near the ps2 ports marked ABCD, after the POST, during a normal boot the will flash in several sequences and with boot is finished all 4 should be green. If they stop an a different pattern, then that indicates a failure Yellow Yellow Green Green indicate bad RAM for example
  4. If the LEDs on front and back are Green then the system appears to be booting but the monitor display is not functional
Feb 05, 2010 | Dell Dimension 4600 PC Desktop
My computer doesn't load on the screen as I turn it in
A solid amber power LED on a Dell System is indicative of a no post. There are 4 diagnostics LEDs on most Dell Towers (Either on the back marked ABCD, or on the front marked 1234) they can give more details of what the POST problem is.
Troubleshooting: Disconnect all external connections to tower except power, turn it on, see if the LED indications changed. If they change, then connect disconnected items one at a time till the failed item is found. If no change, the open tower, remove all PCI expansion cards, see if system will boot. If still no change, then most likely a motherboard failure. Take RAM out, see if you get a Beep error code when powered on, if no beeps, replace motherboard. If it does beep, try RAM modules one at a time, if it boots with 1 but not the other, replace the effected module. If no boot, with either replace MB
Oct 08, 2009 | Dell E173FPb 17" TFT LCD Monitor
Dell dimension 2400 blinking amber light
1. Remove All External Devices
2. Check the Computer's Power LED
3. If the power LED has not changed unplug the Power Cable From the Computer Disconnect All Hard Drive Power and Data Cables and power on the computer. If still no go.
4. Remove All PCI, PCI-E, and AGP Expansion Cards .
5. Remove All Memory From the Computer
6. Reseat the ATX and 12-Volt Connections . The ATX connector will be a 4 pin square connector connecting to the motherboard from the power supply and the 12-Volt Connection would be the biggest connector with a lot of colored wires.
7. If still no go.
8. Disconnect the Power Connection to the Chassis Fan
9. If the light still flashes then it could be a power supply or motherboard failure. Try a good know power supply first and if that does not fix the problem it is the motherboard. Also check the back of the tower for 4 lights lables ABCD or 1234.
Rate if useful.
Aug 11, 2009 | Dell Dimension 2400 PC Desktop
Dell Precision 670 6 long beeps on post no video but pc is on
Please consult this Dell link for general startup troubleshooting for your system., and this link will take you to the codes for the error lights and beeps.
Finally, here's a good article to help solve general startup problems and diagnose the possible cause.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 26, 2009 | Dell Precision Workstation 670 PC Desktop
System couldnot respond after booting dell gx270
Try to check connections between the monitor and the System Unit or what they called CPU. Turn on the computer you must hear 1 beep means the computer start normally. if you haven't, try taking out any new installed hardware but not the video card if you don't have onboard video device and turn on your computer again.. if problem still exist keep in touch.. TY
HOPE I CAN HELP
Dec 04, 2008 | Dell OptiPlex GX270 Small Mini-Tower...
Dell Dimension 4300 PC Desktop Logo
348 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
