A/c compressor Outside unit rattles like a pea thrasher occasionally, then will quit after a couple of minutes. Noise is a loud clicking. What's wrong? Tom Slough tomslough@comcast.net
  • 1 more comment
  • tomslough Sep 14, 2008
    It's definitely in the compressor. If gas low oor dryer clogged, would compressor sometimes make this loud clicking noise?
    Still cooling
  • FatGeek Dec 22, 2008
    Outside A/C unit makes a very loud clicking sound every 1.5 to 2 seconds, and with each click the unit shakes side to side and vibrates briefly.  The noise sounds like clicking from inside the house, but is a very loud Donk noise when standing near the unit outside.  Bought the house this spring, had no problems cooling the house,but the heat wouldn't shut off when it came up to temp.  The clicking noise started after we had been manually turning the unit on and off for a few weeks once the temperature dropped.  The t-stat installed by the seller was a 6 wire, needed a 9 wire, t-stat has been replaced with a honeywell programmable unit that seems to be working fine, heats properly, shuts off properly, but occasionally it will click for several minutes until the t-stat shuts it off and it is able to stay off for a while.
  • 958 Answers
Observe where the noise could be coming from, it could be from the fan or from the compressor.
it could also be just a loose metal vibrating.
if it is still cooling, then it could definitely be just a loose metal housing or bracket.
hold onto it and feel if the noise would disappear.
tighten all loose screws and bolts. replace the screws if necessary.
tnx 4 using fixya,
drcool
Posted on Sep 14, 2008
  • francis rivero Sep 14, 2008
    no it would not make such loud clicking noise.
    if it is low on gas and/or clogged dryer, it should run as smooth as before and even more silent because of the less load it is experiencing.
    as i have asked before, is it still cooling?
    please let me know.
    tnx
    drcool
  • francis rivero Sep 15, 2008
    ift he noise is coming from the compressor and it is still cooling then there could be a spring inside the compresor broke. it happen sometimes.
    the soulution would be to remove the compressor, cut it in half by sawing the housing, then you can see the broken spring in there and rplace it. i am not sure if you can find the part. they may not be selling the pring only. you can only get that from an identical compressor which only service shop would probably have a used and junked one.
    then after you have replaced the spring, you can weld back the housing airtight.
    the welder should really be good to seal it good.
    or you can just ignore the noise and live with it and if it i no longer cooling, then that is the time to replace the compressor.
    tnx again
    drcool
Switch on compressor clicks on loudly and compressor makes a rattling noise when it runs.
if your sure it is the compressor relay that is making the noise then i would suggest replacing it fast... it may be getting weak and will leave the milk spoiling soon... another possibility is that the compressor it self is starting to get harder to crank and or the compressor itself is getting ready to go out...you may be hearing a rattle because sometimes it is not starting and the rattle is the compressor vibrating because of a weak start relay... hopeful thats the case if it constantly is rattling then i would say the compressor valves are starting to fail adn won't be long before you are shopping for a new unit or a appliance repair man ...good luck to you...lets hope you caught it early enough ....
Feb 11, 2011 | Maytag MZD2766G Side by Side Refrigerator
2006 sporster 1200 lots of valve noise has oil pressure.think it is colasped lifters. what your thoughts.or trouble shooting tips without breaking down the engine
If you're having that much valve noise, you have probably lost oil pressure for some reason. Take your oil filter off the engine and take the spark plugs out. Spin the engine with the starter and watch for oil to pump out of the fitting for the oil filter.
Now, you didn't mention how loud the valve noise was. If you have indeed lost oil pressure to your tappets, the noise will be quite noticable, not just a slight rattling. Your bike will sound like a pea thrasher.
The late model Sportster oil pumps are not like the older models that were so bad about shearing the drive pins. The late model doesn't have the pins. They have flat drive angles on the oil pump shaft. About the only thing that I can think of that would cause a loss of oil pressure on a Sporty is a piece of trash got into the tank and is blocking the inlet to the pump or the pump is air locked for some reason. Unscrew the oil pressure sending unit and spin the engine over long enough to pump out a few ounces of oil.
I've only seen one Evo Sporty lose oil pressure. Someone had tried to stop an oil leak in the oil tank by Creme coating the tank. Creme is designed for a fuel tank, not an oil tank. The coating cannot take the heat of the hot oil, becomes brittle and starts flaking off.
Good Luck
Steve
Aug 21, 2010 | 2006 Harley Davidson XL 1200 R Sporster...
It's making a loud running noise
Noise can come from these areas:
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows: If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer. If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer. If the freezer is on the left, the fan is on the back wall, halfway up or near the top. Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead. To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting).
The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Mar 31, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refridgerator make a noise every 3 minutes
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
Mar 29, 2010 | Kenmore 56539 / 56532 / 5653 / 656534 Side...
I am getting a loud rattling noise. could this be my compressor
Jan 29, 2010 | Frigidaire Refrigerators
The back side of refrigerator is makeing a clicking noise near the circuit board of refrigerator
if its a constant click, every couple of minutes, its more than likely your relay and overload.
pull the unit out, take off the back, unplug it, and on the compressor is a small electrical box,
pull that off the compressor and shake it, if you hear a rattle its bad, if not ohm it out on a voltmetr
it should read continuity
Oct 16, 2009 | Refrigerators
A/C unit compressor shuts off
You will need a technician to check the system pressures with a gauge. Souns like the compressor is fighting high pressure in the coil that is outside.. Try this.Right after the compressor chugs to a stop, un plug unit and run cool garden hose water over the outsife coil for a few minutes, then see if the compressor will start again any sooner yhan before. If so. High pressure is the problem. But you still need a tech to adjust the refrigerant level. Make sure air is blowing out from the coils. You may want to clean the coils before our little test Hose it out with pressure yo remove any buildup on the coil and fins. Spray with 409 if you wish, it would help remove the dirt. Let it drip dry for half an hour and see if the compressor still shuts down. Make sure any water coming from the a/c itself is draining so the fan doesn't throw it around. Good luck Ned
Oct 05, 2009 | Fedders X Chassis A3X05F2B Air Conditioner
My new Kenmore window unit 76081 makes loud rattle
If it does not make the noise when the fan is ruunin you may ahve abroken sping in the compressor. Make sure you Window unit is level. If not the compressor will knock on the inside. Rusty
Jun 12, 2009 | Kenmore 76081 Wall/Window Air Conditioner
Clicking of Ge Model PDS22SBRBRSS; serial No; DL047209
IF the below mentioned information does not help, then contact a elextrical engineer worksman who can check the circuit board as it might also cause a short cicuit.
  • If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
  • The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
  • If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.
  • The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
May 31, 2009 | PDS22SFS Stainless Steel
Clicking Fridge
I used to have a whirlpool fridge, they are the ones who make kenmore too. It used to make a loud thud noise. It was the compressor turning off. sometimes it was loud enough to wake me up at night. It did this for years and I never had any problems with it. when I purchased a larger fridge I sold it to a friend and its still working today. If you can tolerate the noise I wouldn't worry about it unless it starts giving you trouble.
Nov 01, 2007 | Refrigerators
Heating & Cooling Logo
307 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
