Question about Samsung DVD-R130 DVD Recorder
Problem with samsung dvd player.....
When I set ?timer recording? for a program, occasionally I get an error message. The error message will be ?system error is detected? and underneath that there will be the following line: Be file:\sh_vrrm_taks.c line:520 Sensecode (4:9:0); detail:0x0 The dvd will not have turned off with above mentioned error message. Some times it will have finished recording the program and sometimes not. I will not be able to use the dvd player at that point, the only way that I can clear the error message and access the menu is by unplugging it and plugging it back in. Is this dvd problem? (Memorex dvd-rw rewritable 2x, 4.6 gb, 120 min) Any help would be greatly appreciated, Dan
  • Anonymous Nov 15, 2008
    Same problem on multiple Samsung DVD-R130 recorders. Seems to happen later in the product's life (it didn't happen when the players were new). Maybe it has something to do with the lens getting dirty or something else inside the recorder/player wearing out.
  • jimwilcox Jan 23, 2009
    Same problem here. I've had it for some time after the warranty expired. Seems to happen to RW disks used a few times, not nearly the 1,000 or so recordings promised.
    Problem Solver:
  • 10 Answers
What is the model number of your dvd player? i suggest try to use DVD-R types. and try resetting the unit if this will help.
Posted on Sep 05, 2007
Samsung dvd sh855 unable to record tv to 250gb hd using timer settings: however can record to the hd using instant record button.
is there any error message or can you provide some other info why you can't record..?
Thank you
Apr 30, 2008 | Televison & Video
Have Panasonic omnivision VHS PV-D4743S-k 4 head Hi Fi stereo and am having problems setting the timer. Could you help please?
To set the time do the following:
Press PROG*
to display Program.
To set record DATE,
press
to select:
1~31= one time, or
DAILY= MON~ FRI, or
WEEKLY= same time
each week and
press SET.
To set remaining items,
press
to select and
press SET
to set START/ STOP times,
CH (channel) or LINE
input (p. 35), and tape
speed (SP, LP, SLP).
Press PROG
to end programming.
To Enter More Programs,
press
to select and
press SET
to set an unused program
number, and then repeat
step 2.
Or
Press PROG
to exit.
The “Timer” Indicator lights up on DECK.
• You can do Timer Recording with the power on or off.
• “TIMER REC WILL START SOON” appears on-screen for 2 minutes
before Timer Recording starts. If DECK is in DVD mode, no message
appears, but the VCR REC Indicator, the VCR mode indicator and
“REC” will flash on Multi function Display.
Hope this helps!
Brad Nelson
Mar 17, 2008 | Televison & Video
Sony DVD Recorder RDR-HXD990 will not timer record.
DVD wont consitently read discs drops out even though no scratches on discs
Jan 29, 2010 | Sony RDR-HX510S DVD Recorder/HDD Recorder
Samsung DVD-SH897M - Cannot get Time Programming to work
You need to contact Curry's direct, I am certain they will be able to send someone to explain it to you.
Jan 05, 2010 | Televison & Video
Samsung DVD-4600 won't record with VCR timer set
Press fast forward and rewind button on the unit simultaneously for 10 seconds with no disc inside the player to reset it to factory setting.
Aug 19, 2009 | Samsung Televison & Video
Samsung DVD-V4600A Combo DVD / VCR will no longer timer record to Videotape
Storms tend to fry most delicate electronics. Quality surge protection is required.
Ben
Jul 25, 2008 | Samsung DVD-V4600 DVD Player/VCR
Philips DVDR3450H Recorder does not record all of timed programs
When setting the record timer make sure that PDC / VPS is switched OFF.
PDC - Programme Delivery Control / VPS - Video Programming System is designed to allow for late starting or running programmes. Not all channels support PDC/VPS, so the recorder may be waiting for a PDC/VPS signal which isn't there.
Jan 17, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Programmed recording to the hard drive
Either You haven't set the time/timer correctly or you need to find a way to clear/format the hard disk.
Aug 16, 2007 | Samsung DVD-HR735 DVD Recorder/HDD...
Programming errors
Several things to check 1) Your time - set it manually and remove the automatic time set 2) Try manually recording even a few min of anything (just put on channel to record, press DVD button and DVD Record button) - does it give you an error message on that disk? If so it might be because you are using 16x and machine sometimes gets messed up and won't record on those speed disks - same with +R sometimes does this - try recording on 8x -R ones. Hopefully this helps - if not try unplugging unit from wallsocket and leave off about 30min then try setting program again etc (plus current local time) and use a new disk and see if problem still occurs - sometimes just unplugging it "resets" everything and then starts working again.
Jan 28, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Samsung DVD-R130 DVD Recorder Logo
316 people viewed this question
Demonic-2011
Demonic-2011
Steve Allison
Steve Allison
