Question about Canon W8200PG InkJet Printer
W8200 IP PROBLEMS
Hi i have just bought a Canon W8200 wide format printer but i cant get my pc to talk to the printer. I posted a question yesterday and was told to download the canon utility. I got a little bit further on the driver install as the w8200 came up in a "add printer" window. when i used the utility program i had to re-input the ip,subnet mask and g/w default back in to the printer menu. I did a ping on ip,subnet mask and g/w default which test ok, but the ip that printer is set to, i get timed out messages. i have tried all combinations of crossover cable and normal ethernet cable. i have tried direct from pc to printer and through a netgear wireless router with both cables. any more ideas? thanks in advance
SOURCE:
cdhardy
  • 111 Answers
SOURCE: pc and printer wont talk to each other
FIRST GO HERE http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2333&modelid=9506 GET THE DRIVER AND THE SETUP UTILITY THEN HOOK UP THE PRINTER TO THE ROUTER THEN YOUR GOOD.
Posted on May 28, 2006
  • 121 Answers
SOURCE: Canon imagePROGRAF W8200 InkJet Printer Problem Printhead Error! Turn Power Off!
You'll probably need to replace the whole printhead.  It's a bit of a job on that machine
Posted on Oct 27, 2007
starcomp
  • 118 Answers
SOURCE: error code on canon w8200
Error Code E02D02 = Clean de coding tape behind the rubber belt.
Error Code E02E05 = Problem with de ink cartridge door.
these are problem for the your error code also. so just clean your encoder stip
Posted on Mar 19, 2008
canontech
  • 1219 Answers
SOURCE: waste ink is full how to clear this message
a) How to enter Service mode
Follow the procedure below to enter Service mode.
1) Turn off the printer.
2) Turn on the printer while holding down the [Paper Source] button and [Online]
button.
3) Check that "Canon W8200" is shown on the display, and then release the buttons.
4) Next, "SERVICE MODE" is shown on the display. (If sheets are inserted, this will
be displayed after the sheets are loaded.)
5) Use the [Lower arrow] button to make a selection.
Service mode is added to the options in the Main menu.
Service mode can be entered even during error status (when Exxxx and Wxxxx are
shown on the display) by turning the power off and then using the above key
operation.
b) How to exit Service mode
To exit Service mode, turn off the printer.
c) Buttons used in Service mode
• Selecting menus and parameters: [Left arrow] button or [right arrow] button
• Entering a lower-level menu: [Lower arrow] button
• Entering a higher-level menu: [Upper arrow] button
• Setting menus and parameters: [Enter] button
Now under service mode select counter, and select printer and W-INK to reset it, and under initialize select W-INK.
But also change the waste ink absorber so that you do not get waterfalls of ink from your plotter :-)
Hope that helps
Posted on Jul 30, 2010
Testimonial: "Thank you very much............ "
  • 1218 Answers
SOURCE: We have a cannon W8200 printer that is telling us
Check the following steps :
1: Unplug power and USB
2: Open door and hold power button.
3: Connect power.
4: Close door, then release power button
5: Connect USB and an press power to use.
http://social.technet.microsoft.com/Forums/en-US/itprovistaprinting/thread/a1e247a6-52d2-416e-8432-ce3e361a9547
Posted on Nov 08, 2010
Access service mode w8200
keep trying man you'll get it please keep trying
Aug 17, 2013 | Canon imagePROGRAF W8200 InkJet Printer
I cannot find drivers for My W8200. I am using Windows7 64bit
There are no drivers yet for Canon imagePROGRAF W8200 on windows 7
Jan 22, 2011 | Canon imagePROGRAF W8200 InkJet Printer
I have an error on my w8200, on the screen
i have an error on my w8200, on the screen written ERROR E20D01,
what is the code mean?
Jun 04, 2010 | Canon W8200PG InkJet Printer
Canon W8200 error message "Print Head Error" "turn off printer"
There was no response to the question, so we called in a Canon service person who has ordered a replacement print head.
Nov 24, 2009 | Canon imagePROGRAF W8200 InkJet Printer
Error code on canon w8200
Clean the round rod that the print head moves along and also the metal work above where the carrage rollers run.
I wipe mine with a drop of oil after cleaning as error is indicating that the carrige is sticking and not moving at the correct speed.
Chris
Mar 19, 2008 | Canon imagePROGRAF W8200 InkJet Printer
you need to enter a service mode before the error message pops up. hold down paper source button + online.
that should override the message before it pops up.
go to replace print head selection. or do a clean. it may still be working. let me know if this doesn't work....but at least you can still get past the message now! marty
Oct 27, 2007 | Canon imagePROGRAF W8200 InkJet Printer
Need to pack up amd move W8200
Canon have a specific protocol to be followed to prepare the printer for transport. It is shown in a pdf file I downloaded from http://www.usa.canon.com/html/download/ipw8200.html.
the file is in the Guides section
Jan 27, 2007 | Canon W8200PG InkJet Printer
Pc and printer wont talk to each other
May 28, 2006 | Canon W8200PG InkJet Printer
Canon W8200PG InkJet Printer Logo
59 people viewed this question
Clive
Clive
old marine
old marine
