Question about Graco MetroLite Air 6116 Stroller
How to remove seat cover
Can you e-mail me instructions on how to remove the seat cover on the MetroLight stroller. It has so many buckles and snaps I can't figure out how to get it off and once I do I'm scared I'll never get it back on. It is in desperate need of washing. DO you have washing instructions as well?
SOURCE: Wondering about compatible car seats for the stroller
i have a renault clio and have a graco car seat but the seat belt iant long enough, will i be able to get it to fit?
Posted on Nov 06, 2008
SOURCE: NEED TO REPLACE A DUOGLIDER SEAT COVER FOR STOLLER
You're in luck -- Graco does sell replacement seat covers through their website.
http://www.gracobaby.com/ReplacementParts/Pages/ReplacementParts.aspx
Posted on Mar 27, 2009
SOURCE: Replacement Parts Phil and Teds Stroller
http://www.shopphilandteds.com/parts
This is the US site for replacement parts for all models.
Posted on Sep 17, 2009
SOURCE: how to change seat covers on a quinny buzz stroller
Try this link
http://www.quinny.com/media/producthandleidingen/Quinny/08.08%20win1299_Buzz4_UK.pdf
The instructions & diagram are in section 6.2 on page 5 of this 7 page pdf document.
Hope it helps!
Posted on Nov 25, 2009
  • 11 Answers
SOURCE: How to remove, clean, reinstall seat on Maclaren Techno Stroller
If you follow this link to the instrucitons on the maclaren website, the instructions tell you how to remove clean and reinstall the seat. http://us.maclarenbaby.com/toddler-buggies/techno-xt?lang=en
If you have any trouble call maclaren customer service at 1-877-443 4622
hope that helps!
1 877 442 4622 info@maclarenbaby.com
Posted on Jun 14, 2010
I took the cover off for washing. Need instructions to put back on
You should be able to download the instruction for this model from this site
Instruction Manuals
You will have to remove the buckle loop holding the harness at the back of the seat and release the straps. Once you insert these through the seat cover and back into the slot on the seat back you can lock the harness by re-inserting he buckle loops.
Aug 25, 2014 | Cosco Baby Gear
hope that helps!
May 31, 2010 | Maclaren Techno XT Standard Stroller
How do you put the cover on the seat?
If it's the new model then you need to follow this in reverse order for Cleaning the Quinny Buzz seats (comfort cushion and XL seat)
1. Open safety harness
2. Unfasten the shoulder belt snap and hook and remove the belt pad.
3. Loosen all snaps on the bottom of the seat
4. Loosen the Velcro straps on the bottom of the seat. Remove the belt buckle through the opening of the seat
5. Slide the cord of the seats out of the edges of the Quinny Buzz seat. Start with the foot section and work towards the head section
6. Pull the lap belt of the Quinny Buzz seat through the holes of the seats and remove the loops from the shoulder belts from the openings of the seat
May 19, 2010 | Quinny Buzz 3 - Juice Travel System...
How do you attach a Graco Car seat to a Baby Trend 1304 tw Snap and Go Double stroller?
Depends on which type of Graco it is, check compatibility. Make sure the babies are facing you, they should SNAP right in just as it says and then buckle them in.
May 10, 2010 | Baby Trend Snap-N-Go LX Double Stroller
Can't unbuckle the buckle
Opening the main buckle should be easy - just press in the waist strap clips as shown in the instructions. Any problems could be referred to your local stockist, or with Bebecar U.K. directly on 01692 408807, service@bebecar.co.uk They can provide instructions by e-mail, and other advice.
Oct 31, 2009 | Bebecar Raider AT Stroller
Winnie the pooh graco car seat how to put the arm straps back together after washing
I had the same problem, so what I did was look at the first picture from walmart.com's page with this car seat.
http://www.walmart.com/catalog/product.do?product_id=10843110
I noticed where the straps went through the restraint systems, and remebered that I took the bottom ones out last, so I'd put them in first.
Then I threaded the straps through the buckle parts that snap to the bottom buckle, up through the buckle parts that snap together, then back through the holes in the cover and seat at whatever height your infant is. After that you secure it in the back like the sticker at the side indicates :)
I hope that's clear enough!
Jun 17, 2009 | Graco Nautilus 3-in 1 Car Seat
How to fold a beby trend expedition single
TO FOLD STROLLER
• Close the canopy as described in the canopy section. Recline seat by releasing buckle as described in seatback positioning section.
• The stroller is folded by simultaneously pulling each trigger fold. . When the fold latches are released, the handle will begin to fall toward the floor. Release the fold buttons and press downward on the stroller handle until the stroller is completely folded. Secure the stroller in the folded position by hooking the fold latch, located on the right side of the stroller, over the rivet that protrudes from the frame.
CANOPY
* The canopy features a ratchet system that allows the canopy to be moved forward to block the sun or wind. To adjust the canopy’s position, push forward or backward on the canopy until the canopy is in the desired position. See figure 23.
SEATBACK POSITIONING
* The seat has a multiple position recline that is controlled by a strap and buckle assembly behind the seat. . To recline the seat, loosen the strap through the buckle and adjust to the required recline position. To place the seat back in the upright position, press upward on the seat back with one hand while pulling the strap through the buckle with the other. The strap will lock automatically.
http://www.babytrend.com/download/2007061021349109CT_instructions.pdf
Apr 28, 2009 | Baby Trend Expedition LE Jogger
Graco Stroller Buckle
try
http://myebestbuy.com/allplasticbuckleslist-1.aspx
heaps of them there
Oct 24, 2008 | Graco Quattro Tour Travel System
Stroller pad cleaning
You can remove the seat pad by unsnapping the two straps on either side of the bottom of the pad (where it covers over the metal frame). Then just thread the buckles through it. As far as the rest of the fabric such as canopy or fabrice sides, no luck. I got this stroller used and wanted to wash it all. I ended up just putting it (minus the removable pad) into my shower and washing it with the shower head. Then I got a Mr. Clean magic eraser and cleaned up the plastic parts. Now it looks so good!
Hope this helps...
Jan 03, 2008 | Evenflo Aura Traditions Travel System...
How do i get the seat of to wash?
I was able to find an online instruction manual for this stroller. From that manual, I was able to find the following instructions for removing the seat for cleaning.
"10 REMOVING AND REFITTING THE SEAT COVER
Remove hood from stroller if fitted.
A Twist shoulder strap end buckles and feed through holes.
B Feed waist and crotch straps through holes.
C Unclip seat cover retaining straps.
D Unfasten seat fabric from handle tubes and seat base.
E Slide fabric from seat back and base.
F When refitting seat fabric, insert seat back support tubes
into fabric slits.
G When refitting seat fabric to seat base, loop fabric flap over legrest
strap and pass crotch strap buckle through both holes in seat fabric
and then hole in seat base.
H When refitting shoulder straps, twist buckles and feed through holes."
Dec 18, 2007 | Maclaren Quest Mod Stroller
Graco MetroLite Air 6116 Stroller Logo
124 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Dennis Crouse
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
