Question about NetGear WGR614 Wireless Router
Installed a New Wireless Router WGT624 and entered all physical addresses of all wireless computers. All the wireless computer cannot connect to wireless router(Internet).It was working with the old wgr614. Please give support. Thanks Wilfred Gomez
Got support from Netgear Engineer.
Thanks
Posted on Sep 14, 2008
Netgear wgt624 v3 problem,cannot go to any sites
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Let me know if you need further assistance.
Thanks for using FixYa.
May 27, 2010 | NetGear WGT624 Wireless Router
Start up and Signal problems. need to download WGT624 set up
.chk files are normally those produced by the system after a hard drive repair or some such, and shows lost clusters on your drive.
Your Broadband modem feeds the router (your problem device), which in turn connects to the computer's Network Card, the one with the RJ45 connector. The smaller connector goes to your modem, for use with Dial-up signals, not broadband. Cable modem feeds router, router routs signals to various computers, via RJ45 cables. Your router is probably for 802.11g signals, used by the majority of networked computers. The 311 in your computer plugs in to the 624 router. They work together to get you on the Internet.
Nov 07, 2009 | NetGear WGT624 Wireless Router
My pc has locked me out of the internet and i unfortunately didnt save the WEP key, the router is a NetgearWGT624 v3
The WEP encryption key is stored in the wireless setting in the Netgear wireless router.
Connect a LAN cable from the computer to the Netgear router and open IE browser and enter the Netgear configuration IP address (http://192.168.0.1) default login = admin default PW = password (type in the login password if you had changed it).
In the wireless encryption setting note down the encryption key. Use this key to configure the wireless card in the computer.
If you forgotten the PW then you can reset the router back to the factory configuration by using a sharp point and pressing the reset button at the back of the router until the LEDs flash, then release the Reset button.
Then login as previously stated. You can then create a new encryption key. I suggest you use WPA2 or WPA encryption key because it is much stronger than WEP.
I also suggest :-
Change the default password
Change the default SSID
For additional wireless security - enable MAC address filtering (this allows only listed MAC addresses of wireless cards to connect to this router - add the MAC address of your wireless card to the MAC address table in the wireless router).
Don't forget to configure the wireless card in the computer with the router's SSID and encryption key.
Oct 25, 2009 | NetGear WGT624 Wireless Router
I have a Netgear WPN824v3 wireless router. My hard drive on my laptop crashed so I am getting a new one. I can not find my password, is there any way to retrieve it without resetting the router?
Netgear wireless routers have a tiny reset button on the back of the router.
Power up the router and use a sharp object to press and hold this reset button until the LEDs start flashing, then release the reset button.
The Netgear router will now be restored to the factory defaults.
To configure the Netgear wireless router : -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL
http://192.168.0.1
3. Enter the router setup login and password (which are admin, and password)
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WAP2
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Oct 10, 2009 | NetGear WGT624 Wireless Router
Have no cd to install drivers
You do not need a CD to configure a Netgear wireless router. Follw these steps to configure the wireless router.
http://192.169.0.1
Login = admin
PW = password
Oct 02, 2009 | NetGear WGT624 Wireless Router
How do i install the router. Do i connect
To setup a wireless router connect the DSL or cable modem to the WAN port of the wireless router with a LAN cable then follow these steps :-
7. For further secutity measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
10. Remove the LAN cable between the router and the computer and the computers should be able to connect to the router
Sep 30, 2009 | NetGear WGT624 Wireless Router
I have a Netgear WGT624 v2 wireless router. It works fine most of the time. But when I try opening any site that loads heavy content like Google Maps or any player like TVU Player, the connection...
ote: Please use the computer for which the Ports are to be opened:
For Windows 2000/XP users:
1. Please click on Start and select Run.
2. Type in cmd and click on OK.
3. In the Command Prompt, please type ipconfig/all then press Enter or Return key.
4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router).
5. Please note down the IP address and Physical address.
B. Reserving an IP Address:
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. When the setup page opens, click on LAN IP Setup under Advanced tab.
5. Click on Add under Address Reservation.
6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.
7. If the computer you want is not on the list, please click on the Refresh button to update the table.
8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add.
9. Click the Add button when done.
C. Enabling DMZ:
1. On the left side of the setup page, click on the WAN Setup under Advanced tab.
May 01, 2009 | NetGear WGT624 Wireless Router
I dunno ow to secure my connection with my edimax router
You can read more about WEP and WPA in the following links:
This article explains how to configure WEP/WPA-PSK/Access list on NETGEAR Wireless router (also applicable to access points).
Note:
  • You can configure WEP or WPA. But you cannot enable both at the same time.
  • You can configure Access list and also enable WEP or WPA for additional security.
  • After you enable wireless security features on the router (or access point), you must configure your wireless clients (wireless computers) with matching settings. Your wireless clients will not be able to connect unless you configure matching settings.
  • Its recommended you enable these wireless security settings from a computer wired to the router (or access point).
Configuring WEP:
  1. Connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. Open an Internet explorer and type the router IP address which would be either http://192.168.0.1 or http://192.168.1.1 (by default, refer to your product documentation ti determine the default IP address.) in the address bar and press Enter.
    The Login window will be prompting for a Username and Password. The default Username is admin and the default Password is password
  4. Under Security Options, Select WEP (Wired Equivalent Privacy)
  5. Select Authentication type as Automatic and Encryption Strength as 64-bit (or 128-bit) - You must later configure your wireless computers with the same setting.
  6. Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength) and Apply the settings. Please note down these values - You must later configure your wireless computers with the same setting.
Apr 27, 2009 | NetGear WGT624 Wireless Router
My new laptop recognises my wireless internet but wont connect
Check the security settings and see if MAC Address filtering is on in the router.
Jan 03, 2009 | NetGear WGT624 Wireless Router
Wireless connection
Make sure that your computer is getting a valid IP address from the router. If your wireless network is secured, you might as well consider checking the wireless settings.
Oct 06, 2008 | NetGear WGT624 Wireless Router
NetGear WGR614 Wireless Router Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Brian Sullivan
Brian Sullivan
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
