Question about KitchenAid KP2671 Professional 6 Series Stand Mixer
Mixer will not start - KitchenAid KP2671 Professional 6 Series Stand Mixer
  • 44 Answers
Generally when this happens the thermister has burnt out. simple fix costs about $1 with part from radio shack.
Posted on Dec 10, 2008
My mixer wouldn't start right away it start at the 3rd speed I'm afraid some day it would start at please help!
How old is your mixer? What type of mixer portable or does it stand by itself?
Jun 07, 2017 | Food Mixers
Mixer wont start
Check for broken wire under back cover. Check operation of switch contacts on black speed control plate. Check carbon brushed under black screw caps on the sides. The brushes are keyed, they only work one way.
Jan 08, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Hobart A 200 Mixer
There are four possibilities to look at here. Assuming your mixer has a normal capacitor start motor (older a200's used a different style motor), possibilities are, in order of likelihood:
Motor start capacitor
Start switch (electronic or mechanical)
Burned wiring
Motor start winding
The start capacitor is located at the rear of the mixer. Remove the rear cover (4 screws) and pull the cover towards you. Disconnect one wire from the capacitor and test with any multimeter.
The start switch, if electronic, is able to be tested, but not very easily. Once you've eliminated the other possibilities, it's time to replace the (electronic) start switch. If the motor has a mechanical start switch, it's easy to test: Remove the two wires at the rear of the motor and test for continuity with the motor stationary. A multimeter should show near zero ohms for a good mechanical start switch.
Burned wiring should be easy to spot with some careful inspection around the motor, capacitor, and start switch.
Start winding: Look closely at the stator (stationary part of the motor). If some of the copper windings look significantly darker in color than the others, it's likely the start windings were overheated (the start windings are the thinner copper wires - if you look closely, approximately half of the wires are thinner than the other half). Look for a wiring diagram behind the power switch and determine which wires leading to the start switch and/or capacitor are for the start windings and test for continuity across the start winding. You should read a fairly small value such as 5 - 15 ohms. Values significantly outside this range could indicate a partially open or partially shorted start winding.
Jun 09, 2010 | Hobart A200 Stand Mixer
My Hobart mixer is hard to start. I have to keep
take off the side cover where gear shifter is, you probably have the original arrow hart contactor in there ,that part is obsolete but you can get a kit from hobart to upgrade the control circuit
Nov 29, 2009 | Hobart H600 Stand Mixer
My mixer just started smoking while i was mix some
Your mixer may still be good, let it cool down and then check it out, If it runs OK then there is no problem. The motor in your mixer probably over heated from trying to mix bread dough which will make any mixer work hard. These mixers will get warm when over worked but unless heavy smoke was coming out and you were getting a burning enamel smell it is probably OK. Let it cool and try it but I suggest you not use it for bread any more.
Oct 08, 2009 | KitchenAid KT2651X Epicurean Stand Mixer
Pastry Chef said mixer will not start.
Depending on what you were mixing for 1/2 hour, you could have overheated & burned out the motor.
Mar 21, 2009 | Spar SP-60PZ Commercial Planetary Stand...
575 watt 6qt stand mixer. start out on low speed
Hi. If your mixer is still under warranty, call Kitchenaid, they are usually very good at replacing mixers under warranty.
If you're out of warranty, you'll need to order a new speed control board. Use the following link to download the parts catalog for your mixer.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212278.pdf
You can remove and replace this board yourself. Use the drawings to assist you with the project.
If this solution has assisted you, please rate it. Good luck! ricardok45
Mar 16, 2009 | KitchenAid KP26M1X Stand Mixer
W!ill not start up
Hi Karl. Have your mixer repaired by a shop that has experience repairing Kitchenaid mixers. Don't think for a second that a new mixer will solve your problems. The new Kitchenaid mixers are not as durable as your old one and are made with an absolute minimum of quality. Quality costs money! ricardok45
Mar 16, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
My mixer started to smoke!!
The gearbox grease has separated and is starting to move (slowly) onto the motor armature area through the front bearing. Replace the grease and since it will be apart, use a lot of cloth strips (NO Q-TIPS! TOO STRINGY - LEAVES A MESS) and alcohol to clean off the motor's armature, housing area and any place you see grease slung around. It's not going to be easy, but worth it. I will try to post pictures as I am doing this right now 12/28/17 to my wife's Kitchenaid for this exact reason.The first image is the gear side of the motor bearing, where the thinning grease is moving through. The second image is a shot of the armature of the motor where the brushes touch and will smoke if grease gets that far (it does). The third image is a cleaned out armature area (brushes removed and speed switch moved)The last is the pooled oil separated and sitting just behind the gear box (where will it go if you tilt the head back?)07667273-29b4-4c89-b9b3-12896c8ef14c.jpg20171228_163751-wafg2nvpw021bpnzetjjpo05-2-2.jpg20171228_165900-wafg2nvpw021bpnzetjjpo05-2-3.jpg20171228_173846-wafg2nvpw021bpnzetjjpo05-2-4.jpg
Aug 17, 2008 | KitchenAid KSM150PS Artisan Series Stand...
Univex mixers
Im not bias on my opinion,but from the repairs i do on mixers hobart mixers are far superior than other manufactures.Hobart is over 100 yr old company that started with mixers and their service dept. is good.unlike any mixer out on the market they mirror off of hobart.
Nov 29, 2007 | Univex 250 Watts SRM12 Stand Mixer
KitchenAid KP2671 Professional 6 Series Stand Mixer Logo
69 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
