Question about Panasonic CT-27G14 27" TV
Fuse blows. Hi, My tv keeps blowing up the power fuse 4amps everytime i press the power switch on the tv. I replaced the fuse,and it blows again. I belive there is a short cicuit somewhere Could u tell me which components should i check. thanks in advance.
  • Rabuor May 02, 2008
    There was power flactuation and when it came back,the Tv couldnt power on.The fuse was blown and when i tried to replace it blew several times.What is causing the blowing of the fuse?
  • the ic voltage regulator is shorted, try to replace the ic regulator
Please check for shorted diode or condenser at power section.
Posted on May 29, 2006
Efi fuse blows when car strts wher is the efi located
NO YEAR stated (old post)
there is no EFI fuse. sorry,
the ECU has 3 fuses.
FI, Dome, and IG-coil
all 3 run the ECU.
i do know what you ment.
but knowing the correct name makes reading the FSM better.
my guess 2 is you lost the fuse box cover and cant read the names.
guessing year at 91 -95
http://www.fixkick.com/power-elect/fusepanel-left-knee1w.jpg
the ECU fuse blows page. is here
http://www.fixkick.com/power-elect/blows-fuse.html
top reasons.
ECU bad CAPS
shorting fuel pump (they pull 4amps normal) if 10amps or
more they blow the fuse and or causes the ECU to click relays
like mad.
Dec 22, 2013 | Geo Tracker Cars & Trucks
Keep blowing the main fuse.
To which circuit section did you replaced the fuse? Main power retulator? Just understand, the fuses are used to protect the circuit and TV from any short circuit or over voltage. Without any one of these, no fuse will blow up. If it was due to over voltage, the set should work after a fuse replacement. But here, the fuse blow up again, means, there is some thing shorted component/s. Check which component is shorted, and replace it, before replacing an other fuse. One more thing to say is, never insert a fuse other than specified. The voltage and ampere specification to fuse, will be marked at the circuit board, very near to the fuse clamp. Insert a fuse of same rating only. Using other fuse, rated higher ampere rating, might make things worse.
May 27, 2013 | Mitsubishi WD-73827 73" HDTV DLP TV
Amp fuse keeps blowing when car is turned off
It sounds like that fuse is supplying power to more than just the amp and is being shorted out in the START mode. Normally I would think the power to the sound system would be cut off by the ignition switch in the START mode. Try to find out what else that fuse supplies power to. You can disconnect suspected trouble areas to see if that helps locate the source of the fault.
Feb 16, 2013 | GMC Cars & Trucks
I am looking to know how many amps should be the fuse of sinotec lcd tv 32"?? to replace a broken one?? thanks
Hello
The Ampere capacity of the fuse depends on the voltage to which the device is working now. If your Tv works on 220 or 230VAC; use a 4Amps slow blow fuse in place. If it works on 110VAC, use a 6Amps fuse of type mentioned above. OK.
Dec 10, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
12v outlet fuses keep blowing.
Faulty reciever ,,, Worth checking the plug assy for internal damage . Check that the sat receiver is within the power capabilities of the vehicles acessory plugs < 10amp .
Dec 23, 2009 | 2004 Ford Ranger
The power safety fuse was blown. I replaced it but everytime I plug the TV, it blows the fuse. It is a Sony projection HDTV
When fuse blows again and again that means power supply is bad and needs to be replaced.
Let me know exact model of your Sony TV to provide you power supply board part number info.
Nov 03, 2009 | Sony KP-51WS510 51" Rear Projection...
TV won't turn on
take the back off the tv and inspect the glass fuse off the ac power cord, it will probably be black and open, this is a common problem, it blows because the degaussing circuit works too slow, the original fuse is an 6.3 amp fuse, you need to replace it with a 6.3 amp slow blow or a 7 or 8 amp fuse to keep it from blowing, if you put an original 6.3 amp fast blow fuse in it, it will work for a while, but will blow again someday.
Sep 07, 2009 | Panasonic CT-32SX12 32" TV
Reverse lights fuse blew
hi
check the wire because if the fuse keep blowing there's a wire somewhere on the car that has contact with the frame so everytime you put your car on reverse the 12V wire shortcut on the frame so the fuse blow check all your positive wire and your bulb as well
Good luck
Jun 19, 2009 | 1997 Ford Explorer AWD
Panasonic CT-27G14 27" TV Logo
569 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
